tj front adjustable track bars for 0-3.5", does yours hit or fit? - Page 8 - JeepForum.com
post #106 of 1784 Old 05-11-2009, 07:40 AM
Kiwi
Originally Posted by redsoxski View Post
BUMP - anybody have anything to report on the new Currie HD trackbar??
I put mine on yesterday and haven't bent it yet. (Although the rig still hasn't moved out of the garage ) I have bent 3 of the JKS versions so will see if this one holds up.
Kiwi is offline
post #107 of 1784 Old 05-11-2009, 06:50 PM
redsoxski
redsoxski's Avatar
Any clues how this differs from the old style (or better yet any pictures?)? The currie website just has the stock picture that is the same as the old model.
redsoxski is offline
post #108 of 1784 Old 05-11-2009, 07:18 PM
Kiwi
Was no use me taking pictures of the JKS as comparison, since of the 2 I have here, one has been welded on the bend where it broke, and is not the correct shape, and the other is still way bent bent out of shape.
The differences have been described somewhere in this thread I believe, but there is a lot more clearance due to the different shape and the way the frame end is attached. These pictures are about the best I can do just now.
Kiwi is offline
post #109 of 1784 Old 05-11-2009, 07:59 PM
nriver
2011 JK Wrangler
I like the look of that trackbar. Looks like the moved the mounting point as far forward as they could.
Why do I post here?
nriver is offline
post #110 of 1784 Old 05-11-2009, 08:04 PM
Yesfan70
Yesfan70's Avatar
What is everyone's take on Rough Country's adjustable track bars? I have their 2.5" lift, but to be honest it seems more like a 3-3.5" lift.
I would like to add Riddlers for my diff covers on down the road and was wondering if RC's front adjustable track bar would be alright to use with them (or the stock covers for the moment). Seems like I read in another thread where they redesigned the front adjustable for this very reason. I'm also running their rear track relocate bracket for the rear. Would that be alright to stay with, or should I upgrade to a rear adjustable as well?
I don't seem to be having any issues, but I haven't had this lift on a whole week yet. Just thought I would go ahead and ask in case a few wheeling trips tell me otherwise.
2004 Jeep WJ
Only in a Jeep
Yesfan70 is offline
post #111 of 1784 Old 05-11-2009, 08:10 PM Thread Starter
mudb8
want it rite or rite now?
mudb8's Avatar
thanks kiwi...
that's awesome how they put it offset on the jj. that gives at least a 1/2" by it'self.
could you post the bent and welded jks bars anyhow just for giggles and to see a wasted jks bar? lol.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #112 of 1784 Old 05-11-2009, 08:13 PM Thread Starter
mudb8
mudb8's Avatar
there's a pic above of the rc hitting the stock cover on alexia's jeep... that is the new front rc track bar also... as far as I know it' hasn't been changed, if It has I haven't heard about it or seen it yet...
mudb8 is offline
post #113 of 1784 Old 05-11-2009, 08:21 PM Thread Starter
mudb8
mudb8's Avatar
never mind kiwi.... I found the bent jks... lol
mudb8 is offline
post #114 of 1784 Old 05-11-2009, 08:30 PM
Kiwi
Originally Posted by mudb8 View Post
thanks kiwi...
First one I bent alongside a new one
Second bent one on top, and the bent, broken and welded one on the bottom
Kiwi is offline
post #115 of 1784 Old 05-11-2009, 08:33 PM Thread Starter
mudb8
mudb8's Avatar
thanks again kiwi... I didn't see the welded one...
mudb8 is offline
post #116 of 1784 Old 05-24-2009, 10:21 AM
Houndmaster1
So, Is there a silver bullet for an adj front track bar for a small lift, or is it all trial and error for a d44?
Houndmaster1 is offline
post #117 of 1784 Old 05-24-2009, 11:50 PM Thread Starter
mudb8
mudb8's Avatar
the JKS will work depending on your bumpstops...
I haven't seen the currie on a small lift yet, there's a good bet it'll work even on stock suspension if it's trimed to shorten it.
mudb8 is offline
post #118 of 1784 Old 05-25-2009, 05:49 AM
Alexia
Alexia's Avatar
That is the track bar for their 4" lifts. The new one designed for the 2.5" lifts does not hit.
2004 Jeep Wrangler Unlimited, Automatic
RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers -
Power Door Locks with Keyless Entry
Alexia is offline
post #119 of 1784 Old 05-25-2009, 10:29 AM Thread Starter
mudb8
mudb8's Avatar
did you get a new one?
RC's for the 2.5" has about the same bends as the RE, FT, rusty's, ....
mudb8 is offline
post #120 of 1784 Old 05-25-2009, 05:37 PM
Yesfan70
Yesfan70's Avatar
So if I went to Riddler covers for my diffs (D30/D44), would I still be alright? If so, I might pull the plug on a set of adj trackbars from RC.
2004 Jeep WJ
Only in a Jeep
Yesfan70 is offline
tj , track bar
how important are front and rear adjustable track bars? travk1234 TJ Wrangler Technical Forum 5 09-02-2009 08:01 AM
Adjustable track bars Aiden80013 TJ Wrangler Technical Forum 8 05-17-2009 03:07 PM
adjustable track bars jr1966 TJ Wrangler Technical Forum 2 03-17-2008 04:15 AM
RE Adjustable Front Track Bar and a 2" BB... ? thejafe TJ Wrangler Technical Forum 4 01-01-2006 10:25 AM
Best Adjustable track bars kaybone TJ Wrangler Technical Forum 2 02-24-2005 06:15 PM
