Tires rub on tight turns. - JeepForum.com
post #1 of 8 Old 03-08-2007, 10:13 PM Thread Starter
Jeep Guy 5
Hey everyone, I'm new to the forums and to Jeep. I just bought my 2000 Wrangler Sport in October and I love it.
But I just had a question about my tires, I have 30'' M/Ts and every time I take a tight turn they rub, but I'm not sure what they rub against. Does anyone know what they might be rubbing against or how to fix it? Any help would be great, thanks guys.
Jeep Guy 5 is offline
post #2 of 8 Old 03-08-2007, 10:16 PM
yell2000
yell2000's Avatar
30's shouldn't rub... but you just need to adjust the steer stops with a couple of washers like this: http://www.4x4xplor.com/steerstop.html
2008 JK Unlimited Rubicon
1978 CJ-5
2000 TJ Sport 4.0
2002 KJ Limited
Now that I have the garage... gotta fill it!
yell2000 is offline
post #3 of 8 Old 03-08-2007, 10:17 PM
bblhead
I had the same issue before. You're rubbing on the Lower Control Arms. Mildly annoying. It'll go away as the tread does.
Different Wheels with adjusted backspacing will make it go away, but if you are buying new wheels, might as well go for the gusto and get a lift and new tires too.
Ben
HIS: 97 Sport, 4" Rough Country X-Series, 33" Super Swamper LTB, Airaid Cold Air Intake, Banks Power Exhaust, Looking to "Fix" the axles soon
HERS: 09 Unlimited Rubicon Stock.... For now!!!!
bblhead is offline
post #4 of 8 Old 03-08-2007, 10:19 PM
Takumi665
Edit: he beat me to it
1997 TJ Sahara: Rubicon Express 2" BB, 31x10.5 Pirelli Trail Cutters, AND A FREAKIN CJ FRONT CLIP!!!!!!!!!!!!!
Takumi665 is offline
post #5 of 8 Old 03-08-2007, 10:22 PM
yell2000
yell2000's Avatar
Wait til the tread wears? Get new tires with different backspacint? Lift?
Guys, its 40 cents in washers and 10 minutes TOPS! Go to the link I posted.
1978 CJ-5
2000 TJ Sport 4.0
2002 KJ Limited
yell2000 is offline
post #6 of 8 Old 03-08-2007, 10:25 PM
XabuJr
XabuJr's Avatar
1992 XJ Cherokee
Yes exactly. Use the washers. And if you look under there you can see what it's rubbing against. It's not always rubbing against the control arms, it could be your sway bar because it has a tendency to shift back and forth to one side then the other. That same site posted above, 4x4xplor.com has a writeup on how to stop your sway bar from shifting too.
XabuJr is offline
post #7 of 8 Old 03-08-2007, 10:32 PM Thread Starter
Jeep Guy 5
Thanks for the help guys, I'll definitely try out the washers.
post #8 of 8 Old 03-08-2007, 10:34 PM
bblhead
While I realize that I could have just gotten the washers, I had to allow it to annoy the Purse Strings holder so I could "Fix" it. if "Fixing" it meant getting a lift, rims, tires, etc... I did what I had to.
HEE HEE.
Ben
bblhead is offline
The feel and handling of tight turns in 4wd Zulu TJ Wrangler Technical Forum 7 12-20-2005 01:34 PM
tight turns on tarmac huttonj TJ Wrangler Technical Forum 8 01-23-2005 12:22 PM
Wheels rub when i make tight turns.... Danlawson TJ Wrangler Technical Forum 11 01-22-2005 10:02 AM
*POP* going on in tight turns htownjeep TJ Wrangler Technical Forum 13 11-24-2004 09:45 AM
Chirping on tight turns? DutchmanAZ TJ Wrangler Technical Forum 14 11-24-2004 09:41 AM
