TJ control arm drop brackets - JeepForum.com
post #1 of 30 Old 12-01-2013, 08:00 AM Thread Starter
dauster500
1987 YJ Wrangler
I have a TJ with 3" currie coils and bilsteins and sway bays disconnected but the thing rides extremely hard. Before you say go long arm and tell me how im going to lose clearence im in the process off going soa with my yj with d60s so im not dumping money into two jeeps...at the moment... so does anyone know where to find the the drop brackets? i can only find them for XJs
04 5spd 4.0 TJ DD, 87 3spd auto 4.0 yj
Gotmudcnj4x4.org
dauster500 is offline
post #2 of 30 Old 12-01-2013, 08:07 AM
Eckoh
what control arms are you using?? and a hard ride is most of the time the fault of the shocks but you have good shocks.
Eckoh is offline
post #3 of 30 Old 12-01-2013, 08:07 AM
Ironhead
what would the drop brackets do to assist the ride?
are your sway bars always disconnected? not that it would affect ride quality, just asking
with currie springs and bilstein shocks, you should not be experiencing a rough ride. what else has been done? control arms? track bars? bump stop extensions? tires and psi?
have you cycled your suspension? anything rubbing?
Ironhead is offline
post #4 of 30 Old 12-01-2013, 08:14 AM
Ben
Same springs and shocks, I don't think mine rides that hard at all.
Ben is offline
post #5 of 30 Old 12-01-2013, 08:15 AM Thread Starter
dauster500
1987 YJ Wrangler
control arm drop brackets reduce the control arm angle giving a better ride. I have stock uppers and IRO lowers. im on 32" mtrs and i run 30psi. Sway bars are always disconnected cause it smooths out the ride. Stock front trackbar but, now that i think of it my trackbar probably isnt helping at all...surpisingly nothing is rubbing even at full flex. rear jks trackbar
Gotmudcnj4x4.org
post #6 of 30 Old 12-01-2013, 08:23 AM
durango-bob
2006 WK
I would start by dropping the tire pressure. That will have a significant effect on your ride quality.
durango-bob is offline
post #7 of 30 Old 12-01-2013, 08:25 AM Thread Starter
dauster500
1987 YJ Wrangler
25psi?
Gotmudcnj4x4.org
post #8 of 30 Old 12-01-2013, 08:26 AM
Ironhead
the bold items are not true, especially under 4" of lift
tire psi seems a bit high, try lowering it to 28
IMO, stock track bars seem to be limited to <2" of spring lift, but i doubt that would give you a harsh ride
Ironhead is offline
post #9 of 30 Old 12-01-2013, 08:26 AM
Ironhead
25psi?
that would be a bit low for 32's
Ironhead is offline
post #10 of 30 Old 12-01-2013, 08:33 AM Thread Starter
dauster500
1987 YJ Wrangler
hmm well my tires are a bit low in tread nothing crazy though and they are from 2009 so maybe a fresh set of tires will help
Gotmudcnj4x4.org
post #11 of 30 Old 12-01-2013, 08:39 AM
Ironhead
Are they the old mtr's?
Ironhead is offline
post #12 of 30 Old 12-01-2013, 08:45 AM
joe_jeep
superlift did sell tj drop brackets at one time. not a popular option.
tire pressure is a bit high, try 26psi and see if it helps.
your control arm angle should be decent at 3"
shocks will dictate the ride more than anything, unless there is a binding issue.
what is the load rating of the tires? d's and e's can be pretty harsh on a tj!
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #13 of 30 Old 12-01-2013, 09:04 AM Thread Starter
dauster500
1987 YJ Wrangler
good point...They're Es
Gotmudcnj4x4.org
post #14 of 30 Old 12-01-2013, 10:20 AM
Necko2529
Necko2529's Avatar
E's have a pretty stiff carcass, meant for higher loads.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #15 of 30 Old 12-01-2013, 10:26 AM
afusco1222
I have Es and they give my jeep the worst ride on and off Road. That is your main culprit.
afusco1222 is offline
