2001 Wrangler TJ with 200,030 miles. My rig is making a very high pitch whistle noise only during the winter months and when the jeep is coasting. At idle it fades away a little but when I accelerate the whistling starts. Spring summer and fall months it doesnt whistle. Just when its cold out. My check engine light is on with miss fire in bank 1. Thinking it's the manifold gasket or headers for both problems or the water pump for the squeal. Can't really tell what area it's coming from bc it's so damn loud. Help needed!
look up tea kettle on the 4.0 mine has been doing it since i bought it back in august. they say its usually cause by a loose intake manifold and the gasket passes air or a leak in the vacumme system. mine whistles at idle and goes away when i give it gas.
Well I replaced the valve cover gasket and intake/exhaust manifold gasket with both fel-pro brand gaskets. Used copper silicone on the manifold gasket, tightened up the bults and no more squeal. Cost me about $40 total for parts and took about 4 hours on a Saturday to complete and this was my first attempt. If I could do it you could also. 4 bolts holding the manifold from underneath were the hardest to get to. Also replaced the foil recall debris heat shield part cost about $5 from dealership. Gaskets I got from rockauto.com, copper silicone from autozone and these are the write ups I followed.
The belt tension and power steeling pump are different. Belt tensioner is on left side and used a 1/2 in ratchet to remove. Steering pump has 2 bolts on top 1 on bottom and easier to use a ratchet by going through the pulley.
Fixed the misfire with champion copper spark plugs
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
