tj front adjustable track bars for 0-3.5", does yours hit or fit? - Page 105 - JeepForum.com
post #1561 of 1784 Old 03-18-2013, 09:00 PM
HiKnee
I did a 2.5 inch lift and saved a lot of $ and headaches. I cut the stock track bar (near the axle end) removed about a 1/4 inch of additional material then sleeved it with DOM. The DOM was cut on both sides at a 45 degree angle (more weld surface) and drilled in four spots to add rosette (spelling?) welds.
It did happen, although I have no photographs to back it up.
HiKnee is offline
post #1562 of 1784 Old 03-18-2013, 09:10 PM
rda616
Originally Posted by cleveland99 View Post
Ok backtracking jks 126 what steering mods
http://www.jeepforum.com/forum/f9/tj...l#post14582713
This is what I'm trying with my setup.
rda616 is offline
post #1563 of 1784 Old 03-18-2013, 09:10 PM
T-Jay
JF Ambassador to Taiwan
T-Jay's Avatar
Originally Posted by Unlimited04
0" or 8", it doesn't matter...if your junk doesn't work at full bump, then it doesn't work.
the only difference is as you go up in lift height, you also need more bumpstop extension, and eventually you reach a point where clearances are more forgiving.
also, lots of people with said higher lifts never check if their stuff clears or not, nor do they do anything with bumpstops, they just bash the heck out of the shocks and post a thread asking what kind of shocks are good because they keep killing shocks for some reason.
and T-Jay, you still haven't answered the previous questions....what's the upper and lower control arm lengths? how about caster?
Yea I know. It gonna be a few days before I get back in bear cave. Busy week for me in the office. I will post the measurements up when I get a chance though.
Sent from my JeepForum using iPhone...oh wait...what?...
My Surgical TJ-6 Build
T-Jay is offline
post #1564 of 1784 Old 03-18-2013, 10:31 PM
cleveland99
OK so tell me if I have stock diff cover and go with jks or currie trackbar and my RC lift at 3.25 and factory bumbstop I should be ok or no help please lift is in the mail And Please dont respond that I have not been reading this thread because I have its just you guys go in to some other tech stuff I dont understand and I get lost and confused so please dont beat me up to bad in that regards
cleveland99 is offline
post #1565 of 1784 Old 03-18-2013, 11:58 PM
BYuen
BYuen's Avatar
As mentioned before, keep your shocks in while you go to full bump too! I found that my OMEs needed about 3" of bumpstop up front or they would bottom out before reaching bumpstop.
BYuen is offline
post #1566 of 1784 Old 03-19-2013, 12:45 AM
T-Jay
T-Jay's Avatar
Wow! Now that's some serious extension!
If I do find that I am in fact sitting on the shocks at full stuff or flex its not that big a deal. These are at the top of my to-do list. These shocks are getting tired anyway.
T-Jay is offline
post #1567 of 1784 Old 03-19-2013, 03:48 AM
rda616
You must have the n66l with a 15.5" collapsed length. It's about the best you will find with 11" of travel. I have though about modified upper shock mounts to run them with minimal bse.
rda616 is offline
post #1568 of 1784 Old 03-19-2013, 03:59 AM
rda616
You will need more then factory bse for that lift anyway with that long of a spring and a spacer on top. Doesn't this kit come with bump extensions?
rda616 is offline
post #1569 of 1784 Old 03-19-2013, 04:07 AM
rda616
You said THOSE threads, no?
For the record, regardless of this or those threads,
4"+ lift...stock or aftermarket? What would you use?
As some point it becomes a matter of convenience and in some cases strength as well. I have a jks 126 on my jeep now with 2.25" of lift. If I had known 7 years ago the things I have learned since I would have never bought my old re 3.5" lift which required me to drill out the frame side mount to 5/8". There is no going back once the drilling is done.
rda616 is offline
post #1570 of 1784 Old 03-19-2013, 06:39 AM
Imped
Imped's Avatar
Originally Posted by Holaday View Post
I am currious as to why I do not have contact on mine.
