TJ 4.0 Stumble? - Page 4 - JeepForum.com
post #46 of 48 Old 07-30-2013, 07:28 AM
jeeptjrn
I just replaced 02 sensor with no code and hasn't stumbled since
jeeptjrn is offline
post #47 of 48 Old 06-09-2014, 07:54 PM Thread Starter
bmxboy809
ITS BACK!
Similar symptoms, it stutters on the highway or under heavy load. It has been steadily getting worse over the last few weeks, and now has gotten to the point I cant drive it to work. One new symptom is a P1391 trouble code.
So far I changed the CKP sensor and tested the TPS. New cap and rotor.
I pulled the Ignition pickup off the distributor and when I bend/roll the wires it sounds like they may be cracked, possible from heat? I am replacing the Pickup under warranty tomorrow.
also when I was looking around today, I noticed the ECM was pretty warm. I just got back from a 20 min highway ride from work but the ECM seemed exceptionally hot. Should I be concerned about this?
1999 Wrangler TJ 4.0 5spd -- 6" LA , 35" MTZ's , Ford 8.8 , 4.88 gears , SYE , Tom woods CV shaft
bmxboy809 is offline
post #48 of 48 Old 06-12-2014, 05:48 AM
Bville-Bud
Just a heads up, I had a 98 Cherokee with similar issues. Changed the front O2 sensor and fixed it.
http://www.jeepforum.com/forum/f11/c...n-cold-759038/
Bville-Bud is offline
4.0 , missfire , o2 sensor , stumble , surge
