TJ Center Bezel Swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > TJ Center Bezel Swap
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 02-09-2012, 08:22 PM   #1
eastcoastxj
Ok, so I did this two weekends ago, I didn't find a whole lot of information on this so maybe this will help someone. I have a '99 TJ and wanted a place to put more switches that looked factory. I couldn't go with a Spod because I have a Tuffy overhead console. I didn't want to go drilling holes all over the place and make my jeep look tacky. This is actually really easy and will turn out great if you just have a little patience.
Total time with this project without wiring switches: 1-2 Hours
Cost: 4 switch bezel without switches $25
03-06 center bezel without vents $50
OTRATTW switches $15 each
Now, first off, I know you can just go and straight up buy all the parts and swap them out, but that includes tearing down the entire dash which will be an all day job if you haven't done it before.
First start by popping off the defrost vent piece, which can be done by carefully prying it up with either a panel popper, or a flat head screwdriver. After that, remove the screws holding the center piece in with the vents, don't forget the one behind the ash tray.
If you went the route I did, I got the new center bezel without vents, which is fine, it saved me 25$ and they just snap out and snap back in the new one.
Now, On your new 4 switch bezel the only modification you will need to do is sand off the locator pin on the passenger side. now that you have that sanded off you can test fit this piece in your Jeep. Loosely screw the two left screws in place till they just touch the plastic, and begin to draw the bezel up. grab your sharpie, and mark where you will need to clearance the vent duct behind the new 12 volt outlets. which isn't much, but enough to make it not fit.
I grabbed my DeWalt rotary trimmer and made short work out of the dash. keep in mind when you turn your fan on little plastic shavings will fly everywhere, watch your eyes!
Now you will have to plug this back up else you will be cooling the back side of your switches leaving you with no air out the vents. Screw your switch bezel back on again, this time it should sit flush to the dash, drill your two holes on the right. I didn't use speed nuts yet as I don't plan to take these in and out very often, over time I will probably have to add them. Make sure everything lines up. I used a piece of HVAC duct I had lying around, it was easy to work with and bent right to the shape in about 15 minutes of work. I went with a 1/2" overlay then about 3/4" to 1" deep, width will depend on how much you clearanced. Test fit this piece in place, drill two holes for rivets, I used roofing cement (bad idea as it still smells when I turn the heater on two weeks later) Use something odorless to caulk the seams around it and rivet it in place.
Wire your switches, any existing will just snap back into this one. I added some OTRATTW laser etched switches in the blanks that were left after I replaced my factory fog light switch. They were very snug and pushed right in. On that note, OTRATTW's Website states that you should not mount these switches in this location due to light bleed from the top light. All I did was not wire the switches to the running lights as the switches are very bright, and can be a safety hazard at night.
Now the last piece is really easy, grab the new 03-06 center bezel and flip it over, in the middle by the retaining tabs are two locator pins, grind those off and the bezel will now snap into your jeep.
So now for the last fitment issues. The radio in the earlier TJ's was farther back in the dash as you notice in my picture. All I did to fix this was to add longer screws and a 1/4" x 1/2" spacer on each of the longer screws on the radio to bump it out. The temperature dials are just slightly set back as well, I took a paint stirrer trimmed to fit and screwed the climate controls back in and perfect fit.
This is the radio before I installed 1/2" spacers with longer screws.
This is the radio after I installed 1/2" spacers with longer screws.
If anyone would like more pictures please let me know and I will do my best to get them as soon as possible.
Yes, I could have install a 03-06 radio adapter to fill the opening, but I want to install a different radio with a different DIN size in the near future, so I haven't changed the adapter yet. The gaps don't let any light shine through, I'm happy with how everything turned out. I could have gone with the two bezel mod, but I decided to go this way as this in my opinion looks cleaner, and will ultimately give me places for seven switches, vs six.
Last edited by eastcoastxj; 02-11-2012 at 07:46 PM.. Reason: Added finished picture.
eastcoastxj is offline   Reply With Quote
Unread 02-09-2012, 08:35 PM   #2
PlaneJob
Hey, did you know for 19 bucks each you can get factory looking switches that snap into that bezel and have a variety of labels on them.
Here's a factory snap in switch for an air compressor
Here's one for fog lights
One for "Bunny Burners", whatever...
And a simple ON switch that lights up when you switch it to on
I added an on off switch to mine to control the On board air, then I saw the compressor switch in the factory style, I might swap it out...
