Quantcast TJ 2.4l power increase - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > TJ 2.4l power increase
Old 07-26-2009, 11:27 PM   #1
A567
im looking at getting a stage 1 Jet power chip for my TJ. is it any good? has anyone got any suggestions?
4 WHEELIN S*O*B
A567 is offline   Reply With Quote
Old 07-26-2009, 11:43 PM   #2
alex_c
buy a sportscar.
alex_c is offline   Reply With Quote
Old 07-26-2009, 11:46 PM   #3
mikeheverly
^^^^^x2. Wanna go fast? Don't drive a TJ. Or just drive it downhill.
Edit> no I don't have any experience with a Jet chip. But I've found dreaming about ANY performance help for my TJ is a we. dream. Please don't call me a ****** for commenting without any real life experience with a JC
mikeheverly is offline   Reply With Quote
Old 07-27-2009, 01:34 AM   #4
ex m38a1er
I didn't see any comment about going FASTER...
Would you make any"fast" comments to anyone with a 4.0 trying to upgrade the
performance of his engine?
I barely see any upgrade comments for a 2.4 engine.Maybe it's because for a 4banger is strong "enough"
Ohhh I do have a personal experience in this "set up".
Before and after.No miracles but slight improovement in mileage and strength...
I would recomment if you can find it used for half the money...
ex m38a1er is offline   Reply With Quote
Old 07-27-2009, 06:58 AM   #5
Unlimited04
Unlimited04's Avatar
don't get a chip, waste of money. same answer for your other header thread, same with a CAI. you're screwed, swap the motor.
Unlimited04 is offline   Reply With Quote
Old 07-27-2009, 09:15 PM   #6
A567
thanks for the input. im fine w/my jeep. it 4 wheels like a dream.. obviously but id like a bit more power on the pavement
4 WHEELIN S*O*B
Old 07-27-2009, 09:27 PM   #7
incredibull
Regearing is really your best bet for the most noticeable increase in "power".
I don't know if having the head worked over is worth any amount of gain on the 2.4, but it's another possibility.
incredibull is offline   Reply With Quote
Old 07-27-2009, 09:29 PM   #8
A567
ok thanks. maybe i will take a look at it
4 WHEELIN S*O*B
Old 07-27-2009, 09:48 PM   #9
TravisHeim
To get more power out of the 2.4L you could install a PT cruiser turbo setup. Read through this thread http://www.jeepforum.com/forum/f9/turbocharged-2-4l-my-tj-333749/, another JF member Air Sierra already set it up.
TravisHeim is offline   Reply With Quote
Old 07-27-2009, 10:39 PM   #10
A567
Originally Posted by TravisHeim View Post
To get more power out of the 2.4L you could install a PT cruiser turbo setup. Read through this thread http://www.jeepforum.com/forum/showthread.php?t=333749, another JF member Air Sierra already set it up.
sweet thanks.
4 WHEELIN S*O*B
Old 07-27-2009, 10:41 PM   #11
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Power chips barely do anything at all and even then they require the engine to be at wide open throttle and extremely high rpms. Not to mention most will cause your engine to ping unless you run high octane gas. You won't feel any performance difference around town and you won't feel any performance difference on the highway... at least not unless you keep it floored and at near redline rpms. They're a complete waste of $$$ in my personal opinion, unless you plan to race your Jeep at the drag strip.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote
Old 07-28-2009, 05:13 PM   #12
iismet
I have an 05 2.4L - 4400 lbs with my wife and I - 4.88 gears, Jet Stage 1, Airaid filter, Screamin Demon Coil, 1 high flow cat between the rails, and a high flow muffler. I run 89 octane. It drives very easily. I pull a 1/4 ton military trailer with no problem. I5 between Portland and Seattle - 6th on the flats, 5th on the grades. It will accelerate up grades in 5th pulling the trailer. I probably don't load the trailer heavier than 800 lb gross. With the coil added, the computer does not like it if it is lugged too much. It will miss and I have to shift down 1. It rarely sees 4500 RPM and I routinely get 18 mpg pulling the trailer at 67 mph. Seems Areo is much worse then weight.
iismet is offline   Reply With Quote
Old 07-28-2009, 07:09 PM   #13
A567
sweet! mines an 04 5 speed. and i was gonna get an air raid, jet chip, cat back muffler and a header. cause goin to odel on the up hills i had it in 4th pinned and could barley hold 50. thanks for the input
4 WHEELIN S*O*B
Old 07-29-2009, 06:30 PM   #14
iismet
I don't want to mis-lead you. The number 1 mod I listed was 4.88 gears. This is very important and you need to re-gear for the tire size you run. That said, the tuning stuff shines on the highway (provides nothing on the trail). I'm not aware of a header but it will respond to exhaust work. Without regear you will not see benefit. I built mine incrementally and it runs very well.
Old 07-29-2009, 11:38 PM   #15
A567
thanks for clarifing. now how do i regear it?
4 WHEELIN S*O*B
Glock Forum
