TJ With 4cyl Lift??? - JeepForum.com
post #1 of 36 Old 04-02-2013, 04:07 PM Thread Starter
hopkincm
I plan on putting a lift on my 97 TJ with the 2.5L. I was wondering what would be a good lift to put on with 33" tires and if I will need an SYE. Anything will help thank you! Also if anyone has any good 4cyl builds that I could take a look at would be awesome too.
hopkincm is offline
post #2 of 36 Old 04-02-2013, 04:09 PM
sjones26573
All lifts are the same whether 4 or 6 cyl. 3-4" will need an SYE. Under that won't.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #3 of 36 Old 04-02-2013, 04:12 PM
JBTJ
But more important, you will need to regear as a grandpa in a wheel chair will be passing you.
You also need to fill out your profile better. "Stock" is to vague of a term. My stock JEEP was no where near what your stock JEEP is.
JBTJ is offline
post #4 of 36 Old 04-02-2013, 04:13 PM
McLovin
What kind of wheeling will you be doing? On my first TJ I started out with a 1.25" JKS body lift and a 2" spacer lift. A 33x10.5 fit perfectly. Later I ran 2" OME springs under the spacers and was able to run 36" TSL's.
I have 4 new zone hydro shocks for sale...PM for a price.
McLovin is offline
post #5 of 36 Old 04-02-2013, 06:47 PM Thread Starter
hopkincm
The problem is that I am not very mechanicaly advanced. I self taught myself with everything I know and go to school for construction. How do I know my gear ratio and all that?
hopkincm is offline
post #6 of 36 Old 04-02-2013, 06:48 PM Thread Starter
hopkincm
I plan on doing some mild wheeling. Mainly keeping the Jeep for a summer vehicle/wheeling
hopkincm is offline
post #7 of 36 Old 04-02-2013, 06:51 PM
sjones26573
You have a 4.10 ratio since you have a 4-banger.
Jeep-Owner.com
post #8 of 36 Old 04-02-2013, 07:03 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
What transmission do you have?...
Knuckelhead is offline
post #9 of 36 Old 04-02-2013, 07:09 PM Thread Starter
hopkincm
I believe I have the AX5
hopkincm is offline
post #10 of 36 Old 04-02-2013, 07:09 PM
McLovin
I believe that all 4cyl 5spd TJ's had 4.10's and auto's have 3.73 maybe?
If your not doing anything to extreme maybe start out with a budget boost or body lift and running some 31"-32" tires. 31's can be used stock, but without additional bumpstops you will rub the fenders on flex when disco'd. Thats a good place to start because budget boosts are cheap, and easy to do. You won't have a lot invested when you decide to go bigger(been there done that) and pretty easy to sell to someone else later.
The body lift is a good choice because it is also fairly inexpensive, easy to do, and will be needed at some point if you decide to do a raised center skid plate or if you do a motor mount lift.
McLovin is offline
post #11 of 36 Old 04-02-2013, 07:19 PM Thread Starter
hopkincm
I would definitely prefer a suspension lift. I hate the look of a body lift and I found some lifts from Rough Country that are in my price range.
hopkincm is offline
post #12 of 36 Old 04-02-2013, 07:26 PM Thread Starter
hopkincm
Originally Posted by knuckelhead View Post
what transmission do you have?...
ax5
hopkincm is offline
post #13 of 36 Old 04-02-2013, 07:34 PM
sjones26573
RC will ride like ****.
Jeep-Owner.com
post #14 of 36 Old 04-02-2013, 07:55 PM Thread Starter
hopkincm
What would you recomend?
hopkincm is offline
post #15 of 36 Old 04-02-2013, 08:06 PM
sjones26573
Zone, BDS
Jeep-Owner.com
4cyl , ideas , lift , tj
