TJ 5.2 318 swap radiator? - JeepForum.com
post #1 of 5 Old 08-09-2010, 12:18 PM Thread Starter
2000GrayTJ
For the past few months I have spent hours upon hours researching for the 5.2 swap into my 2000 TJ SE and i'm yet to find a definitive answer regarding the correct radiator to use. I am well aware that AA and Backwoods both offer modified radiators for the swap, however, I am on a student budget and i'm not inclined to spend $300+ unnecessarily.
If anyone has any input regarding this issue it would be greatly appreciated. The motor I am looking at is from a '98 dakota, is there a possibility that rad could be used?
thanks
2000GrayTJ is offline
post #2 of 5 Old 08-09-2010, 01:20 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I doubt the Dakota radiator can be used.
Its probably too rectangle shaped where you need something that is more square.
Oconee Off-Road sells V8 conversion radiators starting around $190. I'm using one of their radiators with my V8 conversion and its working fine.
http://www.jeepforum.com/forum/f43/c...iators-498486/
Wheelin98TJ is offline
post #3 of 5 Old 08-09-2010, 03:44 PM Thread Starter
2000GrayTJ
wow thanks, perfect timing, they are one sale til today. $235 sure beats the $320 from backwoods.
post #4 of 5 Old 08-09-2010, 03:45 PM Thread Starter
2000GrayTJ
WheelingTJ, are you using the stock fan shroud?
post #5 of 5 Old 08-09-2010, 09:42 PM
Wheelin98TJ
JEEP FREAK
Yes, I'm using the stock fan shroud.
I was able to use the stock clutch driven fan on the V8 so I did not have to use an electric fan.
engine swap , radiator , tj , wrangler
Radiator Swap wetwilly TJ Wrangler Technical Forum 3 06-15-2009 08:00 AM
Radiator for V8 swap simpsonsdotcom TJ Wrangler Technical Forum 2 03-21-2009 02:55 PM
Radiator swap deaconjeep YJ Wrangler Technical Forum 3 04-23-2007 02:37 PM
Radiator for 350/305 Swap RabiDaWise YJ Wrangler Technical Forum 5 11-07-2004 09:23 PM
Radiator Swap?? 87yjNY YJ Wrangler Technical Forum 2 02-12-2003 01:51 PM
