TJ axle swap - d35 to d44 will brake assemblies swap
#1 | |
Hey does anyone out there have any experience with upgrading from a D35 to a D44 axle assembly? I need to know if drum brake assemblies will readily swap out from D35 to D44 ? Need help fast as D35 is going to fail soon and want to upgrade to stronger axle. My TJ is a1997 TJ Wrangler Sport. The axle I intend to swap into it is a 1998 D44 with Tru Trac .Thanks for any help. Birdman.
Last edited by birdman52; 08-19-2005 at 07:07 PM.. Reason: Need to add jear of TJ involved |
#2 |
Yes, they will swap straight across. I did that when my original D35 was replaced with a D44. Drum brakes came right over from the old axle.
#3 |
Ahhhh.....One of the many benefits of a D35 to D44 swap.
2012 JKU Rubi,Auto, 4.10's, All black including hardtop and fenders. : P 99 Sahara D30/44 w ARB's and 4.10's, Warn 9.5TI,AA SYE & Wood's shaft,Raingler nets,Jeeperman trail skids,Warn gas tank and steering box skid's, BDS 2" springs, Currie control arms,32" MTR's,AEV Bridger wheels, custom made tire carrier bumper,Dynomax cat back JKS quicker disco's.PSC Trail Cage,Banks header,LiteDots.PSC Trail Corners. 92 CDN M101 trailer, 33" TSL Swampers,camo paint. Original camo tarp. |
#4 |
#5 |
If you go with a Rubi44 you will need to machine the backing plate a little bit to make it work.
*2004 TJ (Mine)* 1984 CJ-7 Buggy Project (Mine)* 1977 CJ-7 (Hers)*2005 Nylint Crawler (The Kid's) RedCell Motorsports http://www.myspace.com/redcellmotorsports |
#6 |
mine did ....
#7 |
Hey I'm doing this swap soon, I was going to post this today, but I'll just post it here. I was asking if the same drive shaft will work when doing the swap.
Edit: Just read through the link of the write-up. Answered my question.
Jimmy 97 Sport 5sp, 2"BB w/DT3's, AR-767, 32" Mud Rovers 01 Sport 5sp, stock 03 Rubicon |
#8 | |
If you use the dana 35 driveshaft, you'll need at least a 2" lift because the dana 44 is longer. Without the lift the driveshaft spline may slide back and damage the shaft coming out of your tranfercase. Always jack it up without the shocks on till the axle bottoms out on the bump stops and watch to make sure the drive shaft doesn't hit the shaft in the transfercase. A very small lift will allow you to use the dana 35 driveshaft. The Dog .. ![]() |
#9 |
tj d35 to d44 axle swap - brake back plate (support plate?)
Thanks for the replies to my original post!! Another question about brake assemblies............does direct swap also mean the brake back support plate will fit also as the axle I'm getting is new and comes without any brake hardware including back plate???? Thanks again for any info. Steve K. (a.k.a. birdman52)
#10 |
Do it right or not at all
![]() Join Date: Jan 2003
All Dana 35c and Dana 44 brake assemblies and parts are 100% interchangeable.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#11 | |
If you mean the black plates behind the brakes that the E-brake cable is attached to, yes, it will be used in the swap. I just hung it out of the way without disconnecting the cable to the E-brakes. The dana 44 axles are quite different than the dana 35 axles. The retaining plate, ring, and bearing all get pressed on the axle. This is why the dana 44 axle will not fall off like the dana 35 will when an axle breaks. You can limp home with the front differential. Stu olson has some good write ups on brakes and axles that will help. http://www.stu-offroad.com/index.shtml The Dog .. ![]() |
#12 |
D44 swap
Thanks a lot to all who responded to my questons of D35 to D44 swap. I got my D44 and OME 2 1/2 lift is on the way. Now I'm looking at some Eaton steel wheels in 15 X 8 size but don't know what backspace is available at "nwt online". Anyone know about Eaton wheels and where to go for info on weekend about backspace available. Maybe they match up with tire & wheel package for Jeep TJ? Thanks again. Da Birdman.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
