tj front adjustable track bars for 0-3.5", does yours hit or fit? - Page 110 - JeepForum.com
post #1636 of 1785 Old 10-02-2013, 03:12 PM
CommonSense
Originally Posted by bobthetj03 View Post
I doubt you'll find any rubbing. Did you have any trouble centering the axle, ie TB too long?
Yeah its a tad long. I collapsed it as far as it can go and I'll tell you what...the front axle is more centered with this one than the factory TB w/ lift. Also I netted a total of 2 3/4" of suspension lift from the OME HD springs so that put it a bit closer in my favor. After new metal cloak TB install, I think its the passenger sticks out apx. 1/4". That to me is negligible.
CommonSense is offline
post #1637 of 1785 Old 10-02-2013, 03:24 PM
bobthetj03
1/4" out is livable. I netted the same as you (also HD springs), but after I added my winch and winch plate, it dropped me back down to 2.5". I have no clearance issues with my JKS front TB, so you should have miles of room!
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #1638 of 1785 Old 10-02-2013, 03:39 PM
CommonSense
Thanks! I think your right too. I did a good bit of rooting around on here before I pulled the trigger on the TB. I also have a winch and bumper on mine as well... But my winch is a puny 5,000 pounder (which makes me use a snatch block to be safe every darn time) and I hacked the bumper down a bit so its now flush with the frame rails...so probably less weight up front. I'll try to get some pics up of the TB and maybe more...
post #1639 of 1785 Old 10-02-2013, 11:30 PM Thread Starter
mudb8
want it rite or rite now?
mudb8's Avatar
Originally Posted by ArchStanton View Post
By your questions, I probably don't need adjustable control arms. But thanks anyway!
The jks make fine stock replacements. They are way ahead of tera's design with fine threads and sealed shafts. Tera also used small diameter hard polly bushing that had no flexibility. That is what caused mount failure. Jks use the same exact clevite bushing as stock arms. They do flex very well in reality.
I would use them without hesitation for mostly hwy useage up to 4" lifts with less than 10" travel shocks. I believe Youll never experience any failure or abnormal bushing wear provided the sway bar links stay connected.
Track bars, track bars......
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #1640 of 1785 Old 10-04-2013, 09:23 PM
CommonSense
WTF!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11 I'm sick of my attempts at uploading pics from my phone resulting in " your pic of 527kb exceeds the allowed 150kb limit"... NO pics = garbage. NO rubbing= GOOD.
post #1641 of 1785 Old 10-04-2013, 09:31 PM
BGClemson
How to post a pic
BGClemson is offline
post #1642 of 1785 Old 10-07-2013, 12:41 PM
CommonSense
I've been on that one before and just tried it now and still nothing!! I have the GCS Publishing app for this forum and searched for the Auto app but no luck. I PMed the guy who put together the "how to post a pic with your smartphone" so we shall see...
post #1643 of 1785 Old 10-07-2013, 12:50 PM
Imped
Imped's Avatar
Host before you post. It's not rocket science.
OlllllllO
IndyORV
Imped is offline
post #1644 of 1785 Old 10-07-2013, 01:20 PM
CommonSense
Whatever
post #1645 of 1785 Old 10-07-2013, 02:18 PM
JFcavedweller
my new generation rough country adjustable track rod with the thicker tubing self-destructed before it had a chance to bang on the differential. the bracket kept working loose and causing death wobble, then after I got that resolved the tube wallowed out at the threads. back to the stock rod for me
O|||||||O - '99 TJ
■|||||||■ - '97 ZJ
JFcavedweller is offline
post #1646 of 1785 Old 10-29-2013, 07:36 PM
Vic99TJ
So is there a definitive answer for a 3.25 lift and trac bars?
Vic99TJ is offline
post #1647 of 1785 Old 10-29-2013, 07:39 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Metalcloak, Currie TJS/TJJ or JKS #126. Which one depends on how much work you're willing to do, how much you want to drill out, how you tolerate heim vs JJ's, and how much bumpstop extension and tie-rod you're using.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #1648 of 1785 Old 11-15-2013, 12:54 AM
TigreJuapo05
my current setup up is OME 2.5inch HD springs and Bilstieen 5100's and im about to pick up JKS front trac bar, Rubi express adj. lca's and two inch bumpstops. as a solution to the death wobble. should be good. ill update soon
TigreJuapo05 is offline
post #1649 of 1785 Old 11-19-2013, 08:17 AM
rda616
Avoid the Rubicon Express lowers and buy a good set instead.
rda616 is offline
post #1650 of 1785 Old 11-19-2013, 09:13 AM
Border Dave
Got Sand?
Border Dave's Avatar
What's wrong with RE lowers?
Border Dave is offline
tj , track bar
how important are front and rear adjustable track bars? travk1234 TJ Wrangler Technical Forum 5 09-02-2009 09:01 AM
Adjustable track bars Aiden80013 TJ Wrangler Technical Forum 8 05-17-2009 04:07 PM
adjustable track bars jr1966 TJ Wrangler Technical Forum 2 03-17-2008 05:15 AM
RE Adjustable Front Track Bar and a 2" BB... ? thejafe TJ Wrangler Technical Forum 4 01-01-2006 11:25 AM
Best Adjustable track bars kaybone TJ Wrangler Technical Forum 2 02-24-2005 07:15 PM
