Tj Bodylift Install Questions Please Help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Tj Bodylift Install Questions Please Help
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 01-24-2007, 10:25 AM   #1
97TJnSC
Alright this weekend is it.. Im going to install the 2" Bodylift on the jeep. But after reading the instructions I have some questions.... this is going on a 97 tj auto 4L
When it tells you to modify the 4x4 shift linkage how exactly do you do that? It tells you to measure transfer case upper shift linkage and adjust the 4wd shift linkage to measurement.. how do you do this?
Also in the kit it has 8 spacers the same size, 2 really fat ones, and one smaller diameter one.. where do i put the odd size ones?
im guessing the fat ones go up front to help suppost the added weight of the motor, but thats just a educated guess..
in the directions it has everything with a specific number but the pics are blurry and it doesnt have a index of what the parts are..
anyways thanks for the help. hopefully i can get this done that way i can get a BB in the very near future..
97TJnSC is offline   Reply With Quote
Unread 01-24-2007, 10:34 AM   #2
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The kit should come with a bracket for the linkage. You just bolt it on.
The 2 fat spacers go on the body mounts that are right next to your rear upper shock mounts.
I'm not sure about the smaller spacer, but I'd guess it goes up front in the center under the radiator. All the other body mounts are symetrical and are in pairs.
Check out the BL write-up below:
http://www.4x4xplor.com/bl.html
Wheelin98TJ is offline   Reply With Quote
Unread 01-24-2007, 10:36 AM   #3
97TJnSC
yea but what exactly is ittalking about measuring? Once i pull the ****fer off i will probably be like wtf did i ask that question for lol!
how long do you think it will take me to install the BL?
Unread 01-24-2007, 10:40 AM   #4
97TJnSC
why did it ***** out shif-ter? lol
Unread 01-24-2007, 10:47 AM   #5
Wheelin98TJ
JEEP FREAK
If all goes well, you can have it done in an hour or 2.
You must have switched the f and t in shifter. Now stop being such a potty mouth, would ya?
Unread 01-24-2007, 10:47 AM   #6
Crashnburn80
Your also going to need to relocate your radiator fan shroud or convert to an electric radiator fan.
Crashnburn80 is offline   Reply With Quote
Unread 01-24-2007, 06:40 PM   #7
97TJnSC
yea i read where you have to drill new holes for the radiator.. thats not to complicated.. im more worried about the shift linkage for 4wd
Unread 01-24-2007, 07:02 PM   #8
Rocky529
Jeep
Rocky529's Avatar
It should come with a drop bracket that you can install.
Your safest bet, and best bet, is to install an Advance Adapters relocation bracket which completely relocates the linkage off the body of the Jeep. This allows the linkage to "float" off of the transmission and allow you to shift smoothly into 4hi and 4lo... and also eliminates any rattles the 2" body lift will cause your linkage.
AA Part Number 715542
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Unread 01-24-2007, 07:07 PM   #9
RnEmOvr
Will tow
RnEmOvr's Avatar
i have the PA 2" bl and the directions that came with it were great, you can download them off there site, and kit was very complete
took lill over 3 hours including a wash
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
FBI data shows that 323 murders were committed with rifles of any kind in 2011. In comparison, 496 murders were committed with hammers and clubs, and 1,694 murders were perpetrated with knives.
RnEmOvr is offline   Reply With Quote
