TJ Dying When Idling - JeepForum.com
post #1 of 4 Old 08-11-2012, 04:41 PM Thread Starter
oracle5
I have a 2003 Wrangler Rubicon with automatic transmission I bought about a month ago. Its my first Jeep. I have a random issue that only happens while in gear(drive or reverse, happens more often in reverse and never when in park) the Jeep will idle low, the engine will rev itself and the rpms will bounce up and down between revs until it dies after 3-4 bounces.
I can't recreate it every time so it seems random. It never dies when up to speed but only at low speeds like when in reverse. It has 98k but the engine was replaced by the previous owner at 92k with a Jasper engine. It also has a new fuel pump.
I put some Seafoam in the gas tank hoping that fixes/helps the issue but haven't ran it all the way through yet. Any other ideas on what is happening? Thanks in advance.
First post by the way. Glad to be part of the forum.
oracle5 is offline
post #2 of 4 Old 08-11-2012, 04:59 PM Thread Starter
oracle5
I forgot to mention. When doing the key dance trick I get no codes.
oracle5 is offline
post #3 of 4 Old 08-12-2012, 12:00 AM
Willcamp
Mine does something similar, but since I have a stick it stays idling. It only does it when I have spent awhile in the low range. The last time it started doing this I put my code reader on it. The reader said 0 codes, but just for sport I had it erase the codes. Afterward it idled fine. It tells me that something is kicked that my reader won't pick up, but will at least clear. I know I can reproduce it just by going four-wheeling.
Willcamp is offline
post #4 of 4 Old 08-12-2012, 10:37 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Here's the answer I gave you asking the same question in your other thread... http://www.wranglerforum.com/f5/tj-d...ml#post2675613
Jerry Bransford is offline
2003 , idling , rubicon , tj , wrangler
It keeps dying. help. jbars YJ Wrangler Technical Forum 2 02-01-2010 04:31 PM
rig keeps dying?!?!?!?!??? Anonymous6915 YJ Wrangler Technical Forum 13 09-10-2009 09:45 PM
Help..Car keeps dying alexwo1 YJ Wrangler Technical Forum 9 06-09-2006 07:37 AM
Rough idling, dying while idling...tranny problem? MissLarramendy TJ Wrangler Technical Forum 7 07-25-2004 04:20 PM
98 2.5 dying OlllOTJ TJ Wrangler Technical Forum 8 09-23-2003 12:59 PM
