Quantcast tj front adjustable track bars for 0-3.5", does yours hit or fit? - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > tj front adjustable track bars for 0-3.5", does yours hit or fit?
Old 05-05-2009, 03:29 PM   #91
bonesnv
I am assuming the new Currie one that everyone is referring to is the JS-9120?
bonesnv is offline   Reply With Quote
Old 05-05-2009, 09:18 PM   #92
mudb8
want it rite or rite now?
mudb8's Avatar
I don't have a part number yet.. and no pics have been posted yet!
I did look on currie's site and found the HD track bar, tho it looks just like all the other jks bars.. I guess we'll have to call for more info..
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator
In need of work... 11/2/11
mudb8 is offline   Reply With Quote
Old 05-05-2009, 09:52 PM   #93
Strizzy
An option I have been considering for a bit now is to chop the end off my OEM trac-bar and weld in a threaded insert and use a flex joint rod end similar to this:
Would this be possible?
-Steve-
2004 TJ Rubicon
OME HD springs - OME shocks - RE front/rear adjustable Superflex LCAs - Rusty's adjustable front UCAs -
Full Traction rear tri-link conversion - Rusty's quick disconnects - JKS 1.25" BL - JKS 1" MML - Nth diff skid -
Iron Rock Off Road HD tie-rod - Warn M8000 - Tom Wood's rear CV shaft - Rokmen high clearance belly skid -
Rokmen Mercenary Sliders - Rokmen engine/tranny skid - Rokmen steering box skid - Rokmen Mercenary front bumper
RIP:
2004 WJ Overland: 5.5" with front/rear long arms, sliders, skids, 32" Cooper STT's and wheeled it like it wasn't my DD.
2 motors, 2 trannies, 150k miles before I parked it.
Jeeps Going Wild
Strizzy is offline   Reply With Quote
Old 05-05-2009, 09:56 PM   #94
SeanCucf
I'm too lazy to read the entire thread, but I'll just throw this out there. Looks like it's already known, but my JKS bar hits the stock cover with my little BB.
SeanCucf is offline   Reply With Quote
Old 05-05-2009, 10:12 PM   #95
mudb8
mudb8's Avatar
the stock track bar is a solid unit.. not something yo could just weld a bung to..
and one of the strongest bars you can actually use. just a bit to short for more than 2" of lift.
Old 05-05-2009, 10:32 PM   #96
Strizzy
Is a Rubi trac bar the same as a non-Rubi trac-bar?
If so, I may pick one up and play around with some options.
-Steve-
2004 TJ Rubicon
RIP:
Jeeps Going Wild
Old 05-06-2009, 12:27 AM   #97
tkki1230
The HD Currie Bar is different from the JKS. They are just using a generic picture on their website. The bend in the new HD JS Trackbar is a little wider than the JKS. It clears the diff with room to spare. You have to drill out the frame mount to 5/8's. That was also an upgrade over the JKS 9/16 bolt with the tapered sleeve design. Sorry I can't post any pictures, as I'll be out of town for the next couple of weeks. I'm sure there are others that have upgraded to this trackbar.
tkki1230 is offline   Reply With Quote
Old 05-06-2009, 01:26 AM   #98
mudb8
mudb8's Avatar
same as far as I can tell, nth degree used to rebend the stock bars to accomodate 2.5" lifts.. you could do the same with a press and some time.
the leveled ome 2.5" lifts typically need about a 5/8" longer bar..
Old 05-06-2009, 01:31 AM   #99
mudb8
mudb8's Avatar
sweet.
that's what I figured on the pic, I was told the bar will also clear a d60.
O' an if no one posts any pics I'll be waiting for your's...
Old 05-06-2009, 03:16 AM   #100
jeep2008
if you have the jks and you want to upgrade to the HD currie would you have to drill another hole or just broaden up the current one i drilled for my jks?
my build thread
04TJ (SOLD)
01TJ (BUILDING)
jeep2008 is offline   Reply With Quote
Old 05-06-2009, 11:01 AM   #101
bonesnv
The Currie hole is larger so just re-drill it out to accommodate the larger mounting hardware.
Old 05-06-2009, 08:17 PM   #102
mudb8
mudb8's Avatar
yep, bigger, 5/8" hole.
Old 05-10-2009, 11:03 AM   #103
redsoxski
BUMP - anybody have anything to report on the new Currie HD trackbar??
redsoxski is offline   Reply With Quote
Old 05-10-2009, 01:16 PM   #104
mudb8
mudb8's Avatar
I might have to order one just to see it. I'm sure it wouldn't sit on the shelf for long..
Old 05-11-2009, 02:53 AM   #105
jeep2008
Yes please do!!If it doesn't hit i'll buy it from you asap
my build thread
04TJ (SOLD)
01TJ (BUILDING)
tj, track bar
Glock Forum
