TJ 4.0-how many gallon is the gas tank? - JeepForum.com
post #1 of 17 Old 03-27-2005, 08:54 PM Thread Starter
coppa
Just curious? Also, how much does it take you to fill it from E?
thanks,
Jeff
coppa is offline
post #2 of 17 Old 03-27-2005, 08:55 PM
JeepTJMan
I think it is around 19. Not sure.
JeepTJMan is offline
post #3 of 17 Old 03-27-2005, 08:59 PM
rhelton04
rhelton04's Avatar
Might depend on the year, but my 04 has a 19gal tank. I usually drive for 10 or 15 miles with the gas light on and it takes around 16.5 gallons.
04 X
31x10.5 Wrangler AT/S
RE 2" BB
LOD Rocker Guards
Black - You mean it comes in other colors?
rhelton04 is offline
post #4 of 17 Old 03-27-2005, 09:02 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
there used to be a 15-gallon standard tank...and an optional 19-gallon...
'99 or '00 was the last year for the 15-gallon...after that, 19-gallon was the only tank...
(it's actually the SAME tank...there was just a longer vent tube on the 15-gallon tank so you couldn't get 19-gallons in it)...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #5 of 17 Old 03-27-2005, 09:32 PM
Flendo
Greg
and there's a write up some where on this forum that teaches you how to take that tubing out.....pretty neat
Black Jeep Club Member #64
New Jersey Jeep Club Member #1
1997 Jeep Wrangler 4.0L Sahara (Mine)
2005 Jeep Liberty 3.7 4x4 (mom's)
Flendo is offline
post #6 of 17 Old 03-27-2005, 09:34 PM
MattTheMudder
Ask Mr. Owl
MattTheMudder's Avatar
Greg
I thought all 4's came with 15 gal and all 6's came with 19 gal? Doh, I have a '99 and I thought I had a 19 gal. Cost me $30 to fill up, when gas was $2 a gal, and quarter of a tank left.
MattTheMudder is offline
post #7 of 17 Old 03-28-2005, 05:09 AM
msafrit
I believe it is on gottrail.com/tj, the writeup about the vent hose and how to shorten it for 19 gallons on the 15 gal. tank.
msafrit is offline
post #8 of 17 Old 03-28-2005, 06:47 AM
99TJSport
99TJSport's Avatar
97-99 15 gall was standard on ALL models except Sahara, 19 gallon was an option.
2000 and up 19 gallon is standard on ALL models.
Jeff
08 Rubicon Unlimited, 2.5TF Lift, 285/70/17 BFG KM2s, lots of skids, MyGig, and both sets of doors/tops.
Parrothead Jeepers Union #24
99TJSport is offline
post #9 of 17 Old 03-28-2005, 06:57 AM
rhinoss
I thought the Vent tube trick only worked in YJ's... this is news to me. I'll be doing it this evening
rhinoss is offline
post #10 of 17 Old 03-28-2005, 09:15 AM
linux24
Mine is 19 gallons.
linux24
Jeep newbies and novice mechanics go here:
linux24 is offline
post #11 of 17 Old 03-28-2005, 10:16 AM
skinton
mine has the 19 gallon tank, but it never takes more than 14 gallons (which is about 200 miles. i always run it until the light comes on and fill it until the pump clicks off.
1998 TJ Sport, 4.0L - 5 spd -Suffering from frame rot
2006 Grand Cherokee Overland (5.7L HEMI)
HEMI Club Member #53
2003 M-B C240 4matic
skinton is offline
post #12 of 17 Old 03-28-2005, 10:56 AM
BigWaylon
tubework is cool...
BigWaylon's Avatar
nope...I did it to our '99...
takes about an hour...only cost is buying a new fuel pump seal for ~$10 (not a necessity, but why risk it)...
I did a pseudo-writeup that's around here somewhere...
just reach inside the tank and cut the smaller tube (the one WITHOUT the "ping-pong ball" in it) flush with the inside of the tank...
I regularly get 18.5 gallons in when I fill up now...not sure how much it REALLY holds now...
Greg
post #13 of 17 Old 03-28-2005, 11:01 AM
rhinoss
Greg
Excellent, Did you do anything to recalibrate the fuel gauge? I'm sure that if nothing is done it just registers full until you get below the 15 gallon mark.
rhinoss is offline
post #14 of 17 Old 03-28-2005, 11:03 AM
MattTheMudder
Ask Mr. Owl
What exactly was the point of the 15 gal tank anyway? If they went through the trouble of making it in a 19 gal size and putting it on all of them, why make a different tube?
post #15 of 17 Old 03-28-2005, 11:06 AM
BigWaylon
tubework is cool...
BigWaylon's Avatar
cause they made a little $$ if you "upgraded" to the 19-gallon...
Greg
Has anyone done the 15 gallon to 20 gallon gas tank mod? by modifing gas vent line? tybmw YJ Wrangler Technical Forum 27 05-15-2012 09:15 PM
15 Gallon-20 gallon tank mod help needed! Dhofstet YJ Wrangler Technical Forum 9 12-18-2010 09:56 PM
factory 15 gallon vs. 20 gallon fuel tank?? trickle26 YJ Wrangler Technical Forum 19 06-13-2010 05:19 PM
15 Gallon Gas Tank bringbackphish YJ Wrangler Technical Forum 5 02-06-2009 05:55 PM
hrmm 15gal tank to a 20 gallon tank?? evilpsych YJ Wrangler Technical Forum 4 10-29-2001 06:15 PM
