TJ adj. control arm length - JeepForum.com
post #1 of 15 Old 05-23-2010, 07:10 PM Thread Starter
champelite210
I know there is a link on here telling what the lowers and front uppers should be for so much lift but all I could find was one for an XJ. Are they the same? If not any one no where it is or how long they need to be for RE 3.5 springs? Thanks
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump PSC steering Bx, XRC 8000 winch.
champelite210 is offline
post #2 of 15 Old 05-24-2010, 04:29 AM
njbowhntr
Just crawled out from under jeep.
Uppers = 15 1/2" center bolt to center bolt
Lowers = 17 3/16" " "
The jeep was just aligned by OK4WD in March.
Ron
US Navy 1993-'97
njbowhntr is offline
post #3 of 15 Old 06-18-2010, 09:20 AM Thread Starter
champelite210
Found a link that said about 16 1/2 for the lowers at 4" of lift. Is there any problems that occur if you run them any longer. I've heard some talk about the main thing is having the tire centered in the wheel well. Any opinions?
post #4 of 15 Old 06-18-2010, 09:37 AM
glockster
My RE adj lowers are set at 16" center to center. 1/4" longer than stock. This is also the length of the RE fixed lowers for their 3.5" or 4.5" springs. No real need that I am aware of to go any longer. Currie uses the stock length of 15.75" on their 4" lift and that worked real well on my 97 tj.
Marco
glockster is offline
post #5 of 15 Old 06-18-2010, 09:41 AM
Coils Rule
there all going to be a little diffrent the pinion angle is what is important
Rockcrawlin' is lame.
Coils Rule is offline
post #6 of 15 Old 06-18-2010, 09:44 AM
JCWJEEP
2010 JK Wrangler
This.
Some people extend their lowers out as much as they can get away with to cheat a little extra wheelbase. The uppers will all be different to accurately set your pinion angle.
JC Whitney Jeep Team
JCWJEEP is offline
post #7 of 15 Old 06-18-2010, 09:44 AM
lumpster
lumpster's Avatar
The most important thing about control arm length is making sure everything clears. You have to check it at full compression also, not just ride height. If you only drive it on the street you may get away with centering the wheel in the wheel opening, but not if you take it offroad much.
lumpster is offline
post #8 of 15 Old 06-18-2010, 09:51 AM
Coils Rule
I should have elborated a little. Your not trying to point the pinion at the output shaft like you would with your rear end you want to "flatten out" you pinion angle to get the correct caster/camber. Looking at mine by eye ball it is almost level maybe even slightly down.
post #9 of 15 Old 06-18-2010, 09:59 AM
06WranglerX
I am re setting my lowers/uppers soon, and I was going to set the lowers at 15 3/4 mabe 16, then the uppers too 13 1/2. Most likely I will not used exactly 13 1/2 for my uppers since my main focus is just getting the pinion angle back in alignment. If i were you I set the lowers to 16, and then just focus on getting the pinion angle correct, just make sure you stay within the boundaries of the control arms and how far they can be adjusted.
Originally Posted by lumpster View Post
he made it clear when he said he was. He didnt ask for a photo ID of you did he.
People need to be a little more trusting, Its not like we are on a convict and rapist forum.
Upon further reflection I've decided I've had enough of this BS and you are now on my ignore list.
06 Red Wrangler X 6 speed hard top
Ford 8.8 Detroit locked, 4 inches of lift, 33 inch BFG KM2's and some other stuff.
06WranglerX is offline
post #10 of 15 Old 06-18-2010, 11:38 AM Thread Starter
champelite210
Well the 1st reply I got said 17.5 which I thought was a little much unless he's comp cut or has extended wheel well openings. I'm gonna set it up for about 16 1/2 and see how everything clears. Thanks for the replys. Once I get this done I'm gonna submit it for Tj of the month. It's gonna be sweet. It's based of of Redlyners rig.
post #11 of 15 Old 06-18-2010, 11:56 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
16.5" might be a bit long.
Especially in the rear with your 8.8 axle.
You will likely run in to clearance issues with the diff cover and the gas tank skid.
Wheelin98TJ is offline
post #12 of 15 Old 06-18-2010, 12:32 PM
LDO
I was told from Rusty's with their adj lowers and my 3" lift the front should be set to 16.5
LDO is offline
post #13 of 15 Old 06-18-2010, 02:04 PM
Imped
Imped's Avatar
There isn't any EXACT length. You need to know enough about your constraints to set the arms correctly for your setup. Ideally, you want to maximize wheelbase while preventing contact anywhere @ full bump all while running proper pinion/caster angles. It can come down to a game of fractions of an inch. If you don't care and just want to set the arms and go, set the lowers @ 16", maybe a hair more and set the uppers for pinion angle in the rear and find a good mix of pinion/caster up front.
OlllllllO
IndyORV
Imped is online now
post #14 of 15 Old 03-07-2011, 08:53 AM
epeck87
i have 4" suspension lift and my lowers are at 16 which is perfect for me. the uppers will vary for caster/pinion angle like most others have already said
Associates Degree in automotive technology
A1-A8 ASE MASTER CERTIFIED TOYOTA MECHANIC
epeck87 is offline
post #15 of 15 Old 03-07-2011, 10:57 AM
Imped
Imped's Avatar
Because I'm sure, 9 months later, he was still trying to figure this out.
OlllllllO
IndyORV
Imped is online now
control , control arm , length
Control arm length? white305 TJ Wrangler Technical Forum 6 02-01-2010 09:18 AM
control arm length Easton04 TJ Wrangler Technical Forum 10 10-23-2008 11:44 AM
Control arm length ? piperpilot3tk TJ Wrangler Technical Forum 0 03-16-2008 04:00 PM
Control arm length Turner-2000TJ TJ Wrangler Technical Forum 2 07-17-2006 10:59 AM
Control Arm Length ovk TJ Wrangler Technical Forum 3 10-06-2003 09:32 PM
