-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   tj front adjustable track bars for 0-3.5", does yours hit or fit? (http://www.jeepforum.com/forum/f9/tj-front-adjustable-track-bars-0-3-5-does-yours-hit-fit-738948/)
mudb8 03-26-2009 04:12 AM
post you're front track bar specific pics and comments... what hits and what fits 0-3.5" lifts along with broken and bent ones. I'm interested in track bar and differential contact/failure.
we hear claims of jks, rusty's and other hitting and breaking.
I want to attempt to point out why and which ones have little to no issues.
I'll put all the info together in a few days that weeds out the BS. like opinions on strength... we"ll show it.
mother's day EDIT... broken and bent TRE and hiem shafts seem to be/are from clearance issues with the differential cover... several pics in this thread. still gathering info .. bent bars are from abuse, I run and hide here..
kinda like this pic of the thin re1600 and a solid rock krawler bar, which is also similar to rough country's new adjustable, Clayton, and iron rock off road...
http://i268.photobucket.com/albums/j...s/Pdr_0268.jpg
there is a definite shape difference... here's a teraflex adjustable over a stock track bar..
http://i268.photobucket.com/albums/j...nt-track07.jpg
I can start off with my 2.5" suspension, nth degree/aev hd solid adjustable w/frame brace.
with my 16" lower arms and 15 1/2" upper control arms it'll hit the diff cover bolts on the brace and the wj bar just barely touches the cover. it requires 2" bump stops to keep it clear and problem free.
nth with stock wj track bar..
http://i268.photobucket.com/albums/j...20bars/nth.jpg
nth with jks wj adjustable has a considerable amount more room from the cover.
http://i268.photobucket.com/albums/j...1233633372.jpg
this means you to rubidriver.. snap some good side views of the jks
what I figure might be a solution and alternative to the adjustable is a weld/bolt on drop bracket like Clayton's having a thick pad drilled with a tapered hole that'll potentially center the axles of 2-3" lifts with the stock track bar
and be used for adjustable that are known to have rubbing issues with tre's and jj's.
http://i268.photobucket.com/albums/j...rs/DB-TJ-1.jpg
the currie HD offset IMO is the best (I should say easiest) option at this time for a front adjustable track bar...
http://i268.photobucket.com/albums/j.../PICT00221.jpg
http://i268.photobucket.com/albums/j.../PICT00231.jpg
http://i268.photobucket.com/albums/j.../PICT00241.jpg
not yer usual thin bar here....
http://i268.photobucket.com/albums/j.../PICT00261.jpg
http://i268.photobucket.com/albums/j.../PICT00251.jpg
TheBoogieman 03-26-2009 04:21 AM
No pics but, I've had Black Diamond and RC and never had any problems.
mudb8 03-26-2009 09:47 AM
what lift height?
jrb470 03-26-2009 10:30 AM
I have the Rusty's that just arrived yesterday... sitting in the box...waiting to shipped back.
Unless someone can reassure me that installing this will be better than just relocating my stock track bar.
gabriel05 03-26-2009 11:08 AM
I have a Rusty's with the TRE frame mount. I have a 4" RC lift, no clearance issues, however I don't have discos yet. Once I disconnect it might hit. It has been installed for about 2 years and around 5k miles. I had a D30 which give me a little more room over the D44. After all this talk I debating about getting something better. I will be very interested once you compile the info.
chadsmeltzer 03-26-2009 11:20 AM
My Full Traction didn't hit with ~3" of lift but I snapped it. I will find out next week if the JKS one works.
Wetsuit_Mike 03-26-2009 11:20 AM
My RE 3.5" kit works just fine.
vector6 03-26-2009 11:43 AM
i have the clayton setup... i have no issues
TheBoogieman 03-26-2009 12:01 PM
Originally Posted by mudb8 (Post 6879694)
what lift height?
3-5" lifts.
HAYSHAKER170 03-26-2009 02:56 PM
I just installed Rusty's Adjustable trackbar and it hits the diff cover just enough to scape the oily residue off. I'll try to post some pictures later. I may return it depending on your investigation. Thanks for keeping this topic alive, someones life may depend on it.
jrb470 03-26-2009 04:02 PM
What's weird is I have NEVER heard of this issue until a few days ago!
I can't believe it isn't a major topic of conversation when discussion lift kits, etc...
jeep2008 03-26-2009 04:14 PM
i have a problem with mine.the 2'' bumpstops are too much imo.as far as front lca go i have the re fixed ones and cam bolts that have taken the lca all the way back to the end of their adjustment.
http://www.jeepforum.com/forum/f9/jks-adj-trackbar-hitting-dana-30-diff-cover-700145/
MEnginerd 03-26-2009 04:23 PM
I bought a rubicon express because of the known issue between JKS and the D44 cover. Unfortunately the RE has the same issue....
I run an OME HD spring, 3/4" spacer, and have 2 hockey pucks per side for bump stop extensions.
To make this discussion more valuable, I think it would help if people skip their lift height, and describe:
Bump Stop Extension Length
Controls arms (stock or modified length)
Diff model and cover brand if aftermarket
?Shock Length? (Might be nice to know, but I don't think droop on the passenger side matters here)
Edit: I'll add that the contact on my diff cover is VERY suttle, only slightly affecting the paint. Obviously there is some bind and distortion at full compression if there is contact which isn't good, but its not much. I haven't taken any action yet because I was hoping to find a welded style aftermarket diff cover which will actually increase clearance, no idea if one actually exists and haven't had a chance to look into it more.
-Brent
SB99TJ 03-26-2009 04:27 PM
I would take that thing off immediately. I had the Rusty's and it did the same thing. It snapped and nearly killed me at 50+mph. You are gambling with your life and the life of anybody that rides in that Jeep. Do you enjoy eating through a straw?
This is not something you want to experiment with my friends. If it snaps, you LOSE your steering. You can hold on at low speeds, but if it snaps at higher speed on a little road dip like mine, you will need both sides of the road to stop...thats IF you don't roll first.
I tried to post the pic but it wont work. I just get the red x. Just look at the other threads on the Rusty's stuff and track bar.
topfuel83 03-26-2009 04:28 PM
I have a BDS front adjustable, 2" BDS Spring lift, stock control arms, and stock bump stops. I have no rubbing issues at full coil bind.
The time now is 06:11 PM.
