tj front adjustable track bars for 0-3.5", does yours hit or fit? - Page 43 - JeepForum.com
post #631 of 1785 Old 07-15-2010, 03:10 AM
anymanusa
I guess i need a new rear track bar since my 3.5" lift has caused my drivers side rear tire to scrape against my spring perch on occasion.
anymanusa is offline
post #632 of 1785 Old 07-15-2010, 03:30 AM
chmo
wow ... your axle must be off center a lot!
If you have a rear TB relocation bracket and stock TB in the rear you should be fine with around 3" lift,
BUT if you have a fresh RE 3.5 lift ... well hehehe ... their springs give you quite more than 3.5 AT THE BEGINNING (around 4" point something) ... they might settle down to ~3.5 after a while.
And/Or you are running wheels with close to stock back spacing ... (5.5")
wider tires require less backspacing ... the usual range is 4.5" to 3.65".
so : an adjustable in the rear gives you some flexibility over your lift life cycle
chmo is offline
post #633 of 1785 Old 07-16-2010, 09:34 PM
anymanusa
well i have 33/12.5" on stock 16" Rubi wheels, and there is about 1/2" clearance on the drivers side, and 1.25" or so on the pass. side between the coil spring perch and the tire. I can see evidence of the tire rubbing on the drivers side on occasion. i'm not sure what I'll do to fix it yet.
post #634 of 1785 Old 07-17-2010, 01:43 AM Thread Starter
mudb8
want it rite or rite now?
mudb8's Avatar
the adjustable isn't exactly a good idea in the rear without a relocation bracket and shocks longer than 8.5" travel.... at full droop they bind on the stock bracket and can cause failure, like ripping it off the axle.
RE adjustable....
jks adjustable
that's what happens using stock backspacing with 11.5" wide tires and no rear track bar relocation.... or wheel spacer, which is also an option but is far more expensive than a 35 dollar track bar relocation bracket.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #635 of 1785 Old 07-17-2010, 02:00 AM
rs4race
I just saw an adjustable track bar on a 2.5" ome lift with the n66 shocks, no bumpstop extensions, stock control arms, correct pinion angle, d30 stock diff cover, and centered axle not hit the trackbar on the diff cover. Im fairly certain it went to full bump with both front tires at the same time too, Theres not a hint of any contact on the diff cover, axle where bushing might hit, or the track bar.
It's a jks adjustable track bar, and it appears to be bent foreward to where it has plenty of clearance from the diff under full bump. I saw other pictures of the same or similar jks trackbar hitting in this thread, but this one doesnt. This leads me to either one of the two following conclusions reguarding the jks trackbars that were shown hitting in this thread. Either A: the suspension in the pictures with the trackbars hitting wasnt aligned properly, this particular rigs mounts might have been off from the factory (I have heard of jeep not being precise with the placement of mounts when building) or a combination of both.
So sounds like there is definatly hope for an adjustable track bar that works for under 3" of lift.
My Build
http://www.jeepforum.com/forum/f22/rs4races-build-957569/
rs4race is offline
post #636 of 1785 Old 07-17-2010, 02:21 AM
chmo
cool ... but do I want to "find" out ? Honestly : NO
btw I am wondering how the front pinion angle is parallel to the front TC OUTPUT yoke with the stock control arms with front sitting 2.5" higher than stock ... thats why I put adjustable front lowers to push my front diff a bit forward to have the front pinion angle LOWERD again.
Which of course increases the risk of hitting aftermarket TBs
(A slightly extended front wheel base is not bad at all with lifted Jeeps ... noticeably less harsh driving over small obstacles! Ahh ... the caster is then better as a nice side effect )
chmo is offline
post #637 of 1785 Old 07-17-2010, 02:35 AM
chmo
oops ... somehow I was assuming he was using the TB relocation bracket already ... I really read the whole thread and saw those great pics posted before ... thanks a lot mudb8!
The knowledge and experience coming from a handful senior members in this forum make it so valuable ... how many bellies of different TJ builds did you see i your life?
I only saw my TJs belly close enough ...
