TJ fluid capacities - JeepForum.com
post #1 of 6 Old 04-06-2004, 10:31 AM Thread Starter
wyldejackyl
TJ fluid capacities
I dont' have a jeep yet so I don't have a manual to look this stuff up. However, I'd like to start buying supplies so I can change all my fluids first thing::
I need to know capacities and types of::
coolant
oil
diff fluid
tc fluid
trans fluid (manual)
brake fluid
grease (for the grease points on the body/suspension)
I want to have everything ready to go and change so when I get my new jeep (well, used, but new to me), I can be the good car owner I am and change all the fluids and start fresh. That way, there is no question of previous owner maintenance or neglect in that department.
How long do jeep clutches last, and are they easy to change?
..::2007 JK Unlimited X::..
1500W inverter
Midland 1001LWX CB
55/100W H4 Hella headlamp conversion w/ dual relays
wyldejackyl is offline
post #2 of 6 Old 04-06-2004, 11:28 AM
TheAdjuster
TheAdjuster's Avatar
Oil is about 6 qts
Trans is about 3 qts
tc is about 2 qts
front diff and rear together is about 4 qts (I have a dana 44 in the rear)
For grease, just buy a tube
no clue on the brakes
jeep clutches last quite awhile...
TheAdjuster is offline
post #3 of 6 Old 04-06-2004, 11:54 AM
Jay-Mac
Jay-Mac's Avatar
If you plan on just topping off the brake fluid grab a pint if ur gonnableed the breaks and etc get a quart....
Jay-Mac is offline
post #4 of 6 Old 04-06-2004, 12:47 PM Thread Starter
wyldejackyl
DOT 5 on the brake fluid?
What types of oil should I get for the TC, trans and diffs? Or will the rear diff fluid depend on the type of diff I have?
How long is a while on the clutches..100k, 200k?
1500W inverter
Midland 1001LWX CB
post #5 of 6 Old 11-07-2012, 09:47 AM
tjtrucker
I was looking for the same answers, here's what I found on line, (hope it helps others looking for the same info);
http://www.jeep4x4center.com/knowled...capacities.htm
tjtrucker is offline
post #6 of 6 Old 11-07-2012, 09:56 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
All that information is in the FAQ section at http://www.jeepforum.com/forum/f9/tj-forum-faq-615132/
Thread closed.
Jerry Bransford is offline
Closed Thread
FAQ - Fluid Capacities Wheelin98TJ TJ Wrangler Technical Forum 1 01-11-2008 03:51 PM
FAQ - Fluid Capacities Wheelin98TJ TJ Wrangler Technical Forum 0 05-02-2007 07:07 PM
fluid capacities bfr TJ Wrangler Technical Forum 7 12-14-2006 11:44 AM
fluid capacities wraithyjeep YJ Wrangler Technical Forum 1 05-08-2006 03:05 PM
87 YJ fluid capacities Buzzard YJ Wrangler Technical Forum 3 12-09-2001 08:50 AM
