TJ Grill removal - JeepForum.com
post #1 of 11 Old 04-28-2010, 11:28 PM Thread Starter
Paczowski123
TJ Grill removal
Ok i am getting ready to start my trans cooler install project and my only question is the grill removal. What does it take to remove it? I know of the bolts sinside the fenders and the two rods that run back to the firewall area what else am i missing?
Paczowski123 is offline
post #2 of 11 Old 04-29-2010, 07:09 AM
CdnRubi
There is a body mount bolt at the bottom right in the middle too.
CdnRubi is offline
post #3 of 11 Old 04-29-2010, 07:11 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Coolant hoses to the radiator.
And a couple plugs for the lights.
Wheelin98TJ is offline
post #4 of 11 Old 04-29-2010, 11:51 AM Thread Starter
Paczowski123
do you mean pulling the radiator out with it? i thought you seperated the condenser and radiator from the grill to remove it?
post #5 of 11 Old 04-29-2010, 12:07 PM
Wheelin98TJ
JEEP FREAK
If I pull the grill, I usually pull the radiator with it.
If you pull the radiator from the grill, you'll still have to disconnect the hoses and set the radiator aside.
I didn't think of this before, but it just struck me, why are you pulling the grill to install a tranny cooler?
post #6 of 11 Old 04-30-2010, 11:27 PM Thread Starter
Paczowski123
i figured the grill would need to be moved to get the cooler inside of it and to mount it easier? is there an easier way it would sure make my life easier lol
post #7 of 11 Old 05-01-2010, 05:55 AM
Wheelin98TJ
JEEP FREAK
Yea, it will be easier to leave the grill in the Jeep.
That way you do not have to drain your coolant.
You can unbolt the top 2 bolts for the radiator on both sides and then tip it back a little. That will give you enough room to slide the tranny cooler inside the grill.
post #8 of 11 Old 05-01-2010, 09:00 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Depending on your level of ineptitude, it's best to pull the fan blade when you tip it back to keep from punching a hole in the radiator, plus the extra room is nice.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #9 of 11 Old 05-01-2010, 09:33 AM
2003RubiBlue
Thats always helpful unless you want to drain the radiator the hard way.
Also depending on the size of your cooler, I put mine in through the headlight holes. Remove headlight, and bucket, its tight but it works.
-Brian
Will work for Jeep parts...
2003RubiBlue is offline
post #10 of 11 Old 05-01-2010, 11:17 AM Thread Starter
Paczowski123
yeah i will most likely need to put it through the grill its a little larger cooler..but itend to take something easy and make it hard so thank yall for the help..
post #11 of 11 Old 05-01-2010, 12:43 PM
chadsmeltzer
chadsmeltzer's Avatar
I also put mine through the headlight hole, it was tight but it fit.
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
TJ grill removal MTDennis TJ Wrangler Technical Forum 4 12-20-2011 06:36 AM
Front Grill Removal '05 TJ cmorra68 TJ Wrangler Technical Forum 2 11-03-2008 01:36 PM
TJ Grill Removal finsout TJ Wrangler Technical Forum 4 09-26-2008 12:23 PM
grill removal 98 tj clyderains TJ Wrangler Technical Forum 6 12-17-2007 02:55 PM
Front Grill Removal: How? rock2r TJ Wrangler Technical Forum 3 06-27-2005 07:50 AM
