TJ 2.5 to 4.0 swap question... - JeepForum.com
post #1 of 21 Old 07-31-2010, 09:42 PM Thread Starter
saylorjerry
I've read a bit into what a swap would involve, and in my hunt for parts I ran into a question. If 89 and later XJ's used a 4.0 with a AX5 and NP231, what is the issue with putting a 4.0 in front of my TJ's AX5 and NP231? Thanks in advance for any input.
Look to the sky just before you die...it's the last time you will.
saylorjerry is offline
post #2 of 21 Old 07-31-2010, 09:53 PM
moonshinefuel
Ax5's don't go behind 4.0's.
Its a lot of work you are talking about, you will need a new transmission too. Many opt for a V-8 conversion as you will need to replace the wiring harness as well, and weld in new motor mounts. Again an ax5 is a no-go behind a 4.0.
moonshinefuel is offline
post #3 of 21 Old 07-31-2010, 10:07 PM
Ron98jeep
so i would be better off replacing the 2.5 & not attempting
Ron98jeep is offline
post #4 of 21 Old 07-31-2010, 10:17 PM
Ron98jeep
being a previous ford owner, what would it take to install a 300 six cylinder into a wrangler? I've never had a problem with that motor & i would think it would be a powerhouse in a wrangler
post #5 of 21 Old 07-31-2010, 10:27 PM
Ron98jeep
1998 engine swap 2.5 without A/C to 1995 4.0 with A/C
any assistance appreciated
post #6 of 21 Old 07-31-2010, 11:51 PM
Ethan79
obviousl motor mounts/wiring/ecu/tranny... but this would be a goooooood swap. those motors are amazing. they just go and go and go
2000 Jeep Wrangler SE: 2.5 5spd D30 Ford 8.8. Lifted, Locked, Armored, Daily Driven
Ethan79 is offline
post #7 of 21 Old 08-01-2010, 12:04 AM
RogueSpear2023
The problem with the 300 is it has way less HP and torque than the 4.0L I6 has, and it would require the same amount of work a 4.0L and the 4.0L will probably last longer. I would say the best bet if you want to do a motor swap is to do a V8 it's the same amount of work as the 4.0L, ReMoVeR on JF did the 4.0L swap ask him, he says every time this comes up, he wishes he would have done a V8 way more power, and it's the same amount of work. Also the AX5 will not take the power of a the I6, in the cherokees the AX5 was behind a the 2.8L V6 which was a real pooch power and torque wise. So it was never behind the 4.0L, why because it wouldn't last long. All 89+ Cherokees with the 4.0L use the AX15, not sure where you get the info that the AX5 was behind the 4.0L.
Whats involved in the swap
New Engine/transmission 4.0L/AX15, or V8/many options
New motor and transmission mounts
New Radiator
New wiring harness
Also will have to change the input shaft on the t-case.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #8 of 21 Old 08-01-2010, 08:11 AM
Shrek
I did the 2.5 to 4.0 swap. I had a low mile 4.0 donor for free or I would not have done it! Computer, wiring, motor mounts etc. Hell, even the steering shaft mount is different on the 4.0. I wouldn't attempt it unless you're a welder and monster garage type mechanic. To completely rebuild the 4cyl is($1400). Put a V8 in it. No matter what you do, the AX5 is worthless behind anything other than the 2.5.
Having said all that, the 4.0 is a superior TRAIL engine over the V8. Most V8s won't give you the torque at 600-1000 rpm like the 4.0 when your crawling around. On the street or in the mud the V8 would be a panic but for a trail Jeep, the 4.0 is pretty hard to beat.
97 TJ 4.0, AX15, E-Fan, 5" Full Traction Long Arm - D44s /4:88s, 36" TSL/SX Swampers on Cragar Bead Locks, Atlas ll, Outback Extreme OnBoard Air, Hand Throttle, Homemade Sliders, Homemade Rear Roll Cage, M.O.R.E. High Clearance Bumpers, Currie Currectlync Steering, Currie Anti rock, Warn 9.5XP, OR Fab Sport Cage Up Front, I've lost control.
Shrek is offline
post #9 of 21 Old 08-01-2010, 10:16 AM Thread Starter
saylorjerry
Thanks for the clearup and input guys. There must have been a typo in the XJ section on here. Unless I read it wrong. I wsa looking into a V8 because for the dollars I heard it was a better swap, but I really don't need all that power for the running I do. Really the 2.5 does the job, I'd just like to be able to go 70 on the freeway without having to have the wind at my back. I also am not a huge fan of cramming a smallblock into the engine compartment. I've got rather large meathooks and like to have some room to play. Again thanks for the input.
post #10 of 21 Old 08-01-2010, 10:22 AM Thread Starter
saylorjerry
yep...that was my bad, I looked at one and noted the other... it is the AX15 in the XJ
post #11 of 21 Old 08-01-2010, 10:55 AM
gensysmike
I had a shop do my 2.5 to 4.0 upgrade. They did not have to put a new wire harness in. They sent the 4.0 wire harness out for modification to mate to the 2.5. They claim it is better than putting in a new wire harness. It works fine. No issues on my end. If you are interested let me know and I will find out and pass along the details.
gensysmike is offline
post #12 of 21 Old 08-01-2010, 05:14 PM Thread Starter
saylorjerry
how much did the shop charge for the swap? I'm definately interested.
post #13 of 21 Old 08-01-2010, 08:49 PM
JeepN95YJ
LOL @ V8 as easy as 4.0.
I've swapped both. Love the 2.5 to 4.0 swap. Very easy and inexpensive if you shop around. My swap: http://4bangerjp.com/forums/index.php/topic,8673.0.html
The 4.0 doesn't require a modified harness in any way. Simply unplug the 2.5 engine harness from the firewall and computer and plug in the 4.0 harness.
JeepN95YJ is offline
post #14 of 21 Old 08-01-2010, 08:56 PM
JeepN95YJ
I cut and reused the 2.5 motor mounts. The only difference in wiring was the engine harness but it is plug and play. No modification required. Same with computer. The steering shaft didn't need to be touched except to unbolt it while I welded on the frame side motor mount.
I'd hardly call myself a monster garage mechanic. What specific problems did you have with the swap? Did you use a TJ 4.0 and harness?
post #15 of 21 Old 08-01-2010, 09:08 PM
davidchancey
I've also done the swap. Very easy swap I thought. It's alot easier if you use the same year parts. Was also cheaper than regearing. Got the whole swap done for $200 including price of motor.
2000 TJ 4" rough country, 2 inch spacer up front, no t-case drop, 1 inch MML, 35 inch MTR Kevlars, Champion 10,000lb winch, Rockford Fosgate 10 inch subwoofers. Infinity Highs. Sony Head unit, Cobra CB
davidchancey is offline
engine , swap , 2.5 to 4.0
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 05:11 AM
8.8 swap question jeepblackie YJ Wrangler Technical Forum 2 02-10-2009 06:40 AM
4.2L to 4.0L swap question to those who know. Oorin YJ Wrangler Technical Forum 5 11-29-2005 04:53 PM
8.8 swap question EricYJ00 YJ Wrangler Technical Forum 2 11-25-2005 10:13 PM
