Tires wearing faster outside half of tread. - JeepForum.com
post #1 of 6 Old 12-08-2009, 06:07 PM Thread Starter
chutta
I noticed my at's are wearing uneven. Just checked toe-1/8", 27lbs air and on garage floor measuring with a square, top to bottom they angle in at top rather than the opposite you would expect if camber was off due to ball joints.
No slop with tires off ground with the 6-12 0'clock pull.
All four are doing this. ?
Just swap to letters out to max the life out of them?
It's just something I noticed after a lot of miles on these, but nonetheless the inner blocks have easily over a 5/16" depth, outers maybe 3/16".
Is 1/8" toe too much?
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline
post #2 of 6 Old 12-08-2009, 06:13 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
1/16" minimum with 1/8" toe-in being pretty appropriate for a 33" tire.
Getting
Jerry Bransford is offline
post #3 of 6 Old 12-08-2009, 06:20 PM Thread Starter
chutta
Thought so. Just seemed with the uniformity of the issue left to right, my first guess was excessive toe rather than both side ball joints. Probably have 30-32k on em anyway.
chutta is offline
post #4 of 6 Old 12-08-2009, 08:44 PM
durango-bob
2006 WK
Slow down around corners.
durango-bob is offline
post #5 of 6 Old 12-08-2009, 08:47 PM
fish4life
Actually, my tires are wearing on the outside, and i have a feeling my tires are angled opposite, just like you mention. I was also told it's got to be the toe in, but checked mine just like you did and also was fine.....
Anyone else having this problem but us two?
(I used to rotate my tires frequently before and guess they were never worn enough for me to notice before they got swapped, but haven't done so in a long time now and definitely noticeable).
fish4life is offline
post #6 of 6 Old 12-09-2009, 04:41 PM Thread Starter
chutta
Haha. This thing is too high to speed on corners and besides, my slowness coincides with age, perhaps surely not wisdom
chutta is offline
One tire wearing faster than others TanTJ04 TJ Wrangler Technical Forum 3 12-10-2008 07:44 AM
Left Rear tire wearing faster? deathblade556 TJ Wrangler Technical Forum 4 09-03-2007 09:04 AM
Front tires wearing faster???? Jetmech143 TJ Wrangler Technical Forum 13 10-20-2006 06:46 PM
Right front tire wearing faster then the others... AdamB TJ Wrangler Technical Forum 6 12-18-2005 06:14 AM
Just got 33s, which parts will start wearing out faster now? svaughan TJ Wrangler Technical Forum 21 12-11-2004 03:14 PM
