Quantcast TJ Headlight upgrade.. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > TJ Headlight upgrade..
Old 06-13-2008, 11:42 AM   #1
98tjsahara
One of my headlight lenses has a hole in it from a rock chip and it is starting to turn a dull color and it looks bad and puts out less light. I was looking around at headlight upgrades and was wanting to know what everyone else is using.
Here is what I found...
http://www.quadratec.com/products/97017_601.htm
http://www.quadratec.com/products/97018_201.htm
Black Jeep Club v2.0 Member #1337
My Jeeps build thread
1998 TJ Sahara, 4.0L, 3sp auto, d30/d35 w/ 4.11.
1.75" + 2.25" BB, BDS shocks, Spidertrax 1.25" wheel spacers, 15x8 Ravines, 33x12.5-15 BFG a/t, Kilby 50" front bumper, Bestop sailcloth w/ tint.
98tjsahara is offline   Reply With Quote
Old 06-13-2008, 12:59 PM   #2
BlueFlame
Yes on the housings. Good product, good price.
No on the 'magic bulbs.' First off - blue glow?! jeesh, even my daughter wouldn't do that. But more importantly you can get top notch bulbs for far less money. Not to mention those housing come with IPF bulbs already.
But it's your money.
BlueFlame is offline   Reply With Quote
Old 06-13-2008, 01:03 PM   #3
unsung
4
unsung's Avatar
I did those housings but I went with the Fatboys IIRC. I also needed to adjust them down in a big way as I think is the norm. They are pretty bright and I am happy with them.
unsung is offline   Reply With Quote
Old 06-13-2008, 01:08 PM   #4
Xander
http://northridge4x4.com/proddetail.php?prod=PKG-IPF ... you'll be more than happy
'07STI
'12 WK2 Overland
Xander is offline   Reply With Quote
Old 06-13-2008, 01:44 PM   #5
dogbluedrummer
Trust me....
dogbluedrummer's Avatar
Here is my understanding from reading a lot of threads on this topic....
IPF and Fatboys is a very popular mod. Some people suggest you upgrade the wiring harness. The lenses are not DOT approved. There are also complaints about how the light housings don't fit tight and tend to rattle. However, the light output is fantastic.
Another option is to use Delta housings. They are DOT approved and fit mcuh better. The same Fatboy bulbs will work. Same issue with the wiring harness. Again, excellent light output.
Another option is from http://www.roundeyes.com/Jeep_Headlamps-7_Round_Jeep_Conversion_Headlamps.html. It is what I have. Does not need upgraded wiring harness, and is DOT approved. Very good light output. I tested them against stock, and stock housings with Silverstar bulbs. The bulb & lens from Roundeyes is far superior. They cost $110 and can be installed in 15 minutes.
Patriot Blue 2001 TJ
Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires.
My build threadhttp://www.jeepforum.com/forum/f22/free-wife-good-home-pics-included-528892/
dogbluedrummer is offline   Reply With Quote
Old 06-13-2008, 02:12 PM   #6
BChamberlin
BChamberlin's Avatar
Damn, is there a lense of some kind on those roundeyes?
99 Wrangler Sport
Custom stinger / KC Fog Lights / 2" RE BB / Cragar Soft 8's / Igge Seat Covers
31x10.50 BFG All Terain / Tuffy Security Console
BChamberlin is offline   Reply With Quote
Old 06-13-2008, 03:21 PM   #7
98tjsahara
I thought the blue glow would look pretty trick, turn off the lights and have a blue glow slowly fade out. Kinda make it look like it is powering down.
Originally Posted by Xander View Post
Nice find.
I like that you dont need to worry about being legal or messing with the wiring harness. They look pretty sharp too.
Old 06-13-2008, 03:28 PM   #8
pilot-one
I bought the Rampage light kit here:
http://www.automotiveconcepts.net/store/Jeep-Wrangler_product_43473.html?utm_source=google_prod ucts&utm_medium=organic
They look just like the headlights on the 08 JK and they work great.
Gravity Rat #149
But what do I know? I don't really even have a Jeep. I just make it up.
pilot-one is offline   Reply With Quote
Old 06-13-2008, 06:39 PM   #9
Border Dave
Based on this article in JP Magazine, I bought the Hella Vision Plus headlights.
Here is the best price I could find on them(and they come with the bulbs).
Border Dave is offline   Reply With Quote
Old 06-13-2008, 06:52 PM   #10
Twitchy
I went with the IPF H4 conversion and they are outstanding, they make my PIAA 510 55w replacement fog lights absolutely useless on either beam
My store of choice....NATIONAL 4 WHEEL DRIVE; CALGARY, ALBERTA
RCD 6" Long Arm, Procomp Xterrain 35x12.5, DC-1 Black 16x10, Champion 10,000lbs winch, PIAA lighting, H4 Headlights, Magnaflow muffler, Viking Soft Top, Tuffy Consoles, Boston Acoustic audio, Hurst short throw, Trailjammer system, Air Raid CAI
my armor thread: http://www.jeepforum.com/forum/f9/360-degrees-gen-right-tj-armor-594083/
Twitchy is offline   Reply With Quote
Old 06-13-2008, 07:40 PM   #11
TyJeep
Check out this write up and install. IPF H4 Performance Headlight Conversion Lenses and X51 Fatboy Super Low Beam XX Bulbs from Northridge.
http://www.4x4xplor.com/ipf-h4.html
TyJeep is offline   Reply With Quote
Old 06-13-2008, 07:48 PM   #12
BOWMAN1911
i did the delta lenses & fatboy bulbs, the bulbs burned out pretty quick... put the deltas in & they've lasted alot longer
BOWMAN1911 is offline   Reply With Quote
Old 06-14-2008, 07:50 AM   #13
dogbluedrummer
Trust me....
Yes, there is a lens.
- 60% brighter than conventional sealed beam headlamps
- H4 60/55 watt bulbs are replaceable
- Die-cast aluminum housing with a complex multi surface reflector that produces a wider beam pattern
- Unbreakable clear polycarbonate lens
- Gortex® breather allows heat to escape while keeping moisture out of the lamp assembly
- Lamp assembly can handle off-road bulbs up to 130 watts
- Easy drop fit installation with no additional wiring needed
My build threadhttp://www.jeepforum.com/forum/showthread.php?t=528892
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
