TJ 4.7 V8 Swap Radiator? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > TJ 4.7 V8 Swap Radiator?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 02-20-2015, 02:26 PM   #1
Shanenindy
I have been running the factory 04 4.0 radiator with my GEN III 4.7. I would like to replace it due to engine temps rising on long uphill pulls. I did some research and know off the normal v8 conversion companies. I found a hand full of people running the 19x26 from speedway motors so I purchased one last week.
Well today I found out a 19x26 that others are running will not work for me in my 04 Rubi. The width is about 3-4 inches too long.
With that being said I would like to purchase a new radiator that is designed for a jeep, so that will not need to make my own brackets.
My questions to guys with TJ v8 swaps are...
Can you recommend a drop in radiator for under $300?
What dimensions are you running?
Thanks for the help
Shanenindy is offline   Reply With Quote Quick reply to this message
Unread 02-22-2015, 12:17 PM   #2
Shanenindy
bump
Anyone?
Unread 02-22-2015, 02:13 PM   #3
rckchucker
I have a Novak radiator designed to fit a TJ with the mount bracket. I had it with my 5.3. Don't know if the ports are in the right configuration for you. Pm me if you are interested in it and we can work a deal out
rckchucker is offline   Reply With Quote Quick reply to this message
