#1 | |
Tj Braking is terrible
Is it that all TJ's are terrible at braking? It seems like I can't get my wheels to lock up if I tried. I have to begin stopping twice as far as my subaru and I have to apply what seems like a ton of pressure on the petal.
Recently went and picked it up in Tucson and my father said his buddy who is a mechanic just put new brakes on it so maybe they just need to be taken in and adjusted? Any ideas?
#2 |
it's probably because you run a 33
mine takes a while to stop too, and i can definitely tell the system wasn't designed for tires bigger than 30s when i have the money i'm going to upgrade to some ebc yellow stuff pads and centric premium rotors http://www.jeepforum.com/forum/f9/ebc-yellow-stuff-brake-pads-centric-prem-rotors-599703/?highlight=yellowstuff i would love the vanco system but it's a little out of my price range right now ![]() |
#3 |
I guess it could be the tires, but I used to have a full size blazer with 35's and don't remember it being that bad. Then again I was probably just used to it. I guess I just have to upgrade them eventually.
#4 |
2010 JKU Rubicon 3.5" AEV , AEV Pintlers 35" KM2's , AEV Bumpers, AEV Hood / Snorkel 2008 JKU (Daily Driver) 2000 TJ Auto 4.5 RE Superflex ,35" MTZ 's , Warn ,Viking, LoD, RockHard,AEV, JKS, ARB's, Vanco Big Brake Kit ,Currie etc. etc.etc. |
#5 |
yes the brakes are terrible. the full size blazer had better brakes in it then the TJ.
If I can get there I can wheel it! CentralMass4wd.com 1993 Ranger 2wd - dd 1999 wranger 2.5 - it gets used for something 1978 international scout - being built 1998 Cherokee sport 4.0 auto 1957 CJ5 - restoring back to stock http://www.jeepforum.com/forum/f8/restoring-57-cj5-stock-build-thread-553649/#post5168554 Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900 my build http://www.jeepforum.com/forum/f9/my-build-thread-those-us-low-budgets-550786/ |
#6 |
Demonic Jeep Freak!
Why would you want to lock up your brakes?(skid)
#7 | |
Now in the 937
I noticed you have an automatic. The trans is constantly trying to turn the wheels against the brakes so that is a huge amount of why it is so much worse for you.
My Jeep can stop 33s alright, they're a bit touchy in the rain but otherwise are acceptable. Vanco is the best option if you want it to stop stupid-fast.
The lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase Build thread here. Quote:
Pictures of it wheeling at Bill's 491 And more pics from that trip here! |
#8 |
Team CANON
I have a factory set-up. 30"s (sahara). I was running too much air in my tires. I lowered a bit and my Jeep actually stops now, instead of lock n' slide. The paint on the roads was the worst, major sliding on painted markings, especially when damp. Jeeps are light especially the rears. And the drum brakes in the rear don't help, right?
iPhone Uconnect Software FIX is available 2/5/11 MYGIG Database Thread I appreciate all of the info & good people on this site. JK Sahara 2dr |
#9 |
Brake Wizard
You don't, but if you can't, then how much braking performance are you leaving on the table?
Are you 1% away, 10% away, or even more from being able to lock them up? Perfect braking is being able to maintain threshhold during a braking event. That is the fine line between rolling and skidding. If you can't get there, then you need to be able to.
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#10 | |
Brake Wizard
The trans only does what the motor tells it to.
#11 |
uh did your cousin check to see if the brakes needed to be replaced? or did he replace brand new ones with brand new ones?
you guys think fatter or wider brakes will help? |
#12 |
Brake Wizard
What did you just say?
#13 |
33's should not be giving you a problem, i run 37's on stock brakes and i can lock them up no problem.
03 Rubicon Stock.....Till spring :) |
#14 |
Brake Wizard
Go away, you have no pertinent information for this thread.
#15 |
Running Secretly Amok!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
