tj front adjustable track bars for 0-3.5", does yours hit or fit? - Page 112 - JeepForum.com
post #1666 of 1785 Old 02-16-2014, 12:13 AM Thread Starter
mudb8
want it rite or rite now?
mudb8's Avatar
Originally Posted by dustymc View Post
It fits!
[*]RE 3.5" lift springs, RE adjustable "superflex" arms
[*8" total bumpstop, measured between spring pads at full stuff - I have no idea what stock bumpstops look like[*]Currie/Savvy CurrectLync steering[*]D30, Solid cover[*]Metalcloak trackbar[*]I had to grind one "fin" off the diff cover, and take a very thin slice off the top edge of the block that the fill plug screws into.[*]Trackbar just touches the diff cover at full stuff. Maybe 1/16" clearance between the steering stabilizer bracket bolts and the trackbar. No problem anywhere else, although I did have to fiddle with the draglink adjuster[*]https://imgur.com/a/rbKvS[*]Yea, I know, mad photography skills. I'm available for weddings....
Fancy...
Looks like mine has more clearance with 1.5" bumpstop requirements than the mc with your 2" stops... It is a takeoff, unknown brand, i cut off the cold cut axle end and rotated it a bit and one rib.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #1667 of 1785 Old 03-16-2014, 08:22 PM Thread Starter
mudb8
mudb8's Avatar
Recycled Ram 3500 to tj track bar.
I cut off the bad tre, drilled and taped it out for a 3/4" heim. My intended joint was a 1" shank, narrow 2" Johnny joint but i couldnt seem to find my 1" tap.
It got put in the bender for bracket clearance and to level the angle for the frame side. Measured and shortened for the current lift height. It will get a tj cleavite replacement bushing in place of the 14mm dodge bushing. The hole isnt egged out, there is no reason for drilling it out anyway as the 10mm bolt is sufficient due to the clamping force it is capable of.
mudb8 is offline
post #1668 of 1785 Old 03-16-2014, 08:39 PM
Imped
Imped's Avatar
I dig it. But it would take less effort and time to drill the axle bracket holes out and slap a new bolt in vs. installing a new Clevite bushing. Cheaper, as well.
OlllllllO
IndyORV
Imped is offline
post #1669 of 1785 Old 03-16-2014, 09:39 PM Thread Starter
mudb8
mudb8's Avatar
Besides a 14mm/ 9/16" drill bit, 14x70mm bolt, prevaling torque nut, washers and cutting part of the bottom off the axle bracket to fit a 13/16"/21mm ( 7/8 if you cant get a shouldered nut), wrench in there to hold the nut, the moog k7252/ dodge clevite bushing doesnt flex as well as the tj bushing having a much smaller sleeve and the cold cut rings need to shaved to use them as a replacement. I refuse to install any polly bushing in there. A factory rear track bar bushing can be substituted, drilling out the hole to 12mm. I havent yet come up with a part number/application for one yet. I have reused them before tho, it's not always easy to get them out not harming them.
mudb8 is offline
post #1670 of 1785 Old 07-14-2014, 10:31 AM
wildrnesxperie
Hello JeepForum! First time poster, had my LJ for 10 years from new. Always loved it but only now looking to modify a bit. Was looking at the Zone 4.25" lift. Will a Metalcloak adjustable front track bar have any clearance issues on the diff or should I just drill the brackets and use stock? Thanks!
wildrnesxperie is offline
post #1671 of 1785 Old 07-16-2014, 03:11 PM
ex m38a1er
Maybe someone has already tried it...
2.5'' OME+1.25''BL for my KM2 33s...and a Rockcrusher front diff cover.
I have to change my TB bushings (both ends) and thinking...what the...why not buy a new adjustable one...
Am i opening a can of worms?
" H TAN , H EΠI TAΣ"
'WHO DARES,WINS'
ex m38a1er is offline
post #1672 of 1785 Old 07-16-2014, 03:16 PM
SilverTJMike
Leave it be, just go with stock. Yes its a rather large can.
SilverTJMike is offline
post #1673 of 1785 Old 07-16-2014, 10:08 PM
wildrnesxperie
Any comments on the Metalcloak TB? Or should I just stick with stock? Would I also be opening a can of worms adding an adjustable TB with the Zone 4.25"?
post #1674 of 1785 Old 07-17-2014, 05:13 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
the Metalcloak will be fine with 3" of lift. So will the JKS #126, if you use a V8 ZJ tie-rod and run at least 1" front bumpstop extension. Currie TJS/TJJ will work with 2" bumpstop extension, IIRC.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #1675 of 1785 Old 07-17-2014, 08:15 AM
rda616
IIRC the shocks sold with the 4.25" zone lift required 1.5" front and something like 2.5" rear bumpstop extension. It's doubtful you will have any issue with the metalcloak track bar.
rda616 is offline
post #1676 of 1785 Old 07-18-2014, 11:17 AM
wildrnesxperie
Okay cool thanks. The guy on the previous page had a MC tb and he had to grind parts of the diff cover off. Will that be in store for me with the 3" suspension lift and MC tb?
post #1677 of 1785 Old 07-18-2014, 11:22 AM
Unlimited04
if you buy some giant fat diff cover, yes. you'll have major clearance problems.
if you stick with the stock diff cover you'll be fine.
Useful Write-Ups:
Funny:
post #1678 of 1785 Old 07-19-2014, 10:01 AM
wildrnesxperie
Ahh! Good to know thanks!
post #1679 of 1785 Old 07-19-2014, 07:37 PM
m44
So I have 4" of lift and need a new diff cover I'm running currie steering and trackbar my buddy has a arb cover and it rubs. Is the Barnett still the best option?
2003 Tj sport daily driver with a bunch of mods
1998 wrangler rolled and being rebuilt with tons
m44 is offline
post #1680 of 1785 Old 07-19-2014, 07:51 PM
biffgnar
biffgnar's Avatar
Best option are axles that don't use diff covers. But if you do use diff covers, then yes . . Barnett.
biffgnar is offline
tj , track bar
how important are front and rear adjustable track bars? travk1234 TJ Wrangler Technical Forum 5 09-02-2009 08:01 AM
Adjustable track bars Aiden80013 TJ Wrangler Technical Forum 8 05-17-2009 03:07 PM
adjustable track bars jr1966 TJ Wrangler Technical Forum 2 03-17-2008 04:15 AM
RE Adjustable Front Track Bar and a 2" BB... ? thejafe TJ Wrangler Technical Forum 4 01-01-2006 10:25 AM
Best Adjustable track bars kaybone TJ Wrangler Technical Forum 2 02-24-2005 06:15 PM
