TJ 2.4 throttle body spacer - JeepForum.com
post #1 of 6 Old 05-28-2010, 05:28 AM Thread Starter
DiegoTJ
Hello,
Im sorry my English is not very good, Im Spanish.
Im looking back for some information, becouse here is really dificult to know about some things. I have a 2005 TJ 2.4 with 6 gears, and I want to get some engine performance.
There are some people here that mounted Airaid cold air intake sistem, jet stage 2 and throttle body spacer and say that the engine gets amazing improvement, only if you mount the three things. The problem I have is to find that body spacer for the 2.4 engine, and I heard that the model that fits this engine is the same as a PT cruiser. Can you please confirm this to me? Please tell me a reference or link me to a shop so I can search for this item.
Thank you very much.
DiegoTJ is offline
post #2 of 6 Old 05-28-2010, 06:14 AM
03rubiconMG
i found that the air raid intake and an exhaust did increase a quickness of revving a little more power and better gas mileage but as far as a throttle body spacer goes, they way the newer jeeps throttle bodies are designed they already do what a throttle body spacer is suposed to do.
I say do the intake and exhaust but stay away from the throttle body spacer.
Isnt a jet for a carbeurator?
2003 white rubicon on 37s
03rubiconMG is offline
post #3 of 6 Old 05-28-2010, 07:05 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Originally Posted by DiegoTJ View Post
Hello,
Waste of money IMO. Save the money for regearing your axles...
Knuckelhead is offline
post #4 of 6 Old 08-11-2013, 03:01 PM
Sudcalifornio
Hello,
a lo mejor es ya tarde. el motor 2.4l no aplica el uso del espaciador, si quieres agregar algunos caballos de fuerza el sistema de entrada de aire frio ayuda, instalas bujias e3 y el chip stage 1. no uses el numero 2 a no ser que hagas cambios super radicales ojala y te sirva esta informacion yo tengo el mismo jeep que vos
Sudcalifornio is offline
post #5 of 6 Old 08-11-2013, 06:40 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
E3 spark plugs do not/cannot/will not add power. The ONLY time E3 spark plugs will make more power is if the plugs they replaced were completely worn out/totally bad where any new plug would also restore the power.
If you look up E3 in the dictionary, it gives you a picture of a snake oil salesman convincing the gullible to buy his product.
And while spacers work wonders under carburetors & first-generation throttle bodies that had a fuel injector resulting in an air/fuel mixture passing through them, they do nothing when placed under a modern throttle body that passes nothing but air. The fuel is directly injected into the cylinders well below the throttle body.
Jerry Bransford is offline
post #6 of 6 Old 08-11-2013, 08:41 PM
Knuckelhead
AFSOC Retired
Changing to an aftermarket air intake and exhaust isn't going to give the 2.4L engine anymore power.
Any chip is snake oil also...
2.4l , performance
Throttle Body Spacer??? ChiliTJ TJ Wrangler Technical Forum 9 12-22-2008 01:05 AM
Throttle Body Spacer MDJeeper99 TJ Wrangler Technical Forum 23 05-26-2007 11:54 AM
throttle body spacer linkage bracket spacer ? kmo0189 YJ Wrangler Technical Forum 3 09-24-2006 10:42 AM
Throttle Body Spacer???? 1SilverTJ TJ Wrangler Technical Forum 23 05-30-2006 02:22 PM
Throttle Body Spacer deuce94 TJ Wrangler Technical Forum 5 09-02-2004 10:26 PM
