TJ engine swap - JeepForum.com
post #1 of 2 Old 07-15-2010, 11:00 AM Thread Starter
MJPeder
1987 MJ Comanche
TJ engine swap
I have a friend with a 97 TJ 2.5 and a manual.
And i have a 93 zj 4.0 engine with AW4 trans without the wiring harness in my garage that we really wont to put in his Tj.
But I need some help!! What is the best way to get it to work in the TJ?
I have thought about buying a wiring harness from a TJ with 4.0 and auto trans, but wil i work? Isn't the sensors different from 93 to 97 4.0?
And we live in Norway, so there are not a lot of TJ's with 4.0 around. The junkyards do not have that many Jeeps like you in the states. Specialy TJ's and 4.0 engines.
MJPeder is offline
post #2 of 2 Old 07-15-2010, 11:34 AM
Sundowner
You're going to need a lot of auxiliary parts. Wiring harness and PCM, exhaust, fan and shroud, motor mounts, bellhousing (if you swap the tranny), etc, etc, etc...
There are a lot of threads on the 2.5 to 4.0 swaps. Take a brief look through them.
Sundowner is offline
engine swap , zj , grand cherokee , tj , wrangler , 4.0 , 2.5 , aw4 , transmission , wiriing harness , sensor , help , advice
My Jeep ate its engine ! - need advice on engine swap... ymibuyingmore YJ Wrangler Technical Forum 5 05-03-2011 04:31 PM
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 05:11 AM
Engine Swap or Body Swap? schecterguy YJ Wrangler Technical Forum 2 09-28-2008 12:36 AM
Engine 4.3L swap and axle swap abrupt11 YJ Wrangler Technical Forum 14 02-18-2005 12:14 PM
