tj front adjustable track bars for 0-3.5", does yours hit or fit? - Page 17 - JeepForum.com
post #241 of 1784 Old 06-19-2009, 08:17 PM
johnny9
someone on another thread sayed this was spam..i dont need to click on it..
they didnt fill out there info to be on this forum either,weired they even get thru..
johnny9 is offline
post #242 of 1784 Old 06-19-2009, 08:59 PM
abnormal
Platinum Member
abnormal's Avatar
Begone you garbage!
abnormal is offline
post #243 of 1784 Old 06-20-2009, 04:09 PM
classicinjectio
Don't know if this has been asked but can you put the JKS on a tube bender and tweak it to fit better?
classicinjectio is offline
post #244 of 1784 Old 06-20-2009, 04:42 PM
CB3
If I understood what Mud told me (in a PM I think), the JKS front trackbar that I have now, is the same as the old Currie HD trackbar that Johnny and someone else in this thread (forgot who) already has, except for the frame mount being offset and the size of the frame mount bolt (old trackbar has 9/16 frame mount bolt while new trackbar will have 5/8 bolt).
It is the same trackbar with same bend and shape, but the new Currie HD has the frame mount end offset and uses a slightly bigger mounting bolt at the frame end. Otherwise than that it's the same trackbar with the same bend and shape. If I correctly understood what Mud told me.
The old version (has bend/curve, but not offset joint) has been used a lot in Jeepspeed. Currie tech said the bends act as a shock absorber to ease the impacts at high speed, which is easier on driver and helps trackbar and other steering and suspension parts last longer, especially their mounting brackets and mounting hardware last longer.
Currie said that straight trackbars are to stiff and offer no shock absorbtion, which causes harsher ride and in Jeepspeed tears/breaks mounting brackets for trackbars and other steering and suspension components.
Also, as we (in this thread) know, straight trackbars don't offer as much diff cover clearance. A bent/rounded trackbar offers more diff clearance. The offset joint increases clearance by another 1/2", I've read.
So the JKS bar and old Currie HD bar are (apparently) one and the same with each other (perfected in Jeepspeed racing). The only difference between the JKS trackbar and old Currie HD trackbar vs the new Currie HD trackbar is the offset framemount end and larger framemount bolt. If I understand the topic correctly.
Do I understand correctly Mud?
CB3 is offline
post #245 of 1784 Old 06-20-2009, 05:02 PM
CB3
Why would you want to risk that? It's probably fine unmodified, and if not, the new Currie HD front trackbar only costs $225 according to their website. Why risk your life to save $225? You wouldn't save that much anyway because your time has value.
Granted, I'm not an expert and I'm learning along with you and others from Mud and others, but my common sense tells me you shouldn't be bending an aftermarket trackbar because it's a hollow tube (that can collapse). It's not a solid bar like the stock trackbar.
That's my common sense. Now of course, the experts will say if I'm right or wrong and that's fine. I can learn more then.
Also, if trackbar to differential clearance is a concern, you can get a high clearance aftermarket cover that's plenty tough. I listed high clearance aftermarket diff covers in post 220 of this thread.
CB3 is offline
post #246 of 1784 Old 06-20-2009, 06:18 PM
Kiwi
No, read my post 244 above. There is a big difference in the materials the new Currie HD track bar is made of.
Kiwi is offline
post #247 of 1784 Old 06-20-2009, 06:26 PM
CB3
Chromoly right? I forgot about that.
CB3 is offline
post #248 of 1784 Old 06-20-2009, 06:34 PM
classicinjectio
I JKS 126 bar to go with a OME/Bilstein 2.5 set up and thought that bending the bar would be easier then cutting and rewelding if my bar hits. And bending tool should make easy work of it has anybody attempted this or is it just better to ditch it if it hits.
post #249 of 1784 Old 06-20-2009, 06:58 PM
Kiwi
And the wall thickness. It's 1/4" wall compared to the thinner wall of the regular bar.
Kiwi is offline
post #250 of 1784 Old 06-20-2009, 07:12 PM
SuperWade2
More Money than Brains
SuperWade2's Avatar
Now if they would just hurry up and get em ready to sell to us!
I'm going to replace my Rubicon Express TeacBar with the Currie HD one once they will sell me one.
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #251 of 1784 Old 06-20-2009, 07:16 PM
CB3
Hmm. Well then, I guess with chromoly, a thicker tube wall, and a thicker mounting bolt, it's hella stronger. Plus it offers 1/2" more diff cover clearance.
That new trackbar is even sweeter than I realized.
Thanks for helping me better understand the differences.
CB3 is offline
post #252 of 1784 Old 06-20-2009, 07:17 PM
CB3
I called Curie yesterday and asked. I was told 2 weeks from now. I guess that means first week of July.
CB3 is offline
post #253 of 1784 Old 06-20-2009, 07:27 PM
SuperWade2
SuperWade2's Avatar
Approx. the same timeframe that the guys @ Currie told me a week or two ago...
2017 WK2 Overland
post #254 of 1784 Old 06-20-2009, 09:52 PM Thread Starter
mudb8
want it rite or rite now?
mudb8's Avatar
the hd tb that's listed is the same shape, but is thicker and has a 5/8" jj which is also centered instead of having the offset cope that you're waiting for.
doesn't scare me, I've bent many just not jks yet.
yep...
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #255 of 1784 Old 06-25-2009, 02:13 PM
CB3
I suppose that every two weeks they'll tell us "two weeks". Manyana, manyana. How's that song go?
CB3 is offline
tj , track bar
how important are front and rear adjustable track bars? travk1234 TJ Wrangler Technical Forum 5 09-02-2009 08:01 AM
Adjustable track bars Aiden80013 TJ Wrangler Technical Forum 8 05-17-2009 03:07 PM
adjustable track bars jr1966 TJ Wrangler Technical Forum 2 03-17-2008 04:15 AM
RE Adjustable Front Track Bar and a 2" BB... ? thejafe TJ Wrangler Technical Forum 4 01-01-2006 10:25 AM
Best Adjustable track bars kaybone TJ Wrangler Technical Forum 2 02-24-2005 06:15 PM
