Tires on stock Rubi wheels with 4" lift - JeepForum.com
post #1 of 12 Old 12-18-2009, 09:15 AM Thread Starter
greenrover
I've already done some searching on tire size conversions etc.
Wondered if I could get some input on what tire size some of you run with a 4" lift and stock Ruicon wheels. This is for a '05 Unlimited Rubicon.
Thanks all.
greenrover is offline
post #2 of 12 Old 12-18-2009, 09:17 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
33's or 35's or metric equal.I don't have rubi wheels,but I run 35x12.50's on stock wheels with wheel spacers.
TheBoogieman is offline
post #3 of 12 Old 12-18-2009, 10:01 AM
Coops
285/75R16's fit with out spacers. Is a bit tight between the rubber and rear frame spring cup though.
Coops is offline
post #4 of 12 Old 12-18-2009, 10:32 AM
WheelN
stock wheels 05 rubicon
I run 285/75/16 MTR on 3.5in lift... Tires are 33inch tall... i have no problems at all
utcTurtle
WheelN is offline
post #5 of 12 Old 12-18-2009, 10:33 AM Thread Starter
greenrover
285x75x16's it is then....thanks for the input.
post #6 of 12 Old 12-18-2009, 10:35 AM
WheelN
mine also 05 unlimited rubicon
utcTurtle
WheelN is offline
post #7 of 12 Old 12-18-2009, 10:38 AM
WheelN
stock wheels rubiconunlimited
no problem have a good day
utcTurtle
WheelN is offline
post #8 of 12 Old 12-18-2009, 10:38 AM
BriansCJ
1994 XJ Cherokee
255/85R16 = 33x10r16
TrXus Swampers
I rub slightly at full turn and when disconnected I rub the fender.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #9 of 12 Old 12-18-2009, 10:43 AM
RubiconRazorbac
RubiconRazorbac's Avatar
315/75-16 MTZs with Spidertrax wheel spacers. Love 'em.
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #10 of 12 Old 12-18-2009, 02:03 PM
Noxian
2011 JK Wrangler
I am running 285/75R16s on Rubi rims, perfect tire size with the stock Rubi flares, keeps the tread of the tire within the flares, which is perfect because its illegal here to have your tires stick out past your flares.
I did have to add 2 washers to the steering stops to keep the tires from rubbing at hard lock on the control arms.
Noxian is offline
post #11 of 12 Old 12-18-2009, 03:40 PM
jrjb973
Junior Member
I run 305/70-16 on my moabs with 1.25" spacers on a rc 3.25" lift and rc 1.25" bl. I still had to add a washer to each steering stop too.
jrjb973 is offline
post #12 of 12 Old 12-18-2009, 05:29 PM
05x
running here-- 315x75x16 MTR's on my Moabs also with Spidertrax spacers on RESF 4.5"
05x is offline
will the stock rubi wheels work on a lift that uses 4.5" backspacing? rballman JK Wrangler Technical Forum 16 12-05-2008 12:33 AM
33 x 11 MTRs (or other tires) on stock Rubi wheels IndyJpr JK Wrangler Technical Forum 0 08-09-2007 06:30 PM
35" Tires on stock Rubi wheels? Roadtrip JK Wrangler Technical Forum 12 12-21-2006 03:41 PM
35'' Tires On Stock Rubi Wheels? 05fulltraction TJ Wrangler Technical Forum 9 11-16-2006 04:26 AM
Anyone selling Rubi Stock Wheels/Tires? FourbyFour TJ Wrangler Technical Forum 6 09-02-2006 10:28 PM
