tj front adjustable track bars for 0-3.5", does yours hit or fit? - Page 49 - JeepForum.com
post #721 of 1785 Old 11-07-2010, 12:44 AM
EricsGreen98Tj
Ok Mud you are the man to ask it seems. I just installed a 1.25" Zone BL,1" Brown Dog MML, and am goin to be puttin a Zone 3" suspension kit with 33/10.50 BFG KM2's. what bump stop length and TB options do you suggest on a 98tj 2.5?
Also a regear is in order
Thanks I ask cause i want to do this right the first time cause my kids ride/wheel with me.
MEAN diesel BTW!!!
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk http://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
EricsGreen98Tj is offline
post #722 of 1785 Old 11-18-2010, 05:22 PM
Fargo
OK I just read through the entire 49 pages. (Not all at one time though).
From what I have read and understand, I have basically two ideas that I think could be made into production. Since I don't want to be drilling out my holes and the stock track bar seems to be the strongest, both ideas involve modifying the stock trac bar.
The first idea has been stated a couple of times already. To build this tracbar, you would cut the factory trac bars and machine them to use an adjustable sleeve. This keeps all factory mounting locations and gives you adjustability and at the same time will work with factory bumpstops and diff covers. You can find factory trac bars at Quadratech for $65. Original Replacement Parts 52007118 - Front Track Bar for 97-06 Jeep® Wrangler TJ & Unlimited & 91-01 Cherokee XJ - Quadratec It would seem to me that someone should be able to purchase these in bulk for a discount, cut them and sleeve them and be able to sell them for well under $150 and still make a profit.
My second idea is to forget about adjustability. We are all looking for a tracbar that accomadates a 2" lift. If I'm not mistaken 2" lifts are causing the axles to be offset by about 3/8" to 1/2". So all we need is a track bar that is 1/4" longer than factory. This trackbar could even be used with a 3" lift. Although some axles would still be off by a fraction.
As I've already pointed out, Quadratech is selling stock tracbars for $65. You know they are making a profit on these things. That means that someone is building the factory tracbars for about $30-$40. So if someone that owns a 4x4 shop/website wants to make a profit on a low cost trac bar for a 2" lift the there is a simple 3 step solution.
1) Find out who is building the $65 tracbars at quadratec
2) Have them build a few hundred to your specs (Same as OEM but 1/4" longer)
3) Sell them at your store.
It would seem to me that even ordering in a small quantity (say 200+/-) this company should be able to build a tracbar to OEM specs but 1/4" longer. This would probably be the strongest bar out there since there are no weak joints to flex or break, and it would likely be the cheapest.
I really think a solid tracbar designed for a 2" lift would be a reasonable compromise. Especially if people could pick them up for around $100. Everybody with a 2" BB would be all over these things. So would those with 2" LCG builds. Someone like MudB8 or Savvy could sellthese things things all day long. If I had a 4x4 shop, I would seriously look into outsourcing the production of a solid tracbar for a 2" lift. Sure adjustability is nice. But I would rather have strength at a good price. I could deal with being off 1/8"-1/4" and I think with the right length solid bar, that is all anyone with a 2-2.5" lift would be off. Just something to think about.
6spd manual
LJ Owners Group member #110
Fargo is offline
post #723 of 1785 Old 11-18-2010, 05:43 PM
Gary2
Wouldn't hurt to have the TRE of the bar angled slightly so it is at the same angle it was before being lifted that way the force exerted on it will be more horizontal which would make the end last longer and while they are at it they could add the 1/4" of added length right there and kill 2 birds with one stone. I had noticed in the past that my Dodge trucks OE track bar would die as soon as the truck was lifted a little which told me the TRE didn't like any angle and that bar looked like a larger version of what a TJ uses.
Gary2 is offline
post #724 of 1785 Old 11-18-2010, 08:12 PM Thread Starter
mudb8
want it rite or rite now?
mudb8's Avatar
one of the things I do to the stock track bars is rebend them which involves stretching it out and angling the TRE, problem with that is guys that are running over 9" travel shocks still have a binding problem from the straight bar at the Axle mount.....
