#76 | |
want it rite or rite now?
here's a little something I spent a couple hours on today from scrap laying around the shop.. why we can't already buy one tapered is beyond me, of course since I don't have one of the track bars laying around that are hitting, I couldn't put one on to see if it wouldn't just hit the differential in a different place..
it's a weld on bracket that'll move any after market track bar designed to bolt in the factory mount.. it'll also relocate jks jj's and the hiems RE uses... i started out going after a bolt on, then I realized bolting on what I stated to make was interfering with the sway bar, I tapered the the hole that's now relocated forward 2", the other hole bolts to the factory mounting surface with a 5/8" bolt, or a tapered stud, like nth degree uses, could be put in to eliminate the need to drill the factory bracket. I was temped to reinstall my factory track bar just for kicks, it's not something I need tho and the pics have one of the bent ends in it from my rancho track bar.... ![]() ![]() ![]() ![]() I think the Ideal bracket would be verticle and mount the tre horizontally, that wouldn't work so well for a jks bar at all tho.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable HighLine Hood Jeepers TJ Adjustable Track bars DIY highline fenders.... 34-37's under 0"-2.5" lifts shock length, bumpstop extension, tire size chart click here DIY shock shifters, more uptravel/better ride 2011 E-350 4x4 Van conversion 2006 Rubicon Unlimited ASE Certified Master Tech/Fabricator In need of work... 11/2/11 |
#77 | ||||
I'll note i also bent the rear lower corner of the psg side front fender at the joint with the flare. I have to admit, i'm not sure how, but one day i looked and it was bent. Not sure if there was a rock or stick that got involved... Slightly off topic, but i kept the stock control arms and carry a spare. I couldn't justify the price of aftermarket control arms of stock lenth since many designs would actually limit overall flex and add more stress to the frame mounts. I have chewed up stock control arms though and would like the durability of aftermarket ones without sacrificing bushing flex and the flex of stock stamped steel. I think some people lose some flex / or add a large amount of stress to frame mounts because the aftermarket ones are too rigid unless they have a flex joint. Also, if you don't set up your spherical ball joint track bar with the correct relaxed position that will also limit flex. It may seem like I'm slightly contradicting myself since i previously said i'd sacrafice the theoretical flex of longer shocks (CA and TB bind come into play) but i like to do as much as possible for any given design change. The flex on the drivers side and passenger side is slightly different due to track bar bind, and max uptravel is slightly effected by bind or shock length limiting down travel. Although a reinforced track bar frame mount would be nice since i think the stock one flexes too much, it's not everybodies top priority. I dont' like the idea of moving that location and effecting the drop pitman arm. I think that this contact can be designed out by someone competent with a tube bender who has access too and actually cares about lower lift height jeeps and looking at the issue. A bracket that reinforces the stock track bar frame mount but doesn't move the bolt hole would be optimum to me. It would be optional and minimizes installation error. Keep up the good work mudb8, maybe some mfg will regonize the problem. -Brent
- 06 LJ Rubicon 34" LTB's / 33" MTZs, OME Springs/Shocks, RE FTB, JKS RTB & 1.25BL, Brown Dog MML, Fabtech F Bump, Warn M8000 on AtoZ plate, ORF R Bumper & Rack, AR CAI, Banks Catback, Hi-Lift, Midland 75-822, Dual MF1050 Comp, Clayton Skids, Kilby Gas Skid - 94 Firebird Formula, 02 Softail Deuce, 86 GSXR750 - RIP 97 TJ, 83 CJ7, 87 TType |
#78 | |
nth degree, full traction, and pro comp all have units that keep the factory location and are braced, they also lower the track bar tho and still need the bumpstops associated with the longer shocks for the height.. I think jks comes the closest to geting the bend right, i'm not so sure the guys with jks rubbing issues, besides on aftermarket covers, are from improper axle centering even though they have an adjustable.. I've seen a few d30 covers that were only rubbing on the left side low spot of the cover. the straight bars just hang to low. ones that are hitting with 2" stops are gauranteed to hit off road on 4"+ lifts also with a good pot hole even though they never see enough compression during daily driving.
#79 | |
It was hitting hard (baja-style in the dunes ) and it only scratched the paint though, didn't bend it at all.
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA |
#80 | |
anyhow... here's some more info I just got from mr. blaine.... anyone have a new currie bar they are willing to post pics of?
#81 |
I just replaced my old JKS Bar with this new HD version. I don't have pics, but this bar will clear. It has a slightly larger bend, and it uses a 5/8 bolt on the frame side.
#82 | |
The JKS bar i have and hits my DANA30 up front is the latest one, # OGS126 ![]() |
#83 | |
currie has apparently started making a new version of track bars. they have been using jks..
#84 |
ive been reading through here and haven't seen anything about stock trackbar/aftermarket diff cover interference. i have a 2" lift with stock trackbar and want to get a riddler cover, will the trackbar hit it?
#85 | |||
yep, at least two reports, and here's a pic.. Quote:
#86 |
both of those guys were at stock height, wouldnt make a difference? the other things i was looking at was the warn half height skid and the superlift ring which is real similar to the old psc rings...you think either of those would work? sorry not trying to threadjack but seemed like a good place to ask this...
#87 | |
this is a good place for the q... I'm quite sure the warn half skid clears.. I just had one come in and didn't notice any rubbing altough it had a re1600 track bar, there's a couple on the shelf, I guess I should check it out closer..
#88 |
my front shocks are 22.75" fully extended...skyjacker H7016. my bumpstops are stock. i'm not sure how heavy duty the warn skid is, plus ive heard they pack full of mud between the skid and diff cover. they cost almost as much as the riddler or the superlift rock rings so it seemed like a no brainer, but if things wont play nicely together i guess i'll have to reconsider.
#89 | |
I like em, and ya, they can pack full of mud and cost about 80 bucks if memory serves..
#90 |
Any more info on the NEW Currie HD trac-bar? Any pics of it installed? Or did I just miss it already posted in this tread?
-Steve- 2004 TJ Rubicon OME HD springs - OME shocks - RE front/rear adjustable Superflex LCAs - Rusty's adjustable front UCAs - Full Traction rear tri-link conversion - Rusty's quick disconnects - JKS 1.25" BL - JKS 1" MML - Nth diff skid - Iron Rock Off Road HD tie-rod - Warn M8000 - Tom Wood's rear CV shaft - Rokmen high clearance belly skid - Rokmen Mercenary Sliders - Rokmen engine/tranny skid - Rokmen steering box skid - Rokmen Mercenary front bumper RIP: 2004 WJ Overland: 5.5" with front/rear long arms, sliders, skids, 32" Cooper STT's and wheeled it like it wasn't my DD. 2 motors, 2 trannies, 150k miles before I parked it. Jeeps Going Wild |
| Tags |
| tj, track bar |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
