Quantcast tj front adjustable track bars for 0-3.5", does yours hit or fit? - Page 11 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > tj front adjustable track bars for 0-3.5", does yours hit or fit?
Old 06-02-2009, 08:42 AM   #151
redsoxski
Originally Posted by JESSETHELJ View Post
God Guys if your going to let your front track bar hit the Diff let it Hit the Diff lol Just like this.
There was another thread that talked about trackbars breaking from repeatedly hitting the diff cover. When that happens you're s**ewed! So letting them rub the cover like shown in your pic is fine but when there is less clearance and they hit with force, repeatedly, is when its not OK...
redsoxski is offline   Reply With Quote
Old 06-02-2009, 08:55 AM   #152
JESSETHELJ
I agree this was the first wheeling trip and that was the damage from it. Im gonna have to figure this out. Maybe a different Diff cover.
2004 LJ
1" JKS BL, 1" BMML, Rough country 3.25" lift with 2"puck up front
4.88 GEARS, D30 W/ AUSSIE LOCKER D44 33X1250X15
Currie Anti rock, Trail gear bumpers, Rokmen tummy tuck with Eng skid, Genright Rockers
Smitty Bult XRC 10k winch
JESSETHELJ is offline   Reply With Quote
Old 06-02-2009, 09:22 AM   #153
nriver
2011 JK Wrangler
IMHO, diff covers only make the problem worse. Unless you use one that only covers the bottom portion on the diff.
One of these days I will make my modifications to my trackbar and help provide a solution. When I get the time and gumption.
Why do I post here?
nriver is offline   Reply With Quote
Old 06-02-2009, 09:28 AM   #154
JESSETHELJ
Ill post some pics of a set up that i know works. You have to relocate the front track bar bracket. Ill post some pics when I get back home. Didnt want to do this till i got my 44 but oh well.
2004 LJ
Old 06-02-2009, 10:48 AM   #155
masterwacker
Originally Posted by mudb8 View Post
pics? please..
they actually don't hit while flexing, they hit under compression of both springs at the same time such as jumping or simply driving over a curb...
I will take pictures of it here shortly. I didn't notice any hitting with compressing springs at same time, but I will double check this too.
Paul
masterwacker is offline   Reply With Quote
Old 06-02-2009, 12:24 PM   #156
JESSETHELJ
Full spring compression of both springs like so...? Or like trying to Winch somone out of a mud hole?
2004 LJ
Old 06-02-2009, 12:43 PM   #157
rubidriver
rubidriver's Avatar
Originally Posted by jeep2008 View Post
Sorry but JKS sells a trackbar for 0-3.5'' lifts and warns nobody about anything!!I repeat that i have a 2.5'' OME with 0.25'' spacers up front and a dana30 with factory diff cover and it hits.So in my book JKS is to blame and they should at least come forward and post an apologie in this GREAT thread .
Im unaware of the 0-3.5", but I am aware of the 1-3" which is the OGS 126. JKS warns against the dana 30 with an aftermarket diff, so that means you have another issue. Have you lengthened your wheelbase via front adjustable control arms? How bout your caster, what is it?
2005 Black Rubicon - OME 933/942 - OME N66/N67 - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16 MTZ
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline   Reply With Quote
Old 06-02-2009, 08:25 PM   #158
mudb8
want it rite or rite now?
mudb8's Avatar
good luck with that... the jj end needs to coped and welded to the outside of the joint, otherwise, you need about 2" of bumpstops to prevent it from hitting...
this is one I made to fit the jks, RE, ft, and stock track bars.. it relocates the bar 2" forward, welds to the frame and bolts to the stock track bar mount..
currie is a good place to start.... unless you can fab up your own. or just re do the jj end of the jks..
setting proper caster actually tilts the differential pinion down and away from the front end components. in other words, the upper arms get shortened.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator
In need of work... 11/2/11
mudb8 is offline   Reply With Quote
Old 06-02-2009, 08:38 PM   #159
rubidriver
rubidriver's Avatar
I know, I just want to know what his caster is set at. Im thinking he might have addressed the caster as well as wheel base at the same time which would push that axle wwaaaay up there.
Old 06-02-2009, 08:38 PM   #160
nriver
2011 JK Wrangler
Thinking my FT frame side trackbar should be easily modified. Thinking I can cut off the existing bushing mount and install a new bushing mount forward. Then I can add a gusset to make sure it is strong. Not sure how far forward I am going to move it. Should be a easy project, I just need to pull the front end apart again to do it.
You can see their normal mount in the lower part of this picture.
Why do I post here?
Old 06-02-2009, 08:41 PM   #161
JESSETHELJ
I think that the main issue is the Axle mount is to low. its gonna take a few but ill post some pics of when its complete.
2004 LJ
Old 06-02-2009, 09:32 PM   #162
redsoxski
I've been talking with Dave at Northridge, trying to order the "new" Currie TB. He finally got to talk with one of the engineers at Currie and they told him that they are still about 3 weeks out from shipping any of the "new" TBs. Apparently some were sent to help customers in a bind but they are not yet available to me yet...
Old 06-02-2009, 09:40 PM   #163
mudb8
mudb8's Avatar
you do not want to mess with the axle mount, moving/raising it without using high steering will cause you many other problems...
cut the JJ off of the frame end, re cope the tube to move it towards the front of the joint and reweld it back on... problem solved. or you can make a bracket like the one I posted to move it forward..
ouch... I'm sure the demand will be high as word gets out..
Old 06-02-2009, 09:43 PM   #164
JESSETHELJ
High steer is going to be a part of my fix also going to need to relocate sway bar mounts and track bar bracket.
2004 LJ
Old 06-02-2009, 09:57 PM   #165
mudb8
mudb8's Avatar
[IMG]http://i126.photobucket.com/albums/p116/inline6_bucket/jeep%202/IMG_0244.jpg[/IM
this might be enough... I'd say it will amount to close to 2"...
tj, track bar
Glock Forum
