#1 | |
TJ Coilover COnversion
Anyone have experience with these items?
http://www.polyperformance.com/shop/home.php?cat=312 Also...I am guessing this may not lift the Jeep, but rather increases articulatin only? If a lift does occur, does it depend on the legth coilover shock you install? Any info is appreciated.
02' Sahara Owner |
#2 |
the lift depends on the tuning of the coilover. You can tune it to sit at near stock height (so only a few inches of shaft is showing) but will droop quite a bit, or you can do a 50/50 split, or more. Coilovers are very tunable, and you can get as much or as little lift out of just about any size coilover. To just say, "you will get X" of lift from a 12" coilover", would be wrong because you can tune them to what ever you'd like.
#3 |
Any one here runnig it?
[SIZE="1"][B]Black[/B] 98 TJ / 4.5" Coils / 1" BL + MML / 4.56 / 35's Silverstones MT-117 on 16 X 8's / D44 & ARB Airlocker / D30 & lockright / Rocklights / wind sheild IPF's / Custom WARN rear tyre carrier / extended brake lines / Custom Triangulated 4 link long arm / Front adj. panard (no rear) / rear storage draw system / OBA / AA SYE / Bestop duster, windjammer, bikini combo / Bushwackers flares / UHF / TBS / Wilderness Rack / 3" stainless steel snorkel / T-Max 9000 6HP winch[/SIZE] |
#4 |
Thanks Super....that's a lot of help.
I don't know of anyone running this, but is definitely a thought I have thrown into the ring when purchasing my lift (by Spring 07).
02' Sahara Owner |
#5 |
Some Call me RockDog
BigWaylon has coilovers.
another pic here http://www.jeepforum.com/forum/f59/grill-hoop-stinger-bumper-pictures-please-320381/
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#6 |
I'm running Fox Coilovers in the front and I used some of the Poly Performance brackets. In a few months I am also converting the rear to Fox Coilovers. Let me know if you have any questions at all.
Jay
Pics... [URL="http://smg.photobucket.com/albums/v516/JeepJay/"]http://smg.photobucket.com/albums/v516/JeepJay/[/URL] TJ Stretch Thread... [URL="http://www.jeepforum.com/forum/showthread.php?t=348220&page=3"]http://www.jeepforum.com/forum/showthread.php?t=348220&page=3[/URL] |
#7 |
benefits of coilovers
Can someone explain if there are any benefits in doing a coilover conversion without doing a long arm suspension?
TIA |
#8 |
Short arm coilover
I am in the process of running the coilovers in my jeep with the stock control arms. I have had the fronts put in but the rears are coming in the next week or so.
Theres nothing wrong with having a bad *** jeep!!! |
#9 |
Some benefits are:
Set ride height by adjusting collar on top of the springs Springs are always straight and never bow Springs will never fall out or unseat King offers an external compression adjustment ( $80 each ) but you take them apart and adjust it. Just have to get it refilled with nitrogen or whatever gas is in them Can also adjust rebound as well You can always have them rebuilt instead of replacing them A few cons price You can't really mount them in the existing shock locations... outboarding requires cutting on the frame and a tight squeeze between the tires and frame. My solution was this... ![]()
1.) Jesus 2.) Wife 3.) Jeep 4.) myself |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