I compensated the lack of first hand "experience" by thorough fully reading!
(many threads are worth it from start to end!)
chmo is offline
post #638 of 1785 Old 07-17-2010, 09:31 AM
JCWJEEP
2010 JK Wrangler
Wow, Mudb8, that signature is a post unto itself. Reading your last post I got to the sig and kept going, the whole time wondering how it was relevant to the topic.
And you just won't stop scaring me about these adjustable track bars. Luckily my 8.8's bracket is open at the top.
JC Whitney Jeep Team
JCWJEEP is offline
post #639 of 1785 Old 07-17-2010, 11:15 AM
rs4race
Parallel? The diff yoke should be in line with the driveshaft. It's a cv shaft...
I'm not sure what you mean by parallel, but the stock arms with the cam bolts work just fine for correcting pinion angle...
My Build
rs4race is offline
post #640 of 1785 Old 07-17-2010, 05:07 PM
chmo
you are right ...
I dunno what I was thinking ... actually my front pinion angle is pointing towards the TC output yoke ... parallel to the main shaft ... maybe barely noticeable below but for sure not higher. The discussion caster versus pinion angle must have confused me at some points ... I mean I might have read somewhere that the TJ front DS is not really CV type or so ...
chmo is offline
post #641 of 1785 Old 07-18-2010, 12:41 PM Thread Starter
mudb8
mudb8's Avatar
caster angle is reduced the more in line the the d-shaft is along with the more likelyhood of having the diff crash into/scrape the Track bar at full stuff.
basicly, 4* of caster has a near perfect driveline angle for a 3" lift but has the top of the diff in a bad position for a short lift and short or no bumpstop extension, not to mention makes a squirley driving TJ. 7* caster is still in a good position without vibes with a stock 03/up skid and has the top of the diff tilted inward and away from the track bar/brackets...
prime example from the use of a Fabtec front relocation bracket....
mudb8 is offline
post #642 of 1785 Old 07-19-2010, 01:37 PM
john NC
john NC's Avatar
wow, great thread mudb8
i'm so glad i put off installing the JKS OGS126 in my tj. i'm just going to redrill the mount and have it welded
any idea if it will be fine for an XJ with 3" of lift and trimmed fenders? the xj won't see any trails just beach/dunes and roads. i'm going to extend the bumpstops 1" and see if they clear and add more if needed. building the jeep for my dad so i want the axle to be centered. it may get 31x10.5s and/or new wheels with less backspacing depending on the budget
it still needs to be cleaned up and repainted but i was just trying to get an idea of the ride height, i may trim some more as well. it's quite fun
john NC is offline
post #643 of 1785 Old 07-19-2010, 10:15 PM Thread Starter
mudb8
mudb8's Avatar
the xj will still need to be bumpstoped, first of all, according to the shock length.... which means the 2" extensions will make way for the JKS track bar.
Nothin wrong with a little cuttin! but that's another topic for another thread.....
mudb8 is offline
post #644 of 1785 Old 07-22-2010, 03:55 PM
john NC
john NC's Avatar
thanks man, may just redrill the mount on that one too
john NC is offline
post #645 of 1785 Old 07-23-2010, 08:25 AM
Border Dave
Got Sand?
Border Dave's Avatar
Will the stock trackbar accommodate the extra flex (and droop) you'll get with a 2 or 3 inch lift when using that drop bracket?
Border Dave is offline
tj , track bar
how important are front and rear adjustable track bars? travk1234 TJ Wrangler Technical Forum 5 09-02-2009 08:01 AM
Adjustable track bars Aiden80013 TJ Wrangler Technical Forum 8 05-17-2009 03:07 PM
adjustable track bars jr1966 TJ Wrangler Technical Forum 2 03-17-2008 04:15 AM
RE Adjustable Front Track Bar and a 2" BB... ? thejafe TJ Wrangler Technical Forum 4 01-01-2006 10:25 AM
Best Adjustable track bars kaybone TJ Wrangler Technical Forum 2 02-24-2005 06:15 PM
