TJ body mount locations (pictures?) - JeepForum.com
post #1 of 4 Old 06-14-2009, 08:39 PM Thread Starter
rikkards
rikkards's Avatar
I came across this thread for the YJ:
http://www.jeepforum.com/forum/f12/body-mount-bolt-locations-bl-detailed-write-up-w-pix-705291/
And was wondering if anyone had done something similar for a TJ? It's mostly the ones second from the back that I am interested in and would rather not drill more than once
I am toying with the idea of doing a body lift and would like to drill small holes in the tub to be able to soak the bolts on the inside with PB blaster.
It would be great if someone has pictures!
rikkards is online now
post #2 of 4 Old 06-15-2009, 12:19 AM
jerrym_7758
http://www.roughcountry.com/install/1157.pdf
2005 LJ Unlimited, 4.0 I6, Dana 30/44,
3" Suspension Lift, 1.25 BL, Discos, 35" MTR, Flowmaster
Exhaust, Power Door Locks With AutoPage Remote Start, XRC8 Winch,
Custom Bumpers, Front And Rear Tube Fenders, Alpine CDE-123 Head Unit,
13W1V2 JL Audio Subwoofer, A1400 JL Audio Amp
jerrym_7758 is offline
post #3 of 4 Old 06-15-2009, 12:47 AM
mudb8
want it rite or rite now?
mudb8's Avatar
cut the thee center mounts on each side off and weld them higher up on the frame.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #4 of 4 Old 06-15-2009, 04:55 AM Thread Starter
rikkards
rikkards's Avatar
Thanks for the advice and links but if you looked at the other thread, he showed where in the tub to drill to spray PB Blaster on the bolts from the inside. The first link explains how to add a body lift. That I already know.
Moving the body mounts is a bit extreme.
YJ Body mount locations mark12010 YJ Wrangler Technical Forum 6 10-12-2016 07:55 AM
Body Mount Bolt Locations (For BL) - Detailed Write-Up W/ Pix CheapSunglasses YJ Wrangler Technical Forum 107 06-20-2016 04:37 PM
Lets see you CB mount locations N2rock JK Wrangler Technical Forum 35 02-04-2010 08:56 PM
Body Mount etc. Pictures/Description Alfons YJ Wrangler Technical Forum 0 05-12-2009 10:16 AM
11 Body Mount Locations BRad704 YJ Wrangler Technical Forum 4 01-05-2006 05:00 PM
