tj front adjustable track bars for 0-3.5", does yours hit or fit? - Page 111 - JeepForum.com
post #1651 of 1785 Old 11-19-2013, 08:26 AM
BYuen
BYuen's Avatar
Originally Posted by Border Dave
What's wrong with RE lowers?
The hour glass shaped bushings. Wallow out fast after 5-10k miles.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #1652 of 1785 Old 11-20-2013, 12:16 AM
Border Dave
Got Sand?
Border Dave's Avatar
I haven't had any problems with my rear lower RE arms. They've been on there for about 30,000 miles. Maybe it happens to people who don't grease them?
Border Dave is offline
post #1653 of 1785 Old 11-20-2013, 12:21 AM
chmo
sorry ... off topic
but your first version made me smile
(coward ... for post editing it so boringly clean )
"The more I know, the more I realize how much I don't know"
chmo is offline
post #1654 of 1785 Old 11-20-2013, 04:16 AM
rda616
It's been a problem since re started making the hourglass bushings. They have tried half a dozen times or so to fix it and failed. The hourglass bushing doesn't take grease it's the rubber bushing side. The super joint on the other end will also eventually need tightened, or rebuilt, but they are less problematic than the bushing.
Being in the rear you may notice it less if you were in need of hourglass bushings. If you take an arm off at a time to inspect them it's likely they will have slop in them.
rda616 is offline
post #1655 of 1785 Old 11-20-2013, 06:44 PM
Border Dave
Got Sand?
LOL You caught me! I thought I changed it quick enough that nobody saw my smarta$$ reply.
post #1656 of 1785 Old 11-20-2013, 08:38 PM Thread Starter
mudb8
want it rite or rite now?
mudb8's Avatar
I take them apart and grease them..
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #1657 of 1785 Old 11-21-2013, 04:16 AM
rda616
Yep, and let's not forget the special tool you need to buy from re to do that as well. A small one for the uppers and large for lowers. Those maintenance free duroflex bushings are sounding better to me all the time.
rda616 is offline
post #1658 of 1785 Old 11-21-2013, 08:44 AM Thread Starter
mudb8
mudb8's Avatar
Meaning you dont maintain them. Just replace them.
mudb8 is offline
post #1659 of 1785 Old 11-21-2013, 09:26 AM
rda616
Which is what you will be doing with those hard re races eventually. And these replaceable mc bushings seem to be holding up quite well vs the hourglass bushings re uses that do not.
rda616 is offline
post #1660 of 1785 Old 11-21-2013, 09:57 AM Thread Starter
mudb8
mudb8's Avatar
Do not clutter my thread with ignorance.
mudb8 is offline
post #1661 of 1785 Old 11-21-2013, 10:05 AM
rda616
I don't see how fact translates to ignorance. Having all 8 re control arms on my rig now I know how poorly they have held up.
rda616 is offline
post #1662 of 1785 Old 11-21-2013, 10:12 AM Thread Starter
mudb8
mudb8's Avatar
There are no facts to support how a wj ca bushing is better than a p.o.s. re bushing. Start your own thread if you want to advertise mc's unproven product and misinformed ideas. It has nothing to do with track bars. Admin has been informed...
mudb8 is offline
post #1663 of 1785 Old 11-21-2013, 12:05 PM
The_Dealer
2003 KJ Liberty
I used a punch for the lowers. For the uppers I used a chevy/ford wheel bearing socket. Prongs fit perfectly
My build
http://www.jeepforum.com/forum/f22/the_dealers-soft-core-build-1476982/
The_Dealer is offline
post #1664 of 1785 Old 11-21-2013, 02:53 PM
PortlandCJ76
PortlandCJ76 is offline
post #1665 of 1785 Old 02-15-2014, 11:33 PM
dustymc
It fits!
  • RE 3.5" lift springs, RE adjustable "superflex" arms
    [*8" total bumpstop, measured between spring pads at full stuff - I have no idea what stock bumpstops look like
  • Currie/Savvy CurrectLync steering
  • D30, Solid cover
  • Metalcloak trackbar
  • I had to grind one "fin" off the diff cover, and take a very thin slice off the top edge of the block that the fill plug screws into.
  • Trackbar just touches the diff cover at full stuff. Maybe 1/16" clearance between the steering stabilizer bracket bolts and the trackbar. No problem anywhere else, although I did have to fiddle with the draglink adjuster
  • https://imgur.com/a/rbKvS
  • Yea, I know, mad photography skills. I'm available for weddings....
dustymc is offline
tj , track bar
how important are front and rear adjustable track bars? travk1234 TJ Wrangler Technical Forum 5 09-02-2009 08:01 AM
Adjustable track bars Aiden80013 TJ Wrangler Technical Forum 8 05-17-2009 03:07 PM
adjustable track bars jr1966 TJ Wrangler Technical Forum 2 03-17-2008 04:15 AM
RE Adjustable Front Track Bar and a 2" BB... ? thejafe TJ Wrangler Technical Forum 4 01-01-2006 10:25 AM
Best Adjustable track bars kaybone TJ Wrangler Technical Forum 2 02-24-2005 06:15 PM
