tj front adjustable track bars for 0-3.5", does yours hit or fit? - Page 100 - JeepForum.com
post #1486 of 1784 Old 02-12-2013, 09:09 PM
AddictedToJeeps
I see everything about aftermarket trackbars w/ aftermarket diff covers. What about a 2 BB with stock track bar, and wanting an aftermarket cover? What hits, what fits?
AddictedToJeeps is offline
post #1487 of 1784 Old 02-12-2013, 09:22 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
the stock diff cover fits. everything else hits.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #1488 of 1784 Old 02-13-2013, 02:01 AM
oalali
did anybody throw offset TREs into the equation ?
oalali is offline
post #1489 of 1784 Old 02-13-2013, 04:07 AM
rda616
Offset tre's would require custom steering. To use one on an anemic stock tie rod assembly would be pointless and destined for constant repair. This is focused on stock and aftermarket inverted y steering setups. The zj style solid tie rod like unlimited has takes slightly more room then a stock hollow tie rod does and is worth the lost clearance. The currie steering which is superior in most every way to factory is also going to reduce clearance.
Short of a custom crossover steering the offset tre isn't likely going to work.
rda616 is offline
post #1490 of 1784 Old 02-13-2013, 07:55 AM
Unlimited04
this guy did (in this thread) using an custom bent & modified ZJ tie-rod:
http://www.jeepforum.com/forum/f9/tj...l#post14582713
it does fit at full bump.....
Useful Write-Ups:
Funny:
post #1491 of 1784 Old 02-13-2013, 08:53 AM
J03_TJ
Originally Posted by Unlimited04
it does fits at full bump.....
Does that mean it goes crazy at full bump? Sorry couldn't resist.
J03_TJ is offline
post #1492 of 1784 Old 02-13-2013, 08:55 AM
Unlimited04
Useful Write-Ups:
Funny:
post #1493 of 1784 Old 02-13-2013, 09:20 AM
rda616
That's very cool. I hadn't seen that post before.
rda616 is offline
post #1494 of 1784 Old 03-06-2013, 02:30 PM
GMBNT42
I thought the Barnett cover cleared on the D30?
GMBNT42 is offline
post #1495 of 1784 Old 03-06-2013, 03:54 PM
theremikegoes
I'm willing to bet the JKS/tweaked WJ tie rod/offset tre would allow a somewhat larger diff cover... part of the reason the JKS doesnt clear is that the bend is too far out from the diff cover and gets into the steering. If someone wants to give me a beefy cover or two to try I'd be more than happy to report results
The garage is a happy place...
theremikegoes is offline
post #1496 of 1784 Old 03-06-2013, 04:01 PM
rda616
Gotta thank you for the offset tre info. Ordered stuff to do the same thing.
rda616 is offline
post #1497 of 1784 Old 03-06-2013, 04:16 PM
theremikegoes
Happy to help... make sure you've got a plan to bend the tie rod if you're trying to get full bump-putting it in a vice probably wont cut it, I had to use my tubing bender.
post #1498 of 1784 Old 03-06-2013, 04:21 PM
rda616
Not a problem. My father inlaw runs a fab shop.
rda616 is offline
post #1499 of 1784 Old 03-06-2013, 07:50 PM
Unlimited04
really? we've covered this many times over.
the Barnett is a stock diff cover....with some stuff welded on the bottom.
Useful Write-Ups:
Funny:
post #1500 of 1784 Old 03-06-2013, 07:59 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
The Warn clears also. But, it's not a diff cover...
Knuckelhead is offline
tj , track bar
how important are front and rear adjustable track bars? travk1234 TJ Wrangler Technical Forum 5 09-02-2009 09:01 AM
Adjustable track bars Aiden80013 TJ Wrangler Technical Forum 8 05-17-2009 04:07 PM
adjustable track bars jr1966 TJ Wrangler Technical Forum 2 03-17-2008 05:15 AM
RE Adjustable Front Track Bar and a 2" BB... ? thejafe TJ Wrangler Technical Forum 4 01-01-2006 11:25 AM
Best Adjustable track bars kaybone TJ Wrangler Technical Forum 2 02-24-2005 07:15 PM
