TJ Frame Differences Help - Page 2 - JeepForum.com
 1Likes
post #16 of 27 Old 09-29-2011, 08:50 PM
Rockram1
I would assume them to be the same. I just did a 98 6cyl auto to 98 4 cyl 5 sp frame swap The only difference I found was the motor mounts need moved about 4 " forward. I fabbed them myself. Then the skid plate was the same.
Skid plate differances: there are 2 sets of holes for the tranny mounts. A forward set and a rearward set. The auto uses the froward set of holes. There is an additional plate that the tranny mount attaches to. This is attached to the skid with 4 carriage bolts. The 5 sp tranny uses the rearward holes and doesn't require the additional plate as the skid has a support there.
I don't have pics sorry.
86 CJ7, 258, t18, D300, D44's 4.56's, Detroit front, Warn shafts and CTM joints, spool rear, SOA, SRS, waggy springs, 6 point cage, Warn winch, 38" Tsl, Allied beadlocks.
Rockram1 is offline
post #17 of 27 Old 09-29-2011, 09:00 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Your best bet would be to get a trans skid and tranny mount (maybe) from the newer frame and use it instead of trying to make the old one work.
The holes are not in the same place, the 99 uses countersunk head bolts into dimples and the 03 up uses metric bolts that have captive flat washers.
da_jeep likes this.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #18 of 27 Old 10-03-2011, 12:57 PM Thread Starter
nickrad8
Originally Posted by Hillbilly88 View Post
I have a 99 tj with a 4 cycl. And i have a 2004 tj frame that had a 6 cyl in it tmrw when i get home from work i will lay the 99 tranny/ tcase skid on the 04 frome and see if the holes line up will be easy since frame is already upside down and skid plate it off If thats what ur wanting are wanting to know ? If it will help let me know
thats exactly what i need to know. if you could let me know as soon as you get the chance, i would appreciate it. the only difference in what i am doing is that i am going from a 6 cyl to 4 cyl frame
nickrad8 is offline
post #19 of 27 Old 10-03-2011, 05:20 PM
Hillbilly88
2014 JK Wrangler
I just went and laid my 99 skid plate on my 04 frame and all the holes lined up. Hope it helps
Hillbilly88 is offline
post #20 of 27 Old 10-03-2011, 05:45 PM
mikesbeachhut
I am almost sure the trans skid on 03 & up are different then the 98 to 02.Got to do with the automatic trans when they changed it in 03 .The trans mount might not line up with the 4 holes in the skid.
mikesbeachhut is offline
post #21 of 27 Old 10-03-2011, 08:17 PM
Hillbilly88
2014 JK Wrangler
Just so u know i do not know about the trans holes matching since the frame is bare so on that note take some of these other guys advice All i can say for sure is the skid plate will bolt to the frame
post #22 of 27 Old 02-18-2014, 11:01 PM
Corbie
I am in the process of doing a ’97 to a 04 Frame swap. Mine is 4.0 to 4.0, so I don’t have to worry about engine mounts. I have the 04 skid plate, so that isn’t a problem. Did you find that the steering box holes don’t line up? I am having that problem now. I know this is an old thread, and hope you are still active. What other holes didn’t line up.
"Tires are like boobs. They always look big until you have played with them for a while. Then you just want a bigger set!”
-"YEEP” from Virtual Jeep Club
Corbie is offline
post #23 of 27 Old 02-19-2014, 06:57 AM
csalev3
Just did a swap on my 97 TJ last summer.. I swapped in an 03 frame and had to redrill skid pan mounting holes. I can send some pictures if it'll help. Also, the steering box mounts had to be modified slightly too. Other than those two changes I didn't run into anything else. I believe all the changes were from 03-06. 97-02 frames will require some modifications for your 05.. Or you could hunt down the correct skid pan if you're not into modifications.
Feel free to ask if you run into anything, my frame was swiss cheese before the swap so I've seen how bad it can actually be..
1997 TJ, NEW FRAME, 4.0, 5 spd, d30, d35 aussie locked, np231 RR sye, tom woods driveshaft, 4" RC n20 lift, adjustable upper rear c/a, 33x10.5x15 BFG KM2s
1945 Willys MB, all original right down to the tires, 30k miles, 250 miles on rebuilt L134 engine. + 1946 Willys CJ-2a, barn fresh, new 6.50x16 NDTs, 15k miles
csalev3 is offline
post #24 of 27 Old 02-19-2014, 09:06 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
The steering box bolt mounts are different from 97-02 and 03-06. You are better off just moving the lower one at the front so that you can use the earlier gear box.
I am Savvy
mrblaine is offline
post #25 of 27 Old 02-19-2014, 01:07 PM
RH31379
1983 CJ7
I just swapped a frame from a 2000 to an 03 frame. Aside from the mounts being different because of the engine size, the other differences are the skid plate and trans mount plate will not work. I had to use a skid plate from an 03 and newer as well as the transmission adapter plate from the newer year, the threaded holes for the transmission skid plate also change from SAE to metric in the newer frame. You could make a patter out of your old skid and cut out and put some new plates in for the skid mounting bolts. I would of done this had I known the difference before I painted everything. Also the mounting bolts for the newer skid plate are not the self centering bolts used from 87-02 on skid plates. I ended up using regular bolts because the skid plate has flat bolt holes.
The steering box will not work either. The newer jeeps use a Mercedes steering box instead of the saginaw box that jeep used forever. The mount holes are not the same but the pump is but the lower steering shaft is also different. Not sure but between the 4 and 6 cyc. the steering shaft mount may be different. The one other minor difference is the factory side steps also changed in the later years. I haven't found a mounting solution for those yet.... just got it running and found a bad valve so I'm dealing with that at the moment when the weather allows. good luck
besides the 83 cj-7, also have an 87 yj, 6cyl., 5spd, weber upgrade, 6.5' western uni mount plow, also a 2000 Sahara, 4.0, 5 spd
RH31379 is offline
post #26 of 27 Old 10-03-2014, 08:19 PM
365Jeep
Okay, I'm about to undertake this project myself, and I just figured out the skid plate thing tonight. I am swapping a 2004 frame into my '01. The front two bolts on the skid plate line up, but the rear ones do not. Can anyone confirm that the location of the front two bolts are in the same location as the earlier frame? If they are, the transmission mount should line up as well.
David
365Jeep is offline
post #27 of 27 Old 10-06-2014, 07:14 AM
RH31379
1983 CJ7
I ended up getting a skid plate from the later model year and a transmission mount from the later years as well. Everything lined up that way except had to make a minor modification to the hanger for the cat.
RH31379 is offline
frame , frame swap , replace , swap , tj
TJ Frame Differences Zlake TJ Wrangler Technical Forum 13 09-01-2017 07:33 AM
YJ Frame differences? Can I frame swap any platform Nate M YJ Wrangler Technical Forum 5 10-26-2010 10:17 AM
frame differences? Allen52105 YJ Wrangler Technical Forum 2 07-02-2008 04:04 PM
frame differences green_jeep YJ Wrangler Technical Forum 1 11-26-2006 10:46 AM
4cyl vs 6cyl frame differences... yoshisushi YJ Wrangler Technical Forum 1 05-18-2005 04:40 PM
