Quantcast TJ AC to OBA - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > TJ AC to OBA
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 03-24-2008, 01:08 PM   #1
prox621
TJ AC to OBA
Going to covert my AC into a on board air setup. I have found a pretty good thread on the whole conversion done on a cherokee. Just wondering if anybody has any tips for doing it on a TJ that may help along the way. Aloso any good sources for parts. I have most of the fittings just need to decide on a filter, oiler, pressure switch and tank.
prox621 is offline   Reply With Quote
Old 03-24-2008, 03:19 PM   #2
Sbeltinc
I've burned up two stock pumps trying to use them for OBA, I do not believe the design can handle the abuse (despite what you might read on the net).
The 2nd pump I used an HD oiler (not a mister) and streamed a continuous stream of oil into it and it still burned up after a few heavy uses.
Sadly I suspect the only real solution for high-volume continuous air is to graft in a big heavy ugly York pump.
My used TJ parts for sale at:
http://roadracing.20m.com/photo_1.html
Sbeltinc is offline   Reply With Quote
Old 03-24-2008, 03:33 PM   #3
prox621
Thats not what I was hoping to hear. What are you considering heavy use? Anybody else have similar experiences? May have to start looking for an older style internally oiled york compressor. Is that the way to go?
Old 03-24-2008, 03:43 PM   #4
BILL G
I done mine, 2 friends have done theirs.No problems yet.Pumping air is no way near the abuse it gets in its intended use as an a/c pump where it cycles more often and runs for extended times.
BILL G is offline   Reply With Quote
Old 03-24-2008, 03:47 PM   #5
BILL G
A couple more pics
Old 03-24-2008, 03:51 PM   #6
BILL G
And one more of the manifold.I have a 2 1/2 gal storage tank mounted under the Jeep.
Old 03-24-2008, 03:51 PM   #7
igofshn
Locked @ both ends
igofshn's Avatar
I did my TJ 6 years ago and it still works great. Never a problem. I have a 2.5 gal tank along the frame rail on the drivers side.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
[Jeep Pics
igofshn is offline   Reply With Quote
Old 03-24-2008, 04:41 PM   #8
ThUmPeRcOn
Hmmmmm
The original point and click interface was a Smith & Wesson.
ThUmPeRcOn is offline   Reply With Quote
Old 03-24-2008, 04:44 PM   #9
kizer
I've got a buddy with one in his 2.5L and he often lets me barrow some air after he fills up his 36-inch tires. Im running 33's and all we ever have done is let it cool down for a minute or two between filling up his then mine.
Links4Jeeps.com
1600+ Write-ups, and more
My Writeups | My Heap
kizer is offline   Reply With Quote
Old 03-24-2008, 04:49 PM   #10
sryan2k1
Originally Posted by thedirt View Post
1) Can I still use the AC unit for actual air conditioning or is it some sort of permanent modification that makes it into a permanent air compressor?
2) How much is involved in modifiying it to do something like this?
3) Is a tank required for something like this or can I hook it straight up to the tires to air them up?
4) Anyone have a write up?
1. No, its pretty much a one way thing.
3. You would want a tank.
sryan2k1 is offline   Reply With Quote
Old 03-24-2008, 04:51 PM   #11
BILL G
No you can only use it for one or the other.You need some kind of pressure switch and I would reccomend a storage tank.It will pump way more than the 150psi that I have mine set to shut off.
Old 03-24-2008, 04:55 PM   #12
kizer
Depending on where you live AC is totally useless. I live in the Washington state area and honestly doors off, bikini top on doing 35+ there is no need for AC.
Links4Jeeps.com
Old 03-24-2008, 05:25 PM   #13
lovelegos18
http://www.bsjeepers.com/viewtopic.php?f=11&t=80
here is a great write up now it is a priviate club not sure if you will be able to see it without registering
lovelegos18 is offline   Reply With Quote
Old 03-24-2008, 07:15 PM   #14
JJs99TJ
i tried, you cant
Originally Posted by rnemovr
oman, what happened in the wreck? i see it bent your bumper, did you hit a camel?
JJs99TJ is offline   Reply With Quote
Old 03-24-2008, 08:01 PM   #15
DOG2000TJ
Junior Member
DOG2000TJ's Avatar
Do a forum search for On Board Air. Make sure you check out Stu's site, he has a really good set up. Kilby also has some great info.
I have AC in my TJ and I am planning on doing the OBA mod this summer. The initial plan is to keep the AC, but we'll see how that goes. I like the AC when it's hot and humid here in the northeast. I also don't mind it when I'm traveling out west.
"Ah beer, the cause and solution to, all of lifes problems" - Homer Simpson
DOG2000TJ is offline   Reply With Quote
Glock Forum
