TJ/Durango steering box swap - JeepForum.com
post #1 of 6 Old 11-25-2006, 10:58 AM Thread Starter
DBraceM20
i just got done swapping out the TJ steering box for the Durango one. Eveything went fine on the install and was driving fine for about a half an hour than the power steering gave out. What could have cuased this to happen? It goes on and off like it will work fine and then just shut off than go back on agian after i stop driving for a little bit. Any ideas cause i need help!
DBraceM20 is offline
post #2 of 6 Old 11-25-2006, 11:05 AM
jerico
jerico's Avatar
You forgot to bleed the system. Go back on the posts and they will tell you now to do this.
jerico is offline
post #3 of 6 Old 11-25-2006, 11:38 AM
JSBlu974X4
try gettin all the air out as well. when i swapped mine i let all my old fluid run out, fill it and i turned my wheel slowly both sides and kept opeaning it and refilling
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada
JSBlu974X4 is offline
post #4 of 6 Old 11-25-2006, 11:55 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
How to bleed the steering system: Jack the front-end up so the wheels are off the ground an inch or so. Without the engine running (!), slowly turn the steering wheel back and forth from lock to lock at least a dozen times to bleed the air out. Add fresh fluid as necessary but realize the fluid level will go up and down as you cycle the steering back and forth. That simply means to not overfill it at its low point as doing so will cause it to overflow and make you think you have a big leak. Don't ask me how I know this.
Jerry Bransford is offline
post #5 of 6 Old 11-25-2006, 12:05 PM
Beefstew
Jub Jub
Beefstew's Avatar
how do you kno this?
Beefstew is offline
post #6 of 6 Old 11-25-2006, 02:59 PM Thread Starter
DBraceM20
ok thanks alot guys i really appreciate it. I drained it again and filled it up and it works like a champ now.
Great write up for Durango steering box swap hulud44 TJ Wrangler Technical Forum 13 06-05-2014 07:24 PM
95 YJ Durango Steering Box Swap Question Rgribbl1 YJ Wrangler Technical Forum 1 03-20-2009 09:02 AM
Problem after Durango steering box swap Gomofast TJ Wrangler Technical Forum 5 03-11-2008 09:24 AM
Durango steering box swap valeech TJ Wrangler Technical Forum 0 08-12-2006 09:02 AM
durango steering box swap jeepinkeller TJ Wrangler Technical Forum 0 05-21-2004 04:30 PM