PlaneJob is offline   Reply With Quote
Unread 02-09-2012, 08:40 PM   #3
eastcoastxj
At the time I had planned everything out, all I found was the simple "On" switches. I figured I was ordering switches from OTRATTW for my heated seats anyway in a on/off/on and I was going to add them in the square to the right once I had time to properly wire them instead of just sticking the Grand Cherokee controls down in the place where the airbag disarm should be. When I order the factory replacement switches I didn't modify the holes and they will snap in.
Unread 02-09-2012, 09:01 PM   #4
vanek11
No offense but I would have just got the switches that fit in the factory openings and/or done the ashtray replacement where you get another factory switch bezel and install them side by side. The area where the radio looks exactly what you were trying to avoid, a round opening with a rectangular radio? Why would you want to do that just for some switches?
vanek11 is offline   Reply With Quote
Unread 02-09-2012, 09:26 PM   #5
DerekXJ
Would you be able to use a dash kit from an 03+ wrangler for your head unit
to fill the oval stereo opening in the bezel?
Check out and Comment my build thread!!!
[url]http://www.jeepforum.com/forum/f22/project-lucky-lady-1298306/[/url]
DerekXJ is offline   Reply With Quote
Unread 02-09-2012, 09:36 PM   #6
vanek11
That would be a necessity in my opinion......
Unread 02-09-2012, 11:37 PM   #7
AKGeo
That looks like warmed-over dog vomit and a monumental waste of time.
AKGeo is offline   Reply With Quote
Unread 02-18-2012, 07:30 PM   #8
1999TJRED85000
Crutchfield sells a stereo mounting plate for a few bucks, and it fits without showing the edges of the interior plate or the edges of the stereo mounting sleave.
1999TJRED85000 is offline   Reply With Quote
Unread 02-18-2012, 08:18 PM   #9
2jhanna
I always liked this set-up.
http://www.jeepforum.com/forum/attac...nels-dashs.jpg
jhanna
denton county, tx
2jhanna is offline   Reply With Quote
Unread 02-18-2012, 09:04 PM   #10
silver97tj
Hi all
I had the same problem with the gap between radio and hole visible after radio install. So I bought off ebay, a sheet of plastic, 12 x 12 inches, with a glossy side amd a textured side. I made a template of card board, taking radio and bezel on off several times, to get it just right. Then I used a dremel to cut the plastic using the template. silicone beads to held it in place, put radio and bezel back in, and whola! it looked better and it was cheap fix under $10.
1998 Blue TJ, 4 Cyl., Auto (30rh), Hardtop with installed Sunroof, mostly stock.
31x10.5x15 Mud Tires, TJ Rubicon springs, Mopar Deep Trans Pan and Cooler
Army Vet and proud of it! Have you served your country?
Support our Troops!! Thank You!!!
silver97tj is offline   Reply With Quote
Unread 02-18-2012, 09:08 PM   #11
DerekXJ
Originally Posted by silver97tj
Hi all
are you saying a dash kit from an 03+ TJ wouldnt fit his dash at all? It would be a REALLY easy 10 dollar solution
Unread 02-18-2012, 09:19 PM   #12
eastcoastxj
I'm pretty sure that it would, I haven't bought one because I want to install a din and a half radio. I know the screw on the right will line up, I just don't know about the one on the left. I know on my dash the left screw is on the bottom and not the side. Maybe someone with a 03-06 dash can take a quick pic of what the adapter or stock radio looks like installed. If not ill just go buy one on monday, install and post my pics.
Unread 12-09-2012, 08:01 PM   #13
znhunter
How do you wire up the second power point ? do you need to use a relay and a inline fuse?
znhunter is offline   Reply With Quote
Unread 12-09-2012, 08:11 PM   #14
eastcoastxj
I wired a 7 fuse accessory power station under my passenger seat where the stock jack would go to provide it with power, the one i used was from Painless Wiring and I ran one lead up the center console to the new power port. The nice thing I found about the Painless wiring fuse block was that some are accessory hot and some are constant hot.
Unread 12-09-2012, 08:37 PM   #15
2jhanna
I used 1 of these. Available from any parts store. Very easy to use. I unplugged a fuse behind the glovebox, plugged the "add-a-circuit", then plugged both fuses in. The pigtail is for the new outlet. very clean with no cutting splicing.
http://www.amazon.com/Pico-0956pt-Mi.../dp/B001QRSBW0
jhanna
denton county, tx
bezel , swap , switch bezel , switch panel , upgrade