I have to admit though I have never removed the spring to check.
Do I really need to point out the obvious?
I wonder if my antirock is acting as a limit though
It's not. It doesn't even enter the equation when your axle is traveling straight up.
My point exactly no two Jeeps are alike!
I've been around enough Jeeps that this statement and its overuse really gets on my nerves. Go take 5 different TJ's all setup identically. You'll get the same results +/- a very small variance....not enough to matter. My point--that statement has no weight when reviewing this subject. If you run a fat diff cover and poorly-designed track bar, you'll hit. Period.
OlllllllO
IndyORV
Imped is offline
post #1571 of 1784 Old 03-19-2013, 06:55 AM
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
Based on what I saw yesterday I think you would clear the diff but the trackbar may interfere with the tie rod. I do not know what all is in that lift but the easiest thing to do is to order a set of 2" RE bump extensions and check the bump when you install the lift.
Only 1 way to tell:
Setup the lift like normal and at ride height center the axle with the trackbar and adjust your control arms to where you want them... Then pull the springs out and push it up all the way.
JKS with 2" extensions and I feel like without them the trackbar end would be into the tie rod as it goes up 2 more inches.
... an no sidewindin' bushwackin', hornswagglin' cracker croaker is gonna rouin me bishen cutter.
LOCKED UP is offline
post #1572 of 1784 Old 03-19-2013, 07:00 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
as this entire thread is about, you need to push your axle to full bump and find out what the limiting factors are. stock diff cover, the JKS and Currie track bars are the best clearance options available. if you're confused and don't understand what that means, then you've got more learning to do. you may find my build thread useful, and you may also find the summary of this thread I did a few pages back useful. bottom line, push the axle to full bump and figure it out for yourself.
Originally Posted by LOCKED UP View Post
Only 1 way to tell:
exactly.
the JKS 126 and Currie TJS/TJJ use different bends, different materials and are different track bars. both will need about 2" front bumpstop extensions if you don't do any mods. both can fit with less bumpstop extension with some steering mods, like a V8 ZJ tie-rod, and that Rusty's offset TRE posted before (but, it's a Rusty's product ), and possibly bending the V8 ZJ tie-rod (heat it up with a oxy-acet torch, use a 20-ton press, etc).
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #1573 of 1784 Old 03-19-2013, 08:01 AM
rda616
I think teraflex also has a 22mm fine left hand thread with an offset and stock taper available now too. It's doubtful Rusty's makes their tre I would almost bet the tera one came from the same place. Looks well made , but little doubt it was made in China.
rda616 is offline
post #1574 of 1784 Old 03-19-2013, 09:31 AM
theremikegoes
I wasnt happy to use a rusty's product either... I definitely looked for a moog product instead. Time will tell... I'm keeping a close eye on it. If someone can come up with a moog part number for a 22mm fine lh thread offset tre you'd be my hero. Just did an outing with lots of twisting and some at speed hits and got light rub where the coupler on the drag link is to the tie rod, I think when I adjusted drag link I didnt index the bolts far enough away though. Working great other than that and at a minimum the rusty's TRE is not instantly exploding.
The garage is a happy place...
theremikegoes is offline
post #1575 of 1784 Old 03-22-2013, 05:29 AM
T-Jay
T-Jay's Avatar
UCA =15.25+/-
LCA =15.75+/-
T-Jay is offline
tj , track bar
how important are front and rear adjustable track bars? travk1234 TJ Wrangler Technical Forum 5 09-02-2009 08:01 AM
Adjustable track bars Aiden80013 TJ Wrangler Technical Forum 8 05-17-2009 03:07 PM
adjustable track bars jr1966 TJ Wrangler Technical Forum 2 03-17-2008 04:15 AM
RE Adjustable Front Track Bar and a 2" BB... ? thejafe TJ Wrangler Technical Forum 4 01-01-2006 10:25 AM
Best Adjustable track bars kaybone TJ Wrangler Technical Forum 2 02-24-2005 06:15 PM
