TJ Front Fender Flare Clearance Light Issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > TJ Front Fender Flare Clearance Light Issue
TJ Dana 60 - BOLT IN REARSpartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEBds fox ipf 2.0 racing series shocks now available at rock
Unread 06-28-2011, 08:03 AM   #1
boeingxtreme
This winter I got into a little "Fender Bender" (literally). And it broke my clearance light, I didn't worry about fixing it until it was warmer out and a friend gave me a new lense, the problem now is that the light socket is all corroded and I have "cleaned" the socket 2 times and its worked but now It wont come on again, my turn signal flashes faster because it knows theres a dead light, I fixed the fender as it wasnt that bad, now I just need a new harness or something so my clearance light will work. Any Suggestions?
Thanks Dan
boeingxtreme is offline   Reply With Quote
Unread 06-28-2011, 08:24 AM   #2
Jason
Sarcastic Genius
Jason's Avatar
http://www.amazon.com/Imperial-84091-Twist-Socket-Pigtail/dp/B001J7M6X2
New one.
Jason is offline   Reply With Quote
Unread 06-28-2011, 10:20 AM   #3
boeingxtreme
Originally Posted by Jason44406 View Post
Sweet!, is this the right one? Im about to order it.
Unread 06-28-2011, 10:24 AM   #4
JrTjK
http://www.quadratec.com/products/55...googlemerchant
sometimes you need to trim 1 or 2 of the tabs but otherwise they're all the same.
MA/RI/NH Jeepers - CJ Meet & Greet Saturday June 22nd, rt138 Canton, MA.
PM me for details!
JrTjK is offline   Reply With Quote
