TJ Gauges Won't Move - JeepForum.com
post #1 of 12 Old 03-26-2013, 02:07 PM Thread Starter
cptkarla
Hi! I'm having trouble with my '98 Wrangler.
It's 4cyl, 2.5L, manual engine.
A couple of weeks ago, the tachometer and speedometer would randomly drop (when the car was running) and come back on once the car came to a full stop, was put into neutral, or in some cases, when the car was turned off and turned back on. It continued for a few days then went away on its own. Sometimes, the airbag light would stay on.
Today, I turned my car on (after it running fine earlier) and the temperature gauge, oil gauge, gas gauge, and battery gauge did not move at all, but the tachometer and speedometer worked fine.
Any solutions? I've read some posts where cleaning/replacing the F10 and F17 fuses fix the problem, others where wiring was the issue.
cptkarla is offline
post #2 of 12 Old 03-26-2013, 02:13 PM
NotURMailman
NotURMailman's Avatar
Hmm...
Could this be a clock spring issue?
I'm not sure.
Do all of the gauges ground to the same spot?
I know on older 4.0 Jeeps (Cherokees specifically) there was a ground strap attached to the back side of the engine that would break and cause inoperative gauges.
I'm sure someone around here has had a problme like yours. Did you do a good search?
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #3 of 12 Old 03-26-2013, 02:19 PM
wwch99tj
Try cleaning your battery cable connections really well
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #4 of 12 Old 03-26-2013, 02:21 PM Thread Starter
cptkarla
I don't think it's a clock spring issue, it must be electrical.
The oil gauge moves up a little.
After banging on the dashboard some, the gauges finally began operating and the airbag light turned off.
cptkarla is offline
post #5 of 12 Old 03-26-2013, 02:23 PM
NotURMailman
A clockspring or clock spring is a special rotary electrical connector which allows a vehicle's steering wheel to turn while still making an electrical connection between the steering wheel airbag and/or the vehicle's horn and other devices and the vehicle's electrical systems. The clockspring is located between the steering wheel and the steering column.
They tend to fail on TJs that get rained into a lot due to the top being left off.
The only reason I even brought it up is because you mentioned the air bag light.
post #6 of 12 Old 03-26-2013, 02:25 PM
Spyder05
was it raining or really humid when you were having issues??
pull your gauge cluster and look at the connectors on the back of it....they are known for bad connections and randomly loosing the cluster.
05 Tj d44's, 4.88's, ARB's, 37's and some bling
99 TJuggy tons, 40's
14 RAM 1500
07 SRT 8 grand
Spyder05 is offline
post #7 of 12 Old 03-26-2013, 02:26 PM Thread Starter
cptkarla
The horn used to go off in cold weather, but we got a button for it.
The car interior has never been exposed to rain, for sure.
We've checked the fuses, not the problem.
So the only theories left are clockspring and wiring. Any other ideas?
cptkarla is offline
post #8 of 12 Old 03-26-2013, 02:27 PM Thread Starter
cptkarla
Spyder05,
No, it's actually cold today and a little on the dry side.
cptkarla is offline
post #9 of 12 Old 03-26-2013, 02:40 PM Thread Starter
cptkarla
This is what I'm looking at right now. What am I looking for exactly?
cptkarla is offline
post #10 of 12 Old 03-26-2013, 02:52 PM
SpcRodeo
I had the same issue when I bought my 98 TJ. Took it back to the dealer who sent it off. I got it back and couldn't read my odometer and it quit working again after a month. So I would love to know how to fix it myself as well.
SpcRodeo is offline
post #11 of 12 Old 03-26-2013, 03:08 PM Thread Starter
cptkarla
Not sure if the banging on the dashboard fixed it, but it seems to work now. We put some dielectric grease on the clusters!
cptkarla is offline
post #12 of 12 Old 03-26-2013, 03:10 PM
biffgnar
biffgnar's Avatar
In XJs very common for the wire looms that plug into those two plugs to come loose. I think less common in TJs, but what you describe is similar to what I've seen happen in my XJ. Clean the connections, try to tighten up the plugs and put conducter on them (and dielectric grease is not a conductor).
Romney in 2020!
biffgnar is offline
dashboard , electrical , fuses , gauges , wrangler tj
