TJ grill removal - JeepForum.com
post #1 of 5 Old 04-18-2008, 09:11 PM Thread Starter
MTDennis
TJ grill removal
Can anybody tell me how to remove the grill from my TJ? I'd like to paint it, and masking off the grill is an option I guess, but taking the grill off and just doing it properly seems a lot better. It's the stock grill, no chrome, no inserts.
Surprisingly, I couldn't find a write-up about this anywhere.
MTDennis is offline
post #2 of 5 Old 04-18-2008, 10:14 PM
JJs99TJ
Take off the two support rods that bolt on top of it that run to the firewall.
3 bolts on each side under the fender, 1 on each side on top of the fender.
1 bolt underneath (body mount). The shroud, radiator, a/c condenser is where
it gets to be a PITA but I did it a couple different times without too much trouble.
Originally Posted by rnemovr
oman, what happened in the wreck? i see it bent your bumper, did you hit a camel?
JJs99TJ is offline
post #3 of 5 Old 04-19-2008, 04:16 PM
BlueFlame
BlueFlame's Avatar
just remove all the bolts that hold it on and remove it...
(however did we manage before 'writeups' on the internet....)
Don't forget to disconnect the lights.
BlueFlame is offline
post #4 of 5 Old 12-20-2011, 06:58 AM
efm-7
Sorry to dig up a dead thread, but I have a problem regarding the bolts that connect the fender to the grill. The factory paint is locking some of the bolts. Is it advisable to use some sort of solvent? I tried some PB blaster after budging the bolt slightly, but I didn't have much luck. Sustaining the force required to "turn" some of these bolts would undoubtedly snap them.
I'm sure I never really turned the bolt, I was probably twisting them.
efm-7 is offline
post #5 of 5 Old 12-20-2011, 07:36 AM
Rubi4Us
Paint shouldn't prevent these bolts from coming off. If you can't get them loose, you could try a small hand torch to slightly heat up the bolt and try to get it loose. Otherwise, just go for it and the worst case is you drill them out.
LJ 2005 Rubicon Unlimited "Sahara" Limited Edition #0146 of 1000
35 inch KM2's with 5.5 inch Rock Krawler Long Arm
Rubi4Us is offline
Power locks and grill removal burg JK Wrangler Technical Forum 4 03-29-2009 03:49 PM
Front Grill Removal '05 TJ cmorra68 TJ Wrangler Technical Forum 2 11-03-2008 02:36 PM
TJ Grill Removal finsout TJ Wrangler Technical Forum 4 09-26-2008 01:23 PM
grill removal 98 tj clyderains TJ Wrangler Technical Forum 6 12-17-2007 03:55 PM
Front Grill Removal: How? rock2r TJ Wrangler Technical Forum 3 06-27-2005 08:50 AM