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #725 of 1785 Old 11-18-2010, 11:31 PM
bige2533
I think you can get the Super Lift adjustable that fits 2" to 4" for around $140.
bige2533 is offline
post #726 of 1785 Old 11-19-2010, 04:22 PM
Fargo
Yeah, but what good is it if it hits with stock bumpstops? I'd rather run my stock bar. The point of my post wasn't to get mudb8 to build us all cheap track bars. There are plenty of cheap track bars out there. The point of my post was to give Mudb8 another idea on how he might be able to solve the rubbing issue and at the same time produce a track bar for all of us that works and is profitable for him to make/sell. My priority is a tracbar that works and does not hit the diff cover. I will to spend the going rate for a QUALITY tracbar if it works properly. But I don't want to spend $200 for one that rubs. Infact I don't want to spend $50 for one that rubs. If it rubs its no good in my opinion. I'll stick with factory until a suitable tracbar is built. Whether its adjustable or fixed, I don't really care. Just get me in the ballpark. I can live with being off a little. Besides if its a fixed bar I can always add a spacer to bring my Jeep up to the proper height for the fixed trac bar to work. Or I could add a winch if I am sitting too high.
6spd manual
Fargo is offline
post #727 of 1785 Old 11-23-2010, 05:03 PM
RedTeej
I have a '00 TJ Sport, with RC 2.5" coils all around with 1" spacers up front giving a total of 3.5" of lift up front. Just tonight I disco'd my sway bar and jacked up the front driver side to see if my trackbar hit (Rough country adjustable, for lifts 0-3.5") an it does not hit the stock diff cover. It began coming close, but hit the stock bumpstops before it could make any contact.
OlllllllO
RedTeej is offline
post #728 of 1785 Old 11-23-2010, 05:13 PM
-dirt-
Did you compress the jounce bumpers fully until the metal cup contacted the axle pad?
Also, does this TB use the small drop bracket on the frame end?
-dirt- is offline
post #729 of 1785 Old 11-23-2010, 05:14 PM
EricsGreen98Tj
The point is to see if the tracbar hits when both the front springs are compressed. Like when you hit a speed bump or something. Most wont hit with only one side compressed, you gotta do both at once or take the springs out and check.
post #730 of 1785 Old 11-23-2010, 05:37 PM
Gary2
If any one would like that same model bar I have one with maybe 400 miles on it . It does have a bracket that only provides a mount for a bushing instead of the OE TRE, not anything that requires a DPA liketheir 4" and higher Tbar which does require a DPA . The frame mount moves the bar forward of the OE mount and the bar has a curve to it which should clear the cover .
Gary2 is offline
post #731 of 1785 Old 11-23-2010, 06:05 PM
EricsGreen98Tj
Why aren't you using it then, if "in theory" it don't hit? reason i ask is that i was thinkin of installin this same tracbar when i put my zone 3" suspension lift on. I was also gonna put 3/4" spacers in the front.
Just curious
post #732 of 1785 Old 11-23-2010, 06:05 PM
RedTeej
Ok, I'll check that. I'm intrigued with all of this track bar talk. I'm in the process of moving up to 33's, and getting the TJ to be able to handle a cross-country trip to California for a few months to visit a buddy, and to be able to handle some of the wheeling that can be found out there. Trying to build a sort of expedition/long range wheeler, and I'm doing a ton of research on this stuff. My RC 2.2 shocks just aren't cutting it, so I'm looking at switching to OME shocks, unless I find my trackbar does indeed hit the diff cover, in which case I may actually end up going with another higher kit. A trackbar failure 2,000 miles from home with my girlfriend in the front seat is the last thing I want to have happen on my trip. I'm thinking about going out and renting a spring compressor now to do this right... either that or having a bunch of people stand on my bumper tonight. I'll get back to you guys.
OlllllllO
RedTeej is offline
post #733 of 1785 Old 11-23-2010, 06:07 PM
EricsGreen98Tj
cool that's the bar i want to run too, so any feedback will be great!!!!
post #734 of 1785 Old 11-23-2010, 06:34 PM
Gary2
Just curious
I have a JKS that is fine for me so far. I only use my jeep for fishing nothing that really twists up the suspension like the guys on rocks do .
Gary2 is offline
post #735 of 1785 Old 11-23-2010, 06:49 PM
-dirt-
Couldn't a seam or bump in the road that compresses both springs cause the same scenario? In fact I think it would be worse since it would be at speed instead of slowly crawling...
-dirt- is offline
tj , track bar
how important are front and rear adjustable track bars? travk1234 TJ Wrangler Technical Forum 5 09-02-2009 08:01 AM
Adjustable track bars Aiden80013 TJ Wrangler Technical Forum 8 05-17-2009 03:07 PM
adjustable track bars jr1966 TJ Wrangler Technical Forum 2 03-17-2008 04:15 AM
RE Adjustable Front Track Bar and a 2" BB... ? thejafe TJ Wrangler Technical Forum 4 01-01-2006 10:25 AM
Best Adjustable track bars kaybone TJ Wrangler Technical Forum 2 02-24-2005 06:15 PM
