TJ 32RH to AW4 swap - "super short" or regular SYE? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > TJ 32RH to AW4 swap - "super short" or regular SYE?
ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep Grand Cherokee Tie Rods & Adjusting Sleeves
Unread 03-17-2015, 03:35 PM   #1
bwiencek
I'm putting in the AW4 with the cherokee 4.0l swap that I'm doing on the '99 TJ and was wondering if anyone used the 'regular' SYE kits with that swap or if it really is necessary to do a "Super Short" style slip yoke eliminator kit? I really like the option to use the stock style speedo drive setup and ability to change gearing in it to compensate for tire sizes (since I know I'll probably step up to 33's when the 31's that are on there wear out and the swap is done since it has the 4.10's anyhow...)
32RH = 22 3/4”
AW4 = 25 1/2”
(AW4 is about 2 3/4" longer)
Regular SYE kits say they add ~6.5" to the rear driveshaft length which should be more than enough to compensate for the extra 2.75" of length in the AW4 and still gain some 3.75" in length. The "super short" ones I see are about 3" shorter still which would put the fixed end just a little shorter than what the "regular" SYE is in a 32RH equipped TJ...
Given all that I think I'd be fine running the 'regular' SYE - anyone have any real experience with either?
If I have to go with the short style - any preference of the Rugged Ridge kit vs the TeraFlex kit?
08 Rubicon Unl 4",35" KM2, F&R bumper, etc.
99 TJ - 4.0/AW4/NP231 swap 2.5/1.25 lift, 31" MT/R
bwiencek is offline   Reply With Quote Quick reply to this message
Unread 03-17-2015, 03:59 PM   #2
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
How much suspension lift will you be running?
Will you be running a high clearance transfer case skid plate?
Wheelin98TJ is offline   Reply With Quote Quick reply to this message
Unread 03-17-2015, 04:09 PM   #3
biffgnar
biffgnar's Avatar
Neither, J.B. Conversions.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 03-17-2015, 04:39 PM   #4
bwiencek
Right now it's got 2.5" of lift and I've got a 1" BL in the box that I was planning on installing with a MML but that might change now that I'm in the middle of the 4.0 swap... Probably won't go much more suspension lift and no plans for going with a belly lift unless things get crazy...
Unread 03-17-2015, 04:54 PM   #5
freeskier93
I would definitely recommend the super short with the longer AW4, I would recommend it regardless because it allows room to grow and having the longest shaft possible is never a bad thing. I have the JB Conversons super short with only a couple inches of suspension lift and the 8.8.
As far as switching to tone ring it would make your upgrade to larger tires simpler. Once you gat a correction box you can easily adjust it to whatever combo you have, no having to swap gears. Personally I don't use a correction box, my speedo is only 5 off with my tire/gear combo plus my Scangauge tell me my corrected speed.
CU Boulder Aerospace Engineering
freeskier93 is online now   Reply With Quote Quick reply to this message
Unread 03-17-2015, 08:24 PM   #6
TJ-Bville
X2 JB Conversons
Although I don't have a 231 SYE, have a D300 his customer service is great and quality is top notch
Most LCOG Builds are like a fat girl in Yoga Pants, just cause it fits doesn't mean it works...
TJ-Bville is offline   Reply With Quote Quick reply to this message
Unread 03-17-2015, 08:37 PM   #7
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Literally just finished installing my JBC SSYE and it is very nice.
RnEmOvr is online now   Reply With Quote Quick reply to this message
Unread 03-18-2015, 09:20 AM   #8
biffgnar
biffgnar's Avatar
How's your rear driveshaft angle now?
Unread 03-18-2015, 10:46 AM   #9
RnEmOvr
RnEmOvr's Avatar
Estimated around 21, have to send shaft out to be lengthened
Unread 03-18-2015, 10:51 AM   #10
biffgnar
biffgnar's Avatar
Sounds good. Much better than where you were before.
Unread 03-18-2015, 11:17 AM   #11
RnEmOvr
RnEmOvr's Avatar
Ya, only issue is they forgot the bolt that holds the speed sensor in. Have to find out what size it is. Also as I was installing the yoke nut I realized I forgot the return spring so had to pull it back apart.
