TJ Hard Start & rough idle(Everyone help plz) - JeepForum.com
post #1 of 8 Old 07-07-2010, 01:35 PM Thread Starter
Bwesley
Hopefully Jerry or someone else wise will get wind of this one. Several months ago , my 98 TJ had small problems while starting and bigger problems when reaching speeds over 55mph. It would sputter and jerk really bad when reaching those speeds. I replaced the wires, plugs, ignition coil, rotor, and distributor cap. Still no change. I then took it in to get looked at. They replaced the front axle. After that, the sputtering at high speeds went away. However, I still experienced a hard start, then a rough idle. The first attempt to start fails. The second works, most of the time, followed by a temporary rough idle. I also feel that ever-so-slight sputter when I take my foot off the gas at high speeds.
About 3 months ago, I replaced the IAC Valve and cleaned out the throttle body. This did nothing. Over the last few months I added fuel injector cleaner to the tank twice, with no avail. I also attempted to clean the fuel injectors manually, but could not get them removed (must've done something wrong). Just today, I replaced the O2 sensor. Still, nothing. I am assuming the next step is to get to the fuel filter and maybe take another crack at the fuel injectors.
Bwesley is offline
post #2 of 8 Old 07-07-2010, 01:39 PM
freeskier93
Pull your plugs and see what they look like, check you cat for clogging, and something fuel would be my last guess.
freeskier93 is online now
post #3 of 8 Old 07-07-2010, 01:43 PM Thread Starter
Bwesley
Thanks. Never checked my CAT before. Is that very difficult??
Bwesley is offline
post #4 of 8 Old 07-07-2010, 01:44 PM
vindicated
Did you miss me?
vindicated's Avatar
x2 it would almost have to be fuel related. Mine is doing the same thing, and I have been told to replace the check valve on the fuel pump. This might explain the no start on the first try. Not sure if a 98 has that though.. Now, as far as sputtering while driving, may be your fuel pump, or maybe a clogged filter. Have you checked the fuel pressure yet?
Originally Posted by bradthebard
Vin's so hard core, he drinks the whole jug of STFU and then has a three hour conversation about it.
vindicated is offline
post #5 of 8 Old 07-07-2010, 01:50 PM Thread Starter
Bwesley
I have not checked the fuel pressure yet. Quick way to do so??????
Bwesley is offline
post #6 of 8 Old 07-07-2010, 02:48 PM
Sundowner
Should be a connection for a gauge on the rail...
Do you have any check engine light activity? Any codes?
Also, did you say they replaced the front axle??? Why??? Tell me, tell me, I implore...!
Sundowner is offline
post #7 of 8 Old 07-07-2010, 02:49 PM
vindicated
Did you miss me?
vindicated's Avatar
Also, a nice, filled in profile would be nice.
post #8 of 8 Old 07-07-2010, 06:53 PM Thread Starter
Bwesley
So tomorrow morning, I wil pull the plugs and see what they look like. I did have a check engine code several months ago (p0505?) 5th cylinder. The mechanic said that my front axle was in very bad shape and could have been the cause of me losing power while approaching high speeds, and while driving up an incline. Keep coming with the input!! And I will update my profile .
Bwesley is offline
hard , start , rough , idle , TJ
2.5 hard start cold, rough idle, sometimes stalls 91wrangler4cyl YJ Wrangler Technical Forum 1 01-01-2010 08:29 AM
1997 2.5 will not start on incline and rough start/idle when cold. BuckeyeTJ TJ Wrangler Technical Forum 0 11-24-2009 09:39 AM
4.0 Hard Start / Backfire / Rough Run after extended idle biasdesign YJ Wrangler Technical Forum 8 09-17-2009 06:18 AM
Rough idle and hard start '89 2.5L Matt_vs_YJ YJ Wrangler Technical Forum 19 04-18-2008 06:38 PM
2.5L Hard start and rough idle... Elf YJ Wrangler Technical Forum 15 02-27-2008 08:39 PM
