Tires Size. Should I remove 3" BL? - JeepForum.com
post #1 of 16 Old 06-17-2013, 12:36 PM Thread Starter
Morgan_TJ
I know opions are like elbows but I am looking for some feed back. When I bought my jeep it had a 3" body lift already installed and I have recently installed a 4" suspension lift. I am running 33" tires and I am debating on whether or not to remove the 3" body lift. See the attached pic and let me know if you think there is too much spacing between the tire and fenders. I dont want to cruise around looking like a dork with tires that look to small.
Morgan_TJ is offline
post #2 of 16 Old 06-17-2013, 12:42 PM
anotherlilguy
Remove it. If I had the funds to do a 3-4 inch suspension lift, I would remove the body lift installed by a prior owner.
anotherlilguy is offline
post #3 of 16 Old 06-17-2013, 12:42 PM
NotURMailman
Pretty much everyone around here is going to tell you to remove the 3" BL, or cut it down to 1".
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #4 of 16 Old 06-17-2013, 12:43 PM
JBTJ
Yes, that much of a BL is uglier than sin.
JBTJ is offline
post #5 of 16 Old 06-17-2013, 12:51 PM
NotURMailman
Just to clarify, I would only cut it to 1" instead of removal if you plan on a raised belly skid in the future.
post #6 of 16 Old 06-17-2013, 12:51 PM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
For the LOVE OF GOD man,REMOVE IT!
TheBoogieman is offline
post #7 of 16 Old 06-17-2013, 12:56 PM
TheBoogieman
Deeply Disturbed
Wouldn't be easier to buy a 1.25" BL? With all the crap that'll have to be removed with a 3" BL.Fan shroud 3" relocation brackets,3" grill supports,3" t case shifter bracket,3" shifter extender (if it's a 5 speed),3" longer fuel filler hose,steering linkage brace.
post #8 of 16 Old 06-17-2013, 12:58 PM
TheBoogieman
Deeply Disturbed
Your profile says it's a 2" BL.
post #9 of 16 Old 06-17-2013, 01:00 PM
NotURMailman
You would know that better than me. I've never installed, removed, or modified any BL over 1.25" on a Jeep...
post #10 of 16 Old 06-17-2013, 01:03 PM
TheBoogieman
Deeply Disturbed
I prefer a 4" lift with stock tires.
post #11 of 16 Old 06-17-2013, 01:04 PM
TheBoogieman
Deeply Disturbed
It's a PITA! I removed one on my buddy's YJ.I don't know why they even make them.
post #12 of 16 Old 06-17-2013, 01:40 PM
NotURMailman
...I don't know why they even make them...
Because people continue to buy them.
post #13 of 16 Old 06-17-2013, 01:45 PM Thread Starter
Morgan_TJ
Thanks for the replies. The worst part about this is that i have to cut the nerf bars off so the body can come down. The previous owner welded the bars to the frame so that the tube rises about an 1 1/2" over the top of the frame. This will be a PITA to remove but I thought I would ask for some feed back.
post #14 of 16 Old 06-17-2013, 01:51 PM
TheBoogieman
Deeply Disturbed
Thanks for the replies. The worst part about this is that i have to cut the nerf bars off so the body can come down. The previous owner welded the bars to the frame so that the tube rises about an 1 1/2" over the top.
Tell the heaviest women in the neighborhood that you're doing a sexy big girls edition calender photo shoot and to stand on your nerf bars.When they fall off under the heavy pressure,buy them all a McDonalds $1 double cheeseburger and send them on their way.
post #15 of 16 Old 06-17-2013, 03:17 PM
tyvanwie
Or to add in a MML to get rid of some tcase drop
Sent from my iForum using JeepPhone
tyvanwie is offline
lifts , spacing , tires
