TJ with 4" lift & short arms, any potential probs with this setup? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > TJ with 4" lift & short arms, any potential probs with this setup?
Engo winches available at www.rockridge4wd.com! Free shipp8.8 Swap Kit w/ TRUSS for JeepsBlackMagicBrakes 7% Discount, Save today!
Unread 12-29-2005, 08:49 AM   #1
Ben10281
Hello Jeepforum,
This is my first post so please bear with me.
I am going through the process of scouting out used jeeps to buy. I have found one that I really like, it has a TeraFlex 4" lift on it, not a problem in my eyes, however the owner has notified me that is has short arms on it, instead of the TeraFlex recommended long arms. Can you please let me know what problems I might be opening my self up to if I were to purchase this Jeep. The Jeep does have the TeraFlex Short Shaft Kit(SYE) with the upgraded rear driveshaft as well and 33" BFG tires.
One other question, the owner has told me that he planned on upgrading to Dana 44 Rear Axle when he went to 35" tires, but he didn't get bigger tires so he left the rear axle stock. I have heard many people say that the upgrade to Dana 44 is a must. I will, at first, be doing very light off road stuff and mostly just the short around town and commuting a short distance to work, will the stock axles and stock gears be fine for now?
Any info would be greatly appreciated! Thanks in advance.
Ben
Ben10281 is offline   Reply With Quote
Unread 12-29-2005, 08:52 AM   #2
Pat98TJ
Expect a rough ride.
Jerry Bransford said: "[I][COLOR="Blue"]Ramsey might make decent winches but two friends sent theirs in for repair under warranty and Ramsey wouldn't honor the warranty. Ramsey claimed the winches had been "abused" but I know they had definitely not been abused, they were simply used as we all use them on the trail. [/COLOR][/I]"
Pat98TJ is offline   Reply With Quote
Unread 12-29-2005, 09:08 AM   #3
JSBlu974X4
it wont be too rough with a 4in lift, any over 4.5 it can get rough. also the tera arms arnt too good because the joints go bad pretty easily.
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada
JSBlu974X4 is offline   Reply With Quote
Unread 12-29-2005, 09:17 AM   #4
jeeptj19992001
people have been doing it for years...
once you start you will never start.
seen it done with stock arms
as well with full blown kits.
do what you can afford and build from there
besides the kits you will as have to do drive shafts
then when you think you are finished
you will want to remove the shovel and then tummy tuck it.
it is a never ending saga.....
03 rubi....growing bigger and better every day...
jeeptj19992001 is offline   Reply With Quote
Unread 12-29-2005, 10:05 AM   #5
BigJeepJay
A 4" SA lift is no big deal and you have the SYE so as long as it was all installed properly, you should have a decent ride. As far as your rear axle goes, just don't put a locker in it with the stock Dana 35c.
Pics...
[URL="http://smg.photobucket.com/albums/v516/JeepJay/"]http://smg.photobucket.com/albums/v516/JeepJay/[/URL]
TJ Stretch Thread...
[URL="http://www.jeepforum.com/forum/showthread.php?t=348220&page=3"]http://www.jeepforum.com/forum/showthread.php?t=348220&page=3[/URL]
BigJeepJay is offline   Reply With Quote
Unread 12-29-2005, 04:29 PM   #6
dirtgrip
Ditch the Terra short control arms.Mine ripped off the top rear mount from the frame.It won,t be a problem if you don,t offroad it-otherwise=
Everything else should be ok for now.
Large vacuum leak sucking all the dead presidents out of my wallet.
dirtgrip is offline   Reply With Quote
Unread 12-29-2005, 04:37 PM   #7
otisdog
Go for it. The short arms at 4" are somewhat bumpy but ok. It already has the SYE/CV and that's a big plus. You can deal with the rear axle later. There are several solutions to that. I have a 4" short arm lift [it's mixed] and an SYE/CV. I do have a D44 rear but I bought it that way new.
Now - what about the other things with it? How many miles? 4 or 6 cylinder? What year is it?
Jim
03 Sport
otisdog is offline   Reply With Quote
Unread 12-29-2005, 08:44 PM   #8
ocezam
The #1 item I would look for in a used TJ is a D44. It'll save you a bunch in the long run.
I've got 4" on short arms. No problem there.
'01 TJ. 4"Full Traction. 1" BL/MML. 35" BFG Muds. ARB's front & Rear. Full skids. Warn Winch. Lots of other crap!
ocezam is offline   Reply With Quote
Unread 12-29-2005, 09:07 PM   #9
Spartan302
like dirtgrip said the only problem is the tera short arms
Spartan302 is offline   Reply With Quote
