tj coilovers? - JeepForum.com
post #1 of 37 Old 08-08-2004, 03:27 PM Thread Starter
0IIIIII0
0IIIIII0's Avatar
tj coilovers?
anyone know any companys that sells kits for coilovers for a tj? how much would this run me? any disadvantages and advantages? ive seen pics of this done and think it would help tremendously. any info welcome.
98' TJ sahara-white w/spice hard top-5 spd-I6-all stock
70' CJ5 "Dauntless V-6"-3 spd-twin stick pto ramsey 8000lb winch-green body/black bikini/aluminum hard top-2" lift-mudders
0IIIIII0 is offline
post #2 of 37 Old 08-08-2004, 03:41 PM
SlinkyTJ
This space for rent.
SlinkyTJ's Avatar
2009 JK Wrangler
I've been looking at this for a while. There are a few companies that make coilover kits for the front... bluetorch fabwors, skyjacker, and rockkrawler all do. Rockcrawler also makes a coilover kit for the front and rear and a kit that stretches the wheelbase. From the people I've talked to, you definately need some sort of swaybar with it.. like the currie antirock or something. There's also not a huge performance advantage from those I've talked to over a standard long arm kit. It sure looks cool though.
'09 JK
Lockers and stuff
SlinkyTJ is offline
post #3 of 37 Old 08-08-2004, 04:39 PM
StealthTJ
Originally Posted by 0IIIIII0
<SNIP>
Help what ?
What specific problem are you trying to solve ?
Fred
Base - '98 Sahara, 4.0L 6 cyl, Auto (swap from 5 sp)
Suspension- 4.0" Procomp Springs + 1 1/4" bl. Rear tri-link. Currie J arms, F&R. Warn hubs with WJ knuckles, custom cross over/hi-steering setup, Currie A/R Sway Bar.
HPD30/D44 (rear disk conversion, WJ dual piston caliber conversion in the front); Detroits; 4.56
Misc - Tera 2wd lo.
Tires - 35x12.50 MT/R's siped on 15x7 Champion Beadlocks.
Recovery - Warn XD9000i
StealthTJ is offline
post #4 of 37 Old 08-08-2004, 04:53 PM
wipedawg
wipedawg's Avatar
Not being mean, but obviously you've never ridden in a vehicle with coilovers installed. There is a tremendous advantage over normal coils. The drawback is that for most of us.... it isn't worth the extra couple thousand
Silver Jeep Club Member # 829.3
6 in lift, 35" Interco Trxus MT's, long armed, Bushwacker cut-out flares, Skyjacker coils(powdercoated grey), RE 4.5 extreme duty leaf packs, Tera 1.5in shackles, AJ's Superrails, AA SYE, TW DS, Blacked out all around. and a buncha RE trackbar stuff, and the infamous ZJ tierod :)
wipedawg is offline
post #5 of 37 Old 08-08-2004, 07:32 PM
SlinkyTJ
SlinkyTJ's Avatar
2009 JK Wrangler
That's ok, you're right, I haven't. Just like I said, I was only going on what I've been told. What exactly are the advantages? The amount of flex seems to be about the same and with good standard coils and shocks you can get a pretty decent ride. I'm just curious really, cause I still want to try it. I'm also starting to look at the fox air shocks as well.
'09 JK
Lockers and stuff
SlinkyTJ is offline
post #6 of 37 Old 08-08-2004, 08:13 PM Thread Starter
0IIIIII0
0IIIIII0's Avatar
you are very right on the looks...looks very nice...is the ride better or worse?
0IIIIII0 is offline
post #7 of 37 Old 10-29-2004, 04:20 PM
1BLKJP
Alright boys time to bring this one back from the dead. I am seriously considering a 4 wheel coilover, but have never seen anything except an XJ and several buggies with coilover rears.
I already know all of the benefits and I like them over coil/shock combo. Plus I also know how I am going to mount them all also. But I am bored at the office today so I thought I would see if any of you have this particular setup on your TJ's and see if you had any pics of it.
1BLKJP is offline
post #8 of 37 Old 10-29-2004, 11:56 PM
StealthTJ
I already know all of the benefits and I like them over coil/shock combo. Plus I also know how I am going to mount them all also. <SNIP>
You mount them by fabing up some mounts, or buying a "kit" with the mounts. Either way involves cutting and welding.
Again, what specific problem are you trying to solve with coilovers, or is it just for looks ?
Fred
Misc - Tera 2wd lo.
post #9 of 37 Old 10-30-2004, 12:12 AM
Oman Jeep
Oman Jeep's Avatar
Without knowing what problem you guys are trying to solve, I'll just throw this out there. If you're looking to throw a lot of money into your suspension system in the hopes of a better ride, you really should take a close look at the OffRoadOnly AiRock Air Suspension system for TJ Wranglers.
Computer controlled airbag suspension that can raise and lower the Jeep or lean it in any direction you wish, with a control unit that sits on top of your dash.
http://www.offroadonly.com
Oman Jeep is offline
post #10 of 37 Old 10-30-2004, 12:22 AM
shoatx
Try here....
Randy
http://www.oristruts.com/
shoatx is offline
post #11 of 37 Old 10-30-2004, 05:20 AM
CTMpwrdcamry
Is the air strut like a long arm?
CTMpwrdcamry is offline
post #12 of 37 Old 10-30-2004, 06:50 AM
yogi
yogi's Avatar
heres a pic of mine skyjacker coils and custom towers with x-over
ride is better more forgiving looks sweet and cost abot 1500
no sway bar needed still need trak bar
yogi
COME TO YOGI & SUES 7TH ANNUAL PIG GIG AUGUST 14TH -16TH AT ROCK AND VALLEYS ORV PARK2001 xj
yogi is offline
post #13 of 37 Old 10-30-2004, 06:58 AM
BigWaylon
tubework is cool...
BigWaylon's Avatar
this system is amazing...my local shop installed one of the first ones in the US...on an Unlimited...
it automatically adjusts on the trails (up to 10% or so), and automatically lowers the Jeep and locks the new sway bar at 30MPH or so...also has a "demo" mode that makes is rock around like it's on hydraulics...quite entertaining...
I think they guy had $2500 in just parts on it...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #14 of 37 Old 10-30-2004, 07:23 AM
yogi
yogi's Avatar
what happens when the air system fails and you 2 hr from the rd ???will you be able to drive it out or will the air bags deflate and fenders setting on the wheels
yogi
yogi is offline
post #15 of 37 Old 10-30-2004, 07:50 AM
owlman
owlman's Avatar
yogi
the shocks act as bumpstops, it'll be a rough ride though.
also, you can probably just inflate them manually (gas station, somebody else's OBA) and get them to hold that pressure til you got everything repaired.
owlman is offline
yj coilovers jeepwyj94 YJ Wrangler Technical Forum 18 06-20-2010 06:13 PM
Why does no one run coilovers w/ SA's? CCJ TJ Wrangler Technical Forum 33 10-02-2009 07:53 PM
Coilovers JCM TJ Wrangler Technical Forum 4 10-19-2006 07:18 AM
Coilovers TJJPNUT TJ Wrangler Technical Forum 1 12-08-2004 09:48 AM
Coilovers? Who What When Where???? stjjames TJ Wrangler Technical Forum 15 12-06-2004 05:16 PM
