TJ dies, then wouldn't start, then wouldn't idle, now runs fine.
#16 | |
good, glad you found the problem.
God Rules! |
#17 |
i am having very similar problems with my auto. occasionally it starts everytime and that once in awhile start it up and the starter bendix stays engaged to the flywheel or it sputters and dies. sometimes the check engine light comes on, sometimes not.. I thought it could be the throttle position sensor but then the starter would do that. i better check my wiring tommorow...
#18 | |
Sounds like a nightmare!! |
#19 |
Wow! Any idea why the harness wore through? I've noticed that harness before and don't really like the way Jeep routed some of the TJs wiring.
Good lesson to others why you should always keep at least a few tools on board. Even a cheap multitool is better than nothing. I'm just amazed it went on so long and you were able to repair it. A lot of those end up auto flambe. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
